How do i get the monitor to work if i didn't change the settings on the 1st monitor
    Novelist:
  • 108 Answers
Assuming that you've just added a second monitor.
You need to go into the Display Settings, or Display Properties dialogue box.
In there go to the Settings tab.
You'll see two squares marked 1 and 2. select the second one, then lower down on the dialogue box you'll see a checkbox to enable "Extend my Desktop to this Monitor"
Check it and you're good.
With your mouse you can select each monitor, and drag them around to adjust how your two desktop displays will seem together, higher lower, left or right side. Experiment till you're comfortable.
Hope this helps.
Posted on Dec 11, 2009
  • Richard Schabler Dec 12, 2009
    When you firs turn on the computer, the BIOS screen should show on all monitors. If you see this screen, black and white text, memory count check, diagnostic display before the Windows starts. Your computer display is good and working.
    If not, your monitor, or video card may be dammaged or not working.
    Be shure the power lite is on on the front of the monitor to show it is getting power. Be shure the power lite changes from orange to green when the computer is turned on.
    On the Video Output, be shure the terminal is hooked up properly.
    If the BIOS displays, but Windows dosn't have a display, reset the machine to restart it, and when the BIOS screen finishes and Windows starts, press the F8 Key.
    A dos screen will come up and you will have the option to start in "Safe Mode", this is Windows working with basic settings using generic all purpose drivers.
    Your display will work (although it will be course), and you can change your display type and settings.
    In particular, you want to choose which video output you want to use as your "Primary Display";
    and you want to disable a secondary display extention, since you only have one monitor now.
    With these settings changed, restart the computer and allow Windows to start in Normal Mode. Your new display settings should work.
    Beyond this, you will have to manipulate the drivers and video software in the Hardware section of the Windows OS.
    Good Luck.
Want to add a different monitor to IBM ThinkCentre desktop steps
I'm not sure I understand what you intend to do ..but if this is just a monitor you intend to use..it may not be functional ..If you plugged it in the main vga out ..and it didn't come on right ..this means it is either something wrong with the monitor or with the video card ..
If you plugged it as secondary monitor..and you want to use them both ..but it didn't come on ..this is another story ..and you will have to get to the video settings ..and select teh desktops..and enable teh secondary monitor from teh video card settings ..Make sure you select the correct fuinction for it ..It may be clone ..and this will make them both look the same ..or extended ..and this will basically extend your monitor with the other ..and you will be able to slide your mouse from one to the other and also select different tasks ...
In this case you will also have to arrange their position to coincide with their actual one for to avoid confusion ..(just drag the monitors on the settings ..and change position ..)
If enabling will not make them function right ..you have to reinstall teh video card ..and restart ..or ..install teh operation system with both plugged in ..( i had some issues with a tv added as secondary monitor ..and never displayed colored images unless it was installed from the begining already plugged in with the main one ) ..
Jan 07, 2012 | IBM Lenovo ThinkCentre M55e PC Desktop
No picture on screen but power supply is OK
Here is a couple of suggestions for this monitor. 1st check your connection to the computer.
make sure the VGA/HDMI/DVI is properly connected. 2nd check to see if the monitor is setup
to use the right source. Some monitors do this automatically others may need to be manually set.
either look for a button to do this or bring up the monitors menu by hitting the menu button. If the monitors menu button does'nt bring up a menu when the computer is off then the monitor is probably bad.
If the monitor works until the OS boots then goes black. The video card in your computer is set up
improperly with the monitor . In Windows hit F8 as the OS boots this will cause the computer to boot in safe mode. Once in safe mode right click on the desktop then go under properties then settings and change the display option to the correct monitor. You can also go to the device manager in my computer under system information, hardware, device manager and change the monitor here also.
May 01, 2011 | BenQ FP731 17" LCD Monitor
Po720 code and po733 code plus leaking oil
P0720-OUTPUT SPEED SENSOR ERROR
WHEN MONITORED
The transmission gear ratio is monitored continuously while the transmission is in gear.
