Question about D-Link DI 514 Wireless Router (DI-514)
How do I put a passcode on the router so only I can use it?
I have a wireless router and want to "lock" it so only I can use it using my passcode. How can I do that?
  • 2,270 Answers
You want to secure the wireless network.
Is there any other computer connected to the router with the ethernet cable?
If not then you will need to connect the computer to the router with the cable.
check the ip address on the computer.open the setup page of the router. once you open the router setup page, you will find the option to make it secured.
Click Here for more info
Posted on Dec 12, 2009
Okay i am trying to connect my wii to the access point because i have wireless internet well when i finish putting in the passcode which i find on the router and it says testing connection well it say...
Hope this solution helps!
Error Code 51030, 51031, 51032
    It appears that your Wii console's Internet connection may be affected by wireless interference. Try the following:
    • Change your wireless router's channel to 1 or 11
      Changing the wireless channel on your router may help. Most wireless routers have a channel range of 1 through 11. The best channels to try are usually 1 and 11, as they do not overlap with other channels. Typically, the channel settings for your router will be found in the router's main "Wireless" tab.
    • Where is your wireless router located?
      Move your router away from walls and off the floor and try to place it in a central location in your home. Also, keep it away from metal objects such as metal filing cabinets which can cause interference.
    • Look for other devices
      Noise from cordless devices (cordless phones), or wireless electronics (wireless keyboards, headphones, cell phones), especially those using the 2.4GHz frequency, can interfere with your wireless signal. Also, older microwave models can cause wireless interference. Avoid electronics that use the 2.4GHz frequency, instead look for devices that use the 5.8GHz or 900MHz frequencies.
http://www.nintendo.com/consumer/systems/wii/es_na/windows/error51030.jsp
Sep 04, 2011 | Nintendo Wii Console
Need to connect ipod touch asking for passcode ?what's that?
you must remember the code entered when you set up your wireless router, or buy another one.
Feb 14, 2010 | Dell TrueMobile 2300 Wireless Broadband...
I used set up disk, set up SSID and added Key but laptop won't access SSID/router.
In order to access ther router wirelessly, you must first connect via cable to router. Using IE, go to http://192.168.1.1 and look in the Wireless section. Set the Network Name (SSID) you want - it can be almost anything you want - and after that you can choose what sort of Security you want to use, and set up your access passcode. Once this is all done, and access to Wireless is verified (using the passcode to access the SSID you chose) disconnect the cable. You now have control of router wirelessly.
Dec 16, 2009 | Gateway Wireless-B Router (wbr-100)
I would like to lock and secure my connection that way im the only one using it. How do i do it please help.
The way to secure your router is to enable Security at one level or another. Log in to your router, open Wireless settings, verify your SSID (Network Name), and choose security other than None. Whatever passcode you set is the code you use on all computers to access your router. If the passcode is not known then wireless access will not be granted. NOTE: Wired access has no passcodes, as you pretty much know who's plugged in to it.
Dec 01, 2009 | Computers & Internet
I misplace the disc awhile back, and i want to put a password to block others form useing it. Is there another way to do this without the disc?
You need to log in to your router (http://192.168.1.1) and go to the Wireless section. You can set a secure SSID (Network Name) and also, and in the Security section you can set up further Security with any of several methods. All let you set a passcode to limit access to only those that know the passcode.
Nov 18, 2009 | D-Link DIR-625 (790069292637) Wireless...
Need to secure wireless connection
1. Connect the computer to your Wireless router then using the internet explorer access the router gui 192.168.1.1abd7975.jpg 2. It is extremely important that you change the password for your router. Select a strong password using numbers and letters. This is the password that you will use to login and configure your router after this initial setup. 61e656e.jpg+
79ee205.jpg 3. Select a unique name for your wireless network. The name of your network is known as the SSID. This is what wireless users will use to identify which router and network they connect to. 94c0abe.jpg
Nov 17, 2009 | Linksys Wireless-G WRT54G Router
I am trying to set up another computer but cannot connect even though it shows the network available. How do I secure the wireless network?
Is this router set up with any security on the wireless? With a wired connection to the router, log in to http://192.168.1.1 or http://192.168.0.1 as needed to access your router. Once you are logged in, go to the Wireless section (the SSID, or name, of your network) and, if you have not already, set up Security. I prefer using WEP-PSK[TKIP] for its ease of use. You will need to use the new passcode to log on to your router from wireless computers. Anyone that does not know the passcode will be denied access to it.
Nov 11, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
How can I put secure my wireless network
making a wireless connection secure is very easy.
pull up the interface of the router, then look for the wireless tab.
click on the wireless tab and look for the button you can click to enable or disable wireless security..
create a passcode for your network and use that as the pass key whenever the wireless network requires it. i can provide more information if you can give me the brand name of the router you are using.. :-)
Dec 13, 2008 | Dell TrueMobile 2300 Router (000001)
When trying to use my wireless internet connectin I cannot get my wireless passcode. is it on the 2wire box
Your wireless passcode will be located in your router memory. You must log into your router and visit the link for wireless settings. It should be under security features in wireless settings.
Apr 12, 2008 | Computers & Internet
D-Link DI 514 Wireless Router (DI-514) Logo
135 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
