Question about Pioneer Audio Players & Recorders
Require drivebelt for a pionner E1000 a/H record turntable.
  • haydncj Dec 11, 2009
    Now spelt correctly Pioneer E1000 A/H stereo record turntable belt
2 Suggested Answers
SOURCE:
  • 910 Answers
SOURCE: sony casette recorder model cfd-8 drivebelts-
They don't appear to list the belts as a part.
http://www.encompassparts.com/models/?SONCFD8
If you can take them out and measure the overall diameter and cross section (square, round etc & size) I'll see what I can find.
Posted on Apr 20, 2011
Which ports do I use to connect a Thorens TD166 turntable to a VSX D511 reciever, and does it require a pre - amp
Turntable plugs into an RIAA pre amp, (if not fitted within the turntable) then to a line level input on your amplifier.
Mar 27, 2017 | Thorens Audio Players & Recorders
What is the best replacement stylus for a Stanton STR8-50 model turntable
What kind of music do you like most and if it really goes about souns, it aint a bad idea, replacing the tonearmwire and rca and buy some good feet----> it helps. But whichnconcorde do you want yourself?
Oct 18, 2012 | Stanton STR8-50 Turntable
Have Kenwood P25 record player and Kenwood Amplifier A-322, on playing record player sound is very quiet. On a previous record player (P-110) there was a switch on the underside.
I can't find either model you mention anywhere but a turntable without a built-in PHONO preamp will require an external on to drive any input not marked explicitly for PHONO.
eBay always has some...
http://shop.ebay.com/?_from=R40&_trksid=p3984.m570.l1311&_nkw=phono+preamp&_sacat=See-All-Categories
May 09, 2011 | Kenwood KD-291RC Turntable
My Pioneer PL-112D turntable has a broken drivebelt, is it possible to buy a new one, and is there a diagram showing the belt "routing". Thanks.
I don't believe this belt is being provided by the Pioneer. So I did find another option at a reasonable price on E-bay.
http://cgi.ebay.com.sg/TURNTABLE-DRIVE-BELT-FITS-PIONEER-PL-12D-PL-112D-/290432607483
Jan 17, 2011 | Pioneer Audio Players & Recorders
I have a america dj turntable and the record plate wont turn. What could be the problem?
try the belt in the belt drive, may require pulling it apart but if you can manage it belts can be easily found on ebay. hope this helps
Nov 02, 2010 | American DJ TTD-2500 MKII Turntable
Only records 3 or 4 out of 10 songs
Please describe the exact model number and what it's doing wrong (skipping, I suspect). The tonearm setup is critical for proper tracking. Do it again with extreme care if mistracking is your problem.
I found one model online and a review with some sample of music. Quite interesting...
http://www.everythingusb.com/ion_ttusb10_usb_turntable_13231.html
The author complained about some things that clearly mark him as a stranger to finer turntables. Complaining about having to assemble and position the 'rubber band', aka the drivebelt, and the tonearm counterweight shows that he underestimates the precision required to for a mechanism to properly track the microscopic undulations of the groove without skipping into the air or gouging it to death.
Some basics when recording from a turntable...
1) Place the turntable as far from speakers as possible on a solid surface that you will not touch during the recording
2) Keep the volume low enough that airborne sounds don't cause mistracking of the stylus *
3) Avoid anything that will cause vibration or movement of the turntable.
* If you have a subwoofer, turn it off.
Some advice after reading the articel: don't try to save recording time by playing the discs at 45rpm. The best tracking of the disc and recording of the minute details in the grooves will be at the nativespeed of the recording. Digital manipulation later only gloms up the accuracy you probably want.
In general, the fewer the conversions steps in the analog domain, the better; and the fewer the bit rate conversions in the digital domain, the better.
Apr 03, 2009 | ION Audio Vinyl Recording Turntable
Ion ittusb turntable interference
Please describe the conditions under which the noise happens. Is it always the same place? Whic is it - static or some other kind of interference? Read the following. If you're using high speaker volume to monitor while recording you could experiment with identifying it as the casue by cranking it up to see if you can make it worse.
As with any turntable the following advice for this one will apply:
The author complained about some things that clearly mark him as a stranger to finer turntables. Complaining about having to assemble and position the 'rubber band', aka the drivebelt, and the tonearm counterweight shows that he underestimates the precision required for a mechanism to rotate at a constant precise speed while properly tracking the microscopic undulations of the groove without skipping into the air or gouging it to death.
3) Avoid anything that will cause vibration or movement of the turntable. (Tip toe)
Some advice after reading the article: don't try to save recording time by playing the discs at 45rpm. The best tracking of the disc and recording of the minute details in the grooves will be at the nativespeed of the recording. Digital manipulation later only gloms up the accuracy you probably want.
Mar 26, 2009 | ION Audio Vinyl Recording Turntable
Stop button not working properly
Did you get a manual with the unit? Is it set up correctly?
When you initiate a start do you hear the motor startturning (somewhere underneath the platter)? It would be real quiet and vibration-free or it would not be very good for use on a turntable. Is the drive belt attached? See the picture in the link.
What do you mean by the STOP mechanism? What do you mean by ON position?
How many pops? How long?
Manual Motor STOP occurs when the tonearm is swung to the right onto its rest.
Mar 14, 2009 | ION Audio Vinyl Recording Turntable
Record will not play to end.
There is a mechanism underneath the deck which senses "end of record". This is operating too early and will require adjustment.
Dec 30, 2008 | ION Audio TTUSB10 Turntable
79 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Steve Sweetleaf
Steve Sweetleaf
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
