Question about MSI K9VGM-V Motherboard
Cmos checksum error after flashing the bios
I'm pro and have tried the following
reset the bios via jumper and removing the battery removing the power cable and waiting for different times during these processes
I've reflashed with ver1.3 and ver1.7 (latest) of Phoenix - Award bios several times using winflash and awdflash in dos.
Some say it might be that the flashing progs arent reseting the bios checksum or that the battery is flat - mines not - i've cleared the cmos via winflash aswell. i'm fedup with msi for their msi live update program. The only way I get my pc to boot and load windows is by bypasing the bios (Key f1) when i boot. If i do any saving of bios settings (key F10 save and exit) the pc will not boot and i've got to reset the bios again.
I have a K9VGM-V (MSI) VIA K8M890 Chipset based motherboard. AMD 64 x2 4400+ DUALies Proccessor. 1G + 512MB DDR2 667 Ram 2 Sata HD's and one IDE (BOOTSECTOR) and a Nvdia Gfce 7300GS Graphics card Genius 5.1 Pci Soundcard (Onboard Realtech 8.1 has blown) and a Samsung DVD writemaster.
I know that if a setting in the bios is set incorrectly the pc wont boot - Like enabling a setting. But i haven't seen anything that caught my eye.
please or I might go say hi to M.. S.. I..
Johann. 20 Jan 2008
  • 3 more comments
  • MonsterByte Jan 20, 2008
    are you saying i should try with one ram mod in cause in the bios setup i dont have any options to set the timings.
    i'm gona have to sit and take the machine apart. thanx for the help.
    ok so i found the problem i took out the 512 ram module of the 1.5G total and i had no problems booting. There is no problem with that module cause it worked fine before. When I clear the cmos I can go ahead to load windows but i cant change a thing in the bios otherwize (no go) and i've got to clear the cmos everytime to be able to boot otherwize i get a black screen (no go) at the start. my bios settings for the ram is limited i cant change the timings. there must be a process.
  • MonsterByte Jan 21, 2008
    thanx for all the help thus far. im on the net and irc to figure out more solutions
    i'll get back to u soon
  • Cisf May 11, 2010
    have u disabled the onbord sound in the BIOS ?
  • Anonymous Mar 28, 2014
    I need to reset because after Bios all of my USB ports lose power at windows 7 startup.
  • 86 Answers
I had a similar experience after upgrading my RAM. When you reset your CMOS and have default settings maybe you should check if your RAM timings are correct. I could not get mine to load with both sticks in until I fixed the timings from the default settings.
Posted on Jan 20, 2008
  • Rob Breitenstein Jan 21, 2008
    This is coming straight from MSI website about your memory config.
    Due to the High Performance Memory
    design, motherboards or system configurations may or may not operate
    smoothly at the JEDEC (Joint Electron Device Engineering Council)
    standard settings (BIOS Default on the motherboard) such as DDR2
    voltage, memory speeds and memory timing. Please confirm and adjust
    your memory setting in the BIOS accordingly for better system
    stability.
    Example: Kingston HyperX DDR2-800 PC-6400 operates at 2.0V, 4-4-4-12.
    For more information about specification of high performance memory
    modules, please check with your Memory Manufactures for more details.
    Once in your BIOS you will need to most likely choose Advanced BIOS Settings and once you find the correct settings to change, it will then allow you to change your memory timings.
I want to that how i reset my recovery password and where the actual location of CMOS Battery?
In computing, BIOS (basic input output settings) refers to the information stored regarding a computer's hardware configuration, the system date and time and any applied password. This information is known as the BIOS or CMOS settings--the BIOS is stored on a small battery-powered semiconductor chip known as the CMOS (complementary metal oxide semiconductor). Having a CMOS or BIOS password restricts unauthorized changes to the system's hardware configuration and, in some computers, may even be required for booting. A lost password may be reset by removing the CMOS battery, clearing the motherboard jumper or using a software-based password cracker.
Removing CMOS Battery
1. Shut down the laptop and unplug its power cord from the wall outlet. Remove the battery cover under the laptop and gently raise the battery from its dock. Unplug any peripheral devices with a live power source connected to the laptop, such as a modem or printer.
2. Locate and remove the CMOS battery. Refer to your user manual or visit the manufacturer's website for your laptop's architecture. Follow manufacturer recommended procedure to access and remove the CMOS battery. Depending on make and model, this procedure may be more involved for some laptops and not others. The CMOS battery is a flat circular shape and resembles a watch battery.
3. Wait 30 minutes and then put the battery back in. This will erase all information stored in BIOS. Assemble the laptop, making sure you leave no loose connections. Power up the laptop and press "F1" when you get the "CMOS cheksum error" message. Type in a new password.
Clearing CMOS Jumper
1.Turn off the laptop and access the motherboard following recommended procedures.
2.Locate the jumper in the motherboard. If you do not have your motherboard documentation, locate a single jumper near the CMOS battery. In some laptops, the jumper may also be labeled in the motherboard. Put the jumper setting to "Clear" and reassemble the laptop.
