Question about Memorex MVT2135 13 in. TV/VCR Combo
Programming Device Control code for Memorex MVT2135B
What is the Memorex TV/VCR four digit code? I want to enable my Comcast remote to control both the TV/VRC unit as well as the cable box. THX
  • 2 more comments
  • Jeff4346 Feb 07, 2008
    I would also like to know what the four digit code is for the MVT2135 TV/VCR combo tv set is. I am trying to setup my Dishnetwork remote so that it will operate the set.
  • Anonymous May 15, 2008
    I'm having the same issues with my Comcast Remote. I've tried all codes listed for memorx tv's, as well as the tv/vcr combo I have. Also, I've tried using comcast remote control search protocols, which is described in the comcast online remote control instructions. nothing has worked yet.
  • Anonymous Oct 20, 2008
    Any of the codes i've used for a universal remote will not work either.
  • Anonymous Feb 04, 2009
    I've also tried all the codes and the code search option. Nothing works!
    New Friend:
21479 is the Sansui code that worked for me with the Memorex TV/VCR combo MTVT2135 and the Comcast Custom DVR 3 Device remote.
Posted on Apr 17, 2010
  • Yesenia Guerrero
    Yesenia Guerrero Nov 13, 2013
    The 21479 worked for me YAY! But it won't control the volume which is the main reason I wanted to sync the remote to the TV. Is there a way to control the volume as well?
The Memorex TV/VCR combo MTVT2135 is actully a Sansui TVCR1322 mind is with Sansui 076R0C6010 remote the code that work with my comcast remote was 11911, you might try other Sansui codes if that dosn't work
Posted on Mar 14, 2009
Without the remote is there a way to setup up the TV manually from the front panel?
Posted on Oct 23, 2008
I have GE uninveral remote and code 0310 works for the tv but can't get the cable/sat to work.
Posted on Oct 27, 2008
6ya staff
SOURCE:
How to program Comcast 1067BC3 remote for Memorex DVD
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Mar 25, 2012 | Televison & Video
Need codes for memorex tv
Hello
Three digit universal remote codes for Memorex TV are:
000/ 001/ 004/ 009/ 046/ 049/ 051/ 135
Four digit coeds are:
0004 0009 0049 0051 0135 0031 0000 0268 0310 0001
Direct Code Entry
Feb 06, 2012 | Televison & Video
Need codes for emerson & also insructions to program comcast remote
Hello
Setup codes for Emerson TV with "Comcast On demand Custom-3 Universal remote control are:
0154, 0236, 0463, 0180, 0282,
0178, 0179, 0038, 0177, 0280
The Comcast Custom 3-Device universal
remote control is preprogrammed at
the factory to operate the Cable Box
supplied by your Comcast system, an
RCA TV, and an RCA VCR (in the AUX
mode). To control devices other than
default brands (excluding the Cable
Box), perform the below steps; otherwise
skip this section:
1* Turn on a device (e.g., VCR or DVD
Player) and, if applicable, insert
media, (e.g., video cassette or disc).
NOTE: Please read steps 2 to 6 completely
before proceeding. Highlight or write
down the codes and device you wish to
program before moving on to step 2.
2* On the remote control, press a
device key once (i.e., AUX or TV).
NOTE: Use the AUX key to program
control of an Audio Amplifier or
Receiver, a DVD Player, a Home-
Theater-In-A-Box Device, a PVR (or
DVR), or a VCR.
3* Press and hold Setup until the
selected mode key blinks twice,
then release Setup.
4* Locate the code for your device in
Manufacturer's Codes on the back
of this user guide. Brands are listed
in alphabetical order with the
most popular codes listed first.
5* Enter the first four-digit code for
your device. If you perform this
procedure correctly, the selected
mode key will blink twice.
NOTE: If you enter an invalid code, the
selected mode key will display one long
blink and exit the programming mode.
Repeat steps 2 to 5 with a valid code.
6* Aim the remote control at your
device and press Power once. The
device should turn off. If it does
not respond, repeat steps 2 to 6,
trying each code listed for your
brand until you find one that
Searching For Your Code.
