Question about RCA MM36110 36" TV
Cant get picture when hooking up my mm36110 to laptop by vga to vga cable. Hooking it up to 2nd vga port on the tv. Also is this the best connection to use if I'm trying to watch hi-def movies from my laptop?
  • RCA Master
  • 8,457 Answers
Tries use HDMI cable instead of the VGA cale to cable.
Posted on Dec 11, 2009
  • darileys Nov 26, 2010
    SAVE YOUR MONEY DONT USE THIS SITE...WHAT A RIPOFF!
Can I hook my Toshiba satellite C655D-S5303 up to a TV? If so how and what type of cable do I need?
You should definitely be able to, assuming your TV has the proper connection. I just looked at your computer's specs, and it has a VGA (which stands for "video graphics array") port on the left side. If your TV has a VGA port, grab a VGA cable and plug it in to the computer and the TV. You might have to tweak some graphics settings to get the best picture, but the settings should update automatically when you plug it in.
Dec 20, 2013 | Computers & Internet
How to connect a Samsung R700 PC to Sony LCD TV KDL-46S2010
hi my name is Rui i would like to help you with your problem...
its just easy to connect a PC to a sony lcd tv...^_^ here are 5 ways to do it...
1. S-Video - This is probably the most common method out there currently because an S-Video Cable is cheap as heck and just about every TV under the sun has a S-Video port. You'll have to make sure you laptop is equipped with this port. Remember, there are two types of S-Video cables: 4-pin and 7-pin. Most laptops and PC's are equipped with a 7-pin port, so if your TV only has a 4-pin S-Video port, then this method will not work.
2. VGA - If you have a HDTV, then you will be better off connecting using a VGA Cable. It gives much better quality than S-Video and as with S-Video, the cable is very cheap. You usually won't find a VGA port on regular TV's though, so this option is if you have an HDTV.
3. DVI - DVI stands for Digital Visual Interface with "digital" being the key word there. The digital signal will give a higher quality picture than either S-Video or VGA. Of course, your computer will need to have a DVI connection and your TV will need to be an HDTV. This cord is definitely not cheap, it ranges anywhere from $40 to $80.
4. HDMI - Using HDMI will give you the best quality by far. No computers that I know of yet have HDMI ports, but you can get a DVI to HDMI cable to connect it to your HDTV. HDMI is compatible with DVI.
5. Scan Coverter Box - This is the last method that I could think of and it involves using a scan converter box, which takes a VGA signal and converts it into S-Video or component video.
just try hooking up 1 of this tips i give you.well if you ask me i prefer HDMI & VGA. ^_^
but it will still depend on your preference..
hope this will help you... Good luck... ^_^
Jul 17, 2011 | Samsung Computers & Internet
I have a toshiba tv with usb can i plug a blue tooth dongle in to make it connect it to my lap top
No you cannot. The usb port on your tv is for viewing pictures and playing music. You would need specific software installed on your tv to make the bluetooth work. Since your tv is not a computer it cant be used in this way. If you want to hook up your laptop I suggest using the blue vga ports on both devices and a vga cable. You could also use hdmi if your laptop and tv support it.
Mar 31, 2011 | Toshiba Televison & Video
I no longer have the manual for the product and I want to hook it up to my TV via a cable box; we have Charter cable. The cable box is a Motorola and it says Dolby digital on the front of the cable box. ...
The white, yellow, and red RCA phono jacks on the back are called VGA inputs and outputs. The Red is
right channel audio, The white is for left channel audio. The yellow is the video. Look carefully on the back of the unit and the input jacks and output jacks should be clearly marked.
There are several other input/output ports. One is HDMI which is flat and wide. Another, not common, is composite video which uses the three above mentioned RCA jacks as indicated plus two more colored jacks. This combination gives a better picture.
A third option is a screwed on cable for input and output. This is called a "F" connector and is only used if the receiver equipment has a built in tuner. The output of a cable box is usually an "F" connector and the above described outputs
If you connect the cable box to the DVD player input and the DVD player output to the TV input, you often must have the DVD player turned on so the signal will feed to the TV.
If the TV has multiple inputs, it is best to connect the cable box to one of the TV inputs and the DVD player to another TV input. Using the TV remote you can chose which input you want to watch. The remote should have a button labeled "input"
Apr 29, 2017 | Cyberhome CH-DVD 402 DVD Player
How to hook up laptop to desk top screen
plug the VGA cable from the monitor into your laptop's VGA port if you have one. If you don't, you cant connect them.
Sep 01, 2010 | Acer Aspire 5050-3242 Notebook
No Sync message on the TV screen
Is the VGA port enabled? Have you set the computer to send data to the port? (The first may be part of the BIOS or the Device Manager. The second is in the graphics properties - right click on the desktop.) Reboot the computer to make sure it sees the new hardware with the monitor/TV on. Is the cable good? Try another one.
I hope this helps.
May 28, 2010 | Insignia 32" 720p Flat-Panel LCD HDTV
How do i hook up my hp dv6500 LT to my hdtv?
for connectin it to TV u need a cable for it. like say HDMI cable. It comes very costly. and u should be havin a LCD tv..
Sep 03, 2009 | HP Pavilion DV6500T 15.4" NOTEBOOK LAPTOP...
Screen went blank after hooking computer to it
Let's cover the obvious.
The TV works fine with other inputs (cable TV), right?
The laptop is plugged into the VGA port on the TV and the input setting is set to "VGA", right? (or does toy computer have an HDMI port that you are using?)
Is it a laptop or a PC?
If it's a laptop and the TV is connected correctly and functioning otherwise, you need to turn on the remote display port of your laptop. It's a key sequence that toggles from laptop -> external -> both.
If it's a PC, it might be a signal incompatibility. Try different resolutions or refresh rates.
Good luck.
Aug 09, 2009 | Insignia 37" LCD Flat-Panel HDTV
Samsung TV can't detect connection to laptop
Make sure you set the laptop to display at a resolution the TV can display, it seems best to start with 1024x768 then work up.
If you are using a VGA - HDMI converter it is possible you will not get a picture.
You should be able to set the laptop to 1024 x 768, plug it into the TV, select PC input on the TV remote, and the picture should appear.
If not, then check you have the monitor output on the laptop switched on, test it with another monitor to be sure.
If all the above still fails to work, and you've checked the cable the TV has a fault.
I hope this helps.
Mar 28, 2009 | Samsung LA40M81/BDX 40 in. LCD TV
Connect MM36110 to Directv HD Receiver
Use both VGA cable where require,the rest use HDMI cables
Aug 17, 2008 | RCA MM36110 36" TV
RCA MM36110 36" TV Logo
102 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
