Question about Toshiba Satellite A25-S279 Notebook
I have serius difficulties with the machanical stabilization of DISPLAY, and need a manual to intent repair this mechanic problems !!!
My gear is stiff and experiencing a difficulty when engaging second gear. other gears seems to be fine but the shifting is not smooth.
I suspect that it will be in the shift mechanism
If it is a cable shift then replace the cable
If it levers or other linkages check and adjust or lubricate as required
I doubt it is in the clutch as you haven't mentioned difficulty in selecting first gear only shifting from 1 to 2nd.
Jun 21, 2015 | Opel Corsa Cars & Trucks
Gauge Info. display reads service stability system.
To start you have to run the codes from the stability control module, and once that's done then you can beging to look for the problem, only a tech II scanner can reset this module, also make sure all tires are the same size
Mar 17, 2015 | 2003 Buick Park Avenue
How to open hood cable broke
With quite some (intentional) difficulty and a long screwdriver, you can access the latch mechanism from underneath and behind the front bumper. Underskirt covers and other stuff will have to be removed.
Oct 02, 2014 | 2001 Mitsubishi Eclipse
Got 95 Audi a6 wagon used. Smell burnt oil after driving, so I guess I have an engine problem. Can non Audi mechanic work on this issue along with transmission and front end possible problems or should I...
Hello. A word to the wise. myself, if I didn't have a good relationship with a local general machanic, I would ask friends, family, and even co-workers if they have a good machanic they can recommend.
The issues you sighted could be caused by a number of things that a good machanic could resolve.
I would start there, and then let that machanic tell you if it's out of his/her ability.
I suggest this primarily because good machanics at local repair shops usually have a labor rate of $40 to $70 per hour, while dealerships are usually well over $120 per hour.
When you drive older cars, as I do, nothing is more important than finding a machanic that you can trust. They are out there, you may need to invest a little time to find them.
I do wish you all the best.
Jan 09, 2011 | 1995 Audi A6
Kenmore 417.44092500 front load washer I get a LOC Err
LOC stands for lock....door lock failure....check the door strike and make sure door is closed....if closed wil need to replace lock mechanism
Jun 30, 2009 | Kenmore HE2 Plus Front Load Washer
Timing belt
did the belt snap? the mechanic is correct and it will be quite expensive to repair, half the engine needs to be stripped down
Feb 16, 2009 | 2000 Volkswagen Beetle
DVR633H timer recording screen inaccessible
I had the same problem. Contacted Pioneer tech support, they had me send the machine in even though it was out of warranty; apparently a hard drive problem that they were researching. They sent it back with HDD replaced, worked again.
Sep 08, 2008 | Pioneer DVR-633H-S
Service Stability System keeps coming up on my display. It seems to do it right after starting my car and backing up or when coming to a stop sign. The other day I backed out of an area kind of quickly due...
I had the same problem...but I found out that the dealer had rotated incorrectly the tires.
Front and back are different sizes and if a rotation is performent front to rear, you may get a stability light warning.
I corrected my tires and the warning went a way.
Jul 17, 2008 | 2004 Cadillac SRX
Annoying buzz!
your phone have display streep problem if ur machanic, change display streep or display or bring it to your nearest repairer
Aug 27, 2007 | Motorola Mobility RAZR V3
Toshiba Satellite A25-S279 Notebook Logo
63 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