NOTE: If the device does not have a
Power key, press the (Play) key
OK
Aug 22, 2011 | Televison & Video
Remote control code for comcast for lc-42SB48UT 42
Hello
Three digit universal remote codes for Sharp TV are:
004/ 009/ 079/ 095/ 111/ 112/ 114/ 122/ 123/ 124/ 173
Four digit universal remote code for Sharp are:
0079 0123 0063 0020 0004 0009 0226 0266 0006 0095 0122
Direct Code Entry
Four digit universal remote codes for Sharp TV with RCA RCR311W are:
1004, 1007, 1009, 1015, 1023, 1078, 1083, 1094, 1107, 1123, 1125, 1158, 1182, 1195
OK.
Jul 02, 2011 | Sharp Televison & Video
What are the setup codes for a 20' Memorex.
Hello
Three digit universal remote codes for Memorex are: 000/ 001/ 004/ 009/ 046/ 049/ 051/ 135
Four digit universal remote code for Memorex are: 0004 0009 0049 0051 0135 0031 0000 0268 0310 0001
Direct Code Entry
Jul 01, 2011 | Televison & Video
What is the code for a Sanyo DP26640 26" LCD TV
Hello
Remote code for Sanyo TV with Comcast Custom DVR-3 device universal remote control is
0154
1. Turn on a device (e.g., VCR or DVD
2. On the remote control, press a
DVR), or a VCR.
3. Press and hold Setup until the
then release Setup.
4. Locate the code for your device in
5. Enter the first four-digit code for
6. Aim the remote control at your
works. If it still does not work, try
Apr 29, 2011 | Sanyo Televison & Video
Need code for magnavox tv urc-4021boo
Hi, the codes you have requested;
Magnavox - 0054, 0706, 0030, 1454, 1254
Instructions to program code:
1. Turn on a desired device (e.g.,VCR or DVD player) and, if applicable, insert media (e.g., cassette or disc). NOTE: Please read steps 2 through 4 completely before proceeding. Highlight or write down the codes and device you wish to program before starting step 2.
2. On the remote control,press a device key once (i.e., VCR/PVR, DVD, CBL/SAT,or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo, or TV/VCR/DVD Player Combo press VCR/PVR once.After programming a VCR Combo device, you will be able to control channel selection, volume, and VCR functions. NOTE: To program control of a DVD Player,DVD Player/VCR Combo, or TV/DVD Player Combo, press DVD once.After programming a DVD Combo device, you will be able to control channel selection, volume, and DVD functions. NOTE: To program control of a Cable Box, Cable Box/PVR (or DVR) Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR) Combo, press CBL/SAT once.
3. Press and hold SET until the LED (red light) blinks twice,then release SET.
4. Use the Manufacturer's Codes (starting on page 18) to locate the type of device and brand name and then enter the first four-digit code for your device. If performed correctly,
the LED will blink twice. NOTE: If the LED did not blink twice, repeat steps 2 through 4 and enter
the same code again.
5. Aim the remote control at the device and press POWER once.The device should turn off. If it does not, repeat steps 2 through 5, trying each code for your brand until you find one that works.
Feb 12, 2011 | One For All URC-4021 Remote Control
What are the tv codes for this tv?
Hello
Three digit universal remote code for Memorex are:-
002 115 206 502 506 601 701 706 000/ 001/ 004/ 009/ 046/ 049/ 051/ 135
Four digit universal remote code for Memorex are:-
Direct Code Entry
NB: Switch OFF and switch ON the Tv each time with its front panel power ON/OFF switch, before trying an other code.
OK.
Jan 02, 2011 | Memorex MVDT2402 24 in. TV/VCR/DVD Combo
I have URC3220 remote and a Magnavox TV How do I program it?
PLease follow the steps below
1.Turn on a desired device (e.g.,VCR or DVD player) and, if
2. On the remote control, press a device key once (i.e., DVD/VCR,
CBL/SAT,or TV).
or TV/VCR/DVD Player Combo press DVD/VCR once.After programming
Combo, or TV/DVD Player Combo, press DVD/VCR once.After programming
then release SET.
4. Use the Manufacturer’s Codes to locate the type of device and brand name and then enter
6.You are set
thanx
Jul 24, 2010 | One For All URC4110 Remote Control
Memorex MVT2135 13 in. TV/VCR Combo Logo
2,383 people viewed this question
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Ekse
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
