Question about GE Dishwashers
My ge triton xl dishwasher does not clean dishes very well.
My ge triton xl gsd6660g03ss dishwasher does not clean our dishes or silverware very well. The spray arms seem to be clear and functioning properly as is the soap dish, which we do not overfill. Any ideas?
SOURCE:
  • 1462 Answers
SOURCE: Dishwasher not getting water into spray arm, so no clean dishes
two possibilities: open door when in use. check if water is coming out of the spray arms. if it is and at a good rate, then the problem may be the spray arm jets blocked. the spray arms are only rotated by water coming out of the angled jets at their end or is the main circulating pump running ok?
Posted on Apr 02, 2007
reg501
  • 413 Answers
SOURCE: Dishwasher spray arms don't spin & spray water
Could be a a couple different issues.. Not filling with enough water or food chopper broke or food chopper filter screen clogged.
Check water level:
Run the DW and wait for the main wash to start (water will fill. pause then complete fill) The water should be no more than 1/4 inch below the heating element. If not there..replace water inlet valve.
Inspect food chopper:
1. Remove lower spray arm and rear water supply tube to upper spray arm.
2. Remove torx screws that secure the sump cover.
3. Remove primary filter
4. Remove food chopper cover to expose the chopper assembly. Inspect for breakage or blockage.
If you need further assistance, let me know
Regards,
reg501
Posted on Jun 29, 2008
SOURCE: GE Nautilus Soap does not dissolve
The Water Inlet Valve is not Working. This is a small piece at the bottom of the dishwasher where the inlet hose connects to. The Valve is stuck and water will not enter the dishwasher itself. Of course this is one of the most expensive pieces of the dishwasher to replace!
Posted on Jul 26, 2008
abhishek33
  • 1239 Answers
SOURCE: Dishes not getting clean in GE Triton XL Dishwasher
HI
Step 1: Remove the cap that holds the sprayer arm on.
Step 2: Remove the sprayer arm, the screen, the pump housing, a bolt, the upper impeller, the food disposer blade, a spacer plate, the impeller hood, a flat plate, an O-ring, and the lower impeller. Lay the parts out in order as you disassemble them so that you'll be able to reassemble them properly.
Step 3: Clean the parts thoroughly with a mild detergent solution. If any parts are worn, replace them with new ones made for the dishwasher.
Step 4: Replace any seals, such as the O-ring or other washers, with new ones.
Step 5: Reassemble the pump, keeping the parts in order.
To reach the water pump, remove the sprayer arm and screen and then the pump housing. Remove the bolt, and the pump components can be disassembled.
On some dishwashers, the lower impeller serves as a drain pump. This type of system usually has a reversible motor; machines with nonreversible motors have drain valves, as detailed previously. If your machine possesses this impeller pump system, and the water will not drain from the dishwasher, clean the lower pump impeller. This may solve the problem. Otherwise, call a professional service person.
Posted on Oct 12, 2008
larryyb
  • 291 Answers
SOURCE: soap build up on dishwasher. Dries white and stays on dishes.
the spray arms is eather bad or the wash motor ,,,,, it isn't spraying water onto the dishes with any force.
Larry
Posted on Nov 25, 2008
I have a GE Eterna Series Triton XL. It is not cleaning the dishes very well. The top dishes (glasses & mugs have debris in them. Silverware not very clean either. Can you help. I have checked the...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Sep 01, 2010 | GE Dishwashers
Film on my dishes and silverware
the detergent is not breaking down,it could be hard water try cleaning the soap dispenser,also try vinegar or CLR and run with no dishes.clean out sprayer arms make sure the wholes are not blocked up,and before loading machine rinse off dishes before loading.
Jul 08, 2010 | GE 24 in. GSD6660GSS Built-in Dishwasher
Not cleaning silverware and leaving film on dishes
to much detergant or not enough hot water prime sink before starting dw
Jul 01, 2010 | GE 24 in. Profile PDW8280JSS Built-in...
My GE Triton XLdishwasher, model GSD6300 Gooww is leaving a
The problem is hard water. www.dishwasherfilter.com has a great new product out that will solve this problem once and for all. It filters the water entering your dishwasher and leaves your dishes looking amazing. They even have a money guarantee if you are not completely satisfied. Check it out. You will love it.
May 15, 2010 | GE Tritonr XL GSD6260JCC Dishwasher
My ge triton xl dishwasher isn't getting are dishes clean. There is a white film on the glasses and I find dark spots on my plates. There is always dish soap left behind in the dish soap container. It was...
The problem is hard water. Go to www.dishwasherfilter.com. They have a new product out that solves this problem once and for all. It filters the water entering your dishwasher and removes the hard minerals that cause these spots. Very affordable and guaranteed to leave your dishes looking amazing every time.
Oct 10, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
Not cleaning dishes, leave a cloudy film on silverware
the problem is hard water. you need a dishwasher filter and your problems will be solved. you can get one at www.dishwasherfilter.com and it is guaranteed or your money back. you will love the way your dishes come out.
May 31, 2009 | GE Dishwashers
GE Triton XL, Dishwasher, while washing dishes in the sink
Ho could be a blockage in the dishwaser pump, is the drain plug clear .............
Jan 17, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
My Triton XL soap dispenser still has a clump of soap after the cycle has finished. My glasses are left with a cloudy film, and my silverware is left marked with film on it. I have cut down on the amount of detergent, and have not overfilled. I have also tried using white vinegar as the manual states. Any suggestions? Thank you
Aug 17, 2008 | Dishwashers
Dishwashers Logo
382 people viewed this question
Top GE Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Steve Allison
Steve Allison
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
