Question about Refrigerators
Frig problem my water and ice taste really horible in the lsat 2 days, what could be the problem?
  • jturn2478 May 25, 2008
    We just replaced the filter in our fridge just because the light indicated it was time. Before we changed it, the ice tasted like mildew or mold and after we changed it there was not change in the taste. It tastes horrible.
When I open the frig door there is a nasty smell. I have checked all contents and they seem fine, I ahve tried to clean through the hole but no change. It i an old frig. What might it be. Thank you Ken Mills
Posted on Jul 29, 2008
  • 397 Answers
I would check your filtering
Posted on Jan 20, 2008
6ya staff
SOURCE:
Kenmore fridge with a strong chemical taste in water and ice
Every time you replace a water filter you want to purge about 3-4 gallons. Or maybe the filter was bad.
Dec 31, 2012 | Refrigerators
Water and Ice have tasted like **** since we got the refrigerator (about 1 year ago) I believe the soultion is bypass the storage tank, but I can't find it..
When the Ice Smells
1. Replace water filters every 6 months to avoid musty odors from getting into your ice. If you don't replace the filters, they become clogged with the chemicals they have been removing from the water. In addition to smelly ice, you may see a drop in water pressure if you have a water dispenser, and possibly a decrease in ice cube size.
2. Remove the cap from the new filter.
3. Place the cartridge inside the holder, and twist to the right.
When the ice smells...water & ice have tasted like ***** also.
Good day : )
Jun 21, 2011 | Refrigerators
Our ice tastes really bad. I've changed the fiilter/regulator, the main freezing tray and the water line into the filter/regulator. Still, bad tasting ice. What should I do next?
Disconnect the water line from the wall and taste the water or<br /> freeze it in another ref for verification.<br /> <br /> If this was helpful please rate me.<br />IMUFO2<br />Leo Ponder Appliance-Tyler,Texas<br /><a href="mailto:[email protected]">[email protected]</a>
Aug 31, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
The ice and water from my refrigerator taste bad
run the water thr it for about 5 mintes and flush out theline.
Mar 09, 2009 | Refrigerators
Coffee taste bad
Coffee Tastes Bad- Cuisinart
1) Run 1 tsp lemon juice per 1 cup water through Cuisinart
2) Use filtered water
3) Replace the charcoal water filters every 3-4 mos
4) Use better coffee
-Tha Mp3 Doctor
Nov 12, 2008 | Cuisinart (ICE-20) 1.5 Quart Ice Cream...
Water smells/tastes like freon
freon has no smell or taste and in any case doesn't get anywhere near the water. look elsewhere like your water supply
Nov 04, 2008 | Kenmore 53463 Stainless Steel Side by Side...
Bad water & ice cube taste
Hello redwood City
Welcome
You said,
Your Kitchenaid Superba KSRG25FKBL15 has bad tasting water and ice cubes. You replaced the copper tubing which delivers the water to the fridge and that didn't help. You replaced the copper tubing again with plastic tubing...no better. Any suggestions? Your tap water doesn't taste this bad.You bought a Kenmore french door fridge with water dispenser in the door in July 2008. The fridge has a filter. A few weeks after the fridge came the water and ice started tasting really bad, unlike any bad water taste I have ever tasted. And your tap water is fine. The bad taste appears to be random. Sometimes you get a cup full of nasty water and sometimes it tastes fine.
First you must know you have a 1 year warranty and can have them come out to fix anything, no charge.If it persists. You will have to get tough and you , MUST INSIST THEY REPLACE YOUR FRIDGE
When installing the water line these were a part of the directions!
Did you do this before connecting the water line to your fridge?
"Place the free end of the tubing in a container or sink, and
turn ON the main water supply. Flush the tubing until water is
clear. Turn OFF the shutoff valve on the water pipe. Coil the
copper tubing."
Whirlpool remedy
Off-taste, odor or gray color in the ice
1.Are the plumbing connections new, causing discolored or
off-flavored ice? Discard the first few batches of ice.
2.Have the ice cubes been stored too long? Throw old ice
away and make a new supply.
3.Does the freezer and ice storage bin need to be cleaned?
See “Cleaning” or “Ice Maker and Storage Bin.”
4.Has food in the freezer or refrigerator been wrapped
properly? Use airtight, moisture-proof packaging to help
prevent odor transfer to stored food.
5.Does the water contain minerals (such as sulfur)? A filter
may need to be installed to remove the minerals.
6. Is there a water filter installed on the refrigerator? Gray or
dark discoloration in ice indicates that the water filtration
system needs additional flushing. Run additional water
through the water dispenser to flush the water filtration
system more thoroughly (at least 2 to 3 gal. [8 to 12 L] or 6 to
7 minutes initially). Discard discolored ice.
Let me know what works,
Thank You ,
HUUUM!!
Please remember to leave a rating.
Sep 25, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
132 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