3.Turn on the computer and hit "F1" when the "CMOS checksum error" message is displayed. Navigate through the BIOS settings interface to load default settings and apply a new password.
Using Password Remover
1.Download a software-based BIOS password cracker. There are numerous free programs able to recover or delete CMOS or BIOS passwords from virtually all motherboard brands. Download the file from a trusted source and save it to the desktop.
2.Burn the installed file to a CD using image burner software. Insert the CD and access the password remover tool.
3.Note the password or use the program to set a new password.
I hope you find it very helpful. Thank you for using fixya.
Aug 15, 2011 | IBM Lenovo IdeaPad Y560 Notebook
I have a Soya SY-7VCA mobo that hasn't been used for about 6 years. Upon bootup, I received a CMOS checksum error message, but was still able to load a copy of Windows 98SE that I had on floppy. After...
Probably your BIOS battery, replace that and setup you BIOS again and it should be fine. BIOS batteries look like little round watch batteries.
Any more questions just let me know.
Thanks
John
Feb 14, 2011 | Soyo SY-7VCA Motherboard
Checksum error, pc clock returning at jan 1, 2004
flashing BIOS is not needed in your case. The only way to solve your issue is to make the mobo work. When working, thats the time you can use utilities to flash your BIOS.
For now, visit your CMOS Setup by pressing DEL or F2 at startup. Then choose LOAD SETUP Defaults.
Oct 09, 2009 | Foxconn 661FX4MR-ES Motherboard
My computer can not boot -BIOS ROM checksum error
to be honest if you have tried to re-flash your bios, and it did not work you still either have hte wrong version or the disc drive your using to flash it from is faulty. try another floppy drive/disc and try again. if that dont work. to be honest it's not worth getting it repaired just go out and spend £30-40 on a new mobo. sorry i'm not more helpfull but i dont believe it's worth spending that much time and effort on an old system like that with this kind of problem. good luck to you. let me know how you get on ok.
Jun 15, 2009 | EliteGroup K7VTA3 V5.0 Motherboard
Intel 102ggc:The Firmware has detected that Cmos Checksum Error
Hi there.
Basically you first bios update was bad, if you can get into the operating system re-flash the bios again, that will sort it out.
Good luck and thanks for choosing FixYa!!
Jun 02, 2009 | Microsoft Windows XP Professional Upgrade...
P4vmm2 v8.1 bios checksum error
Try to reset your Bios by remove the CMOS battery
if it's just same
you can to replace your CMOS chip in your board with the same type ( you can get it from useless or junk 'same type' motherboard)
Nov 05, 2008 | EliteGroup P4VMM2 V8.1 Motherboard
Checksum error
Hi Oliver, the most common error related to the message,
(Bios Rom Checksum Error). Someone has left a floppy disk in the floppy drive. Once the floppy disk has been removed press the reset button on the PC, your windows will start normally. Next place to look is in your bios.
Open your manual to page 27.
Enter your bios & go to the title Advanced BIOS Features. Check First, Second & Third boot devices they should be as follows. Floppy disk drive, CD-ROM drive & primary hard disk drive. If both of the above are ok than try clearing the cmos/bios by resetting the cmos jumper (JP1) location on page 5. Descriptions of page five on page 6. CMOS settings on page 9.
When your system restarts re-enter your cmos & reset up your bios settings. Lastly if none of the above has fixed the error message, than remove the cmos battery & check its voltage. It should maintain 3volts. If yours' is lower than 3volts replace the cmos battery. There is one other possible fix. It’s an option not given lightly. Flashing a cmos/bios is not recommended unless all other options have failed.
Bios link for the EliteGroup P4VMM2 V8.1
http://www.ecs.com.tw/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=436&DetailName=Bios&DetailDesc=P4VMM2%20%20(V8.1)&CategoryID=1&MenuID=82&LanID=0
Main web site;
http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?CategoryID=1&DetailID=436&DetailName=Feature&MenuID=52&LanID=0
Good luck Oliver!
Mike
Aug 23, 2008 | EliteGroup P4VMM2 V8.1 Motherboard
CMOS Checksum error.
the only thing i can think of is when you changed the battery somehow the board terminals positive negative are not in proper contact with battery
did you try resetting bios by the pins on the motherboard
somewhere on the board is printed bios reset or words to the effect
most times it is a 2 pin connector with a jumper only on 1 pin connect the jumper across both pins remove and try to reboot
hope this helps
Jul 14, 2008 | ASUS M2N-VM DVI - Motherboard - micro ATX...
CMOS BAD CHECKSUM
Reseat your ram modules and remove the 2nd hdd
try rebooting
If same thing , then reset the Bios to default ,save and exit
Try again..
If same thing ? assuming you have more then 1 stick of ram,, try booting with 1 stick removed . to eliminate ram modules being bad
then switch ram untill you have verified ram chips are or aren't bad
Hope this helps
Nov 13, 2007 | E-Machines eMachines Desktop PC
MSI K9VGM-V Motherboard Logo
1,043 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
