Question about Philips 42PFL5332D 42 in. LCD Television
Tv is normal but when heats up half screen goes red??
  • 11,361 Answers
It sounds like the LCD controller (t-con) board is bad, try removing the back cover and cool down the board with a samlle fan blowing on the board, you can see what the board looks like here or buy the replacement, but you need to get the numbers pronted on the board since your TV has more than one version as shown on the website: http://www.shopjimmy.com/catalogsearch/result/?q=Philips+42PFL5332D+
Posted on Dec 11, 2009
SOURCE:
We have half a screen when we turn on TV
Your TV's primary control board may have gone bad and when the TV heats up to a certain tempurature and then it goes back to normal i suggest a new tv but you can order new parts and replace it yourself, if you need parts I can get a list of parts that may fix the TV
Jan 01, 2012 | LG 42LC2D 42 in. LCD HDTV
Turn on tv and get full screen but after 5 minutes half the screen starts to scramble then goes blank leaving me with half ascreen
I would suspect your power supply deflection board is failing. Normally these tvs have a problem with the hyper board in which the image is scrambled and then clears up. Your problem is just the opposite and indicates a part is heating up on the power board. A good visual look at the board will be your best starting point. Look for burn marks, a capacitor that is rounded on top or leaking. Also look carefully to ensure your CRT bulbs have not leaked fluid onto one of the boards.
It's a starting point.
Feb 24, 2011 | Toshiba 57H81 57" Rear Projection...
Half the tv screen goes black randomly,then returns to normal
The Tuner signal board have problems.The board CPU,Chip,have intermitten short.When the chip is completely dead.The tv will get only LED light indicator power only,will not get tv signal pictures.
Apr 12, 2010 | LG 42LC2D 42 in. LCD HDTV
Picture is flashing red
the panels going bad. sometimes the panel will seperate dew to the heat that it produces. most of the time its not economical to fix these type of issues.
Jun 02, 2009 | Televison & Video
52" Samsung that the top half of screen goes black.
the HDTV has a heat-related problem check your fans. Do they remove heat? the vertical chips paint the screen from top to middle and, middle to bottom so; your top to middle vertical chip is overheating as is your video chip; that is why you have "glitter" in the back ground. get rid of the heat or, bye,bye TV.
May 20, 2009 | Samsung HP-R5072 50 in. Plasma HDTV
TV..everything works...but screen goes red...I smack it, it goes back to normal, but then back to red.
it soinds like a convergence problem, i would try haveing someone take a look at it
May 20, 2009 | Hitachi 65F59 65" HDTV
Model 42mf231d/17 42" plasma
If the loss of picture is either on top half or bottom half of screen. there are y buffer boards that go from top to bottom on left side of screen when looking at back that control those sections. when there is loss of half of picture then buffer associated with that area would be at fault and would need to be replaced. when i see a degrading symptom such as loss of picture on top half or bottom half leading to no picture issue normally you would check heat syncs on y sustain board and if not heating up after a few minutes of being turned on would recommend replacing y main and both y upper and lower y buffer boards as they complete a circuit
Jun 04, 2008 | Philips Magnavox 27MS343S 27" TV
Sony 65 Inch Projection TV Color Red Green Separation
Sounds like a convergence issue. Call Sony for an ASC that can come out and give you an estimate. You are probably looking at $200-400 to do the repair.
Nov 02, 2007 | Sony KP-65WS500 65" Rear Projection...
Philips 42PFL5332D 42 in. LCD Television Logo
67 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