SET CONDITION
If there is an excessive change in output RPM in any gear. This DTC can take up to five minutes of problem identification before illuminating the M.I.L.
POSSIBLE CAUSES[*]Output speed sensor signal circuit open[*]Speed sensor ground circuit open[*]Output speed sensor signal circuit short to ground[*]Speed sensor ground circuit short to ground[*]Output speed sensor signal circuit short to voltage[*]Speed sensor ground circuit short to voltage[*]Output speed sensor[*Powertrain Control Module (PCM)[*]Intermittent wiring and connectorsi cen get you a full flow chart on how to check it out if you wish
p0733 Gear 3 Incorrect ratio
Jan 03, 2011 | Chrysler Voyager Cars & Trucks
My monitors menu keeps popping up and changing the monitors settings it seems as if its going haywire
mcdevito75 here, You can try to disconnect the monitor from the computer for about 5 minutes and then reconnect, then press auto on the monitor seee what happens. I didn:t see anything related to your problem in Start, then control panel then visiual display that can cause your problem.
Nov 12, 2009 | HP Compaq FS7600 17" CRT Monitor
Monitor lost resolution
itz probably corrupted software/driver or graphic adapter..
try reinstalling the drivers..
but 1st open control panel->display->click on the 'Settings' tab->Color Quality= (Highest) 32 bit; Screen Resolution= 1024x768 pixels (atleast)..
..try contacting ur system admin/vendor....
Oct 27, 2009 | Computers & Internet
Monitor colors are not displaying correctly
Hi, At the worst it is a blown monitor, but have hope. 1st try a new or known good lead, between monitor and PC. 2nd put monitor with own lead on good PC. if 1st works = result. if 2nd and monitor is same, suspect monitor, however, if 2nd works ok on other PC, then look at ur vid card. Either way, this test sequence should save you some $. Be lucky.
Aug 15, 2009 | Acer AL1916W 19" LCD Monitor
Pc monitor blank
Perform a system restore to see if it will restore your settings.
May 12, 2009 | EliteGroup GF8200 MCP78S AM2+ Atx 32GB...
Display problem in my LG 15'' monitors
1. cheak the filament path diode,capacitor.
2. there is dry points in power section.
3. replaced 3842 IC supply capacitor 47/100v.
4. LOT sarounds. if in case near to lot one resistor burnt (12k ohm ) change the lot & capacitors,resistor
Nov 22, 2008 | LG Studioworks 563N 15" CRT Monitor
Monitor not working
You will need to change the display settings for the type of lcd monitor you have, it is a wide screen I am assuming, you can change this by right clicking on the desktop select properties then settings the screen resolution should be on the middle left side and change this until you get a screen that you like There is also an advanced setting then select monitor at the top tab and change to refresh rate to the lowest setting (60 hz) this should get the HCL monitor up then change the setting until they dont work the operating system will revert to the previous settings if you cant see anything after a change. you may also need to use the automated setup on the lcd monitor select auto from the menu (osd). Now if you can not do this on the HCL lcd you may need to use that other Samsung monitor and then set up on that at the lowest resolution so that the lcd can be changed with a working screen. Lastly you may need to uninstall the samsung monitor drivers if you installed those, and leave the generic drivers in for the monitor (plug and play monitor).
I am making some guesses here as you did not tell me if the 1st Samsung monitor was a lcd also , and if the second HCL monitor is a wide screen etc what type of operating system are you running is also important 98 is fussy and 2000 is much more simplified as is XP , vista would be garbage (if you could get it to run on a pIII),
As for reasons for resolution problems, way too many variables to discuss in a short answer forum like this, sufficed to say that the resolution is different because in the past there were lower resolution (less pixels) on monitors, the refresh rates were different by manufacturers and the way the lines were scanned could be different, so setup of the monitor with the video card was also very important interlacing etc was also handled differently until that industry decided on a common standard.
I hope this helps you to get the monitor up and running.
Jul 17, 2008 | Computers & Internet
Computers & Internet Logo
52 people viewed this question
Alun Cox
David Payne
David Payne
