Question about Samsung Rant Cell Phone
Mircosd card when i hook the usb data cable into my phone which is a samsung exclaimit keeps telling me to connect the usb cord and i have already
Memory full, install new SD card, how move files to new SD card?
One of these ought to work:
  1. Remove SD card, connect to PC using a card reader (and adapter if needed), copy files to PC. Connect a larger capacity SD card to PC, copy files from PC to new, larger SD card, install new SD card in phone.
  2. Connect phone to PC with USB cable, then do same process as above.
  3. Back up phone to Google, Samsung, or other cloud resource. Replace SD card with larger one. Restore phone from cloud.
Mar 02, 2015 | Samsung Cell Phones
How I can connect my Samsung GT-E2152 mobile with computer through usb cable
Make the FixYa experience better for everyone by voting.
My name is Ben and I'm your guru, i.e., mentor, an influential teacher or popular expert: a management guru. - origin from Sanskrit, 'weighty, grave', for today.
How to connect via data cable?
Materials:
USB data cable.
PC Suite mobile software.
What is a data cable?
A data cable is a long cord, which connects your computer with your cell phone in order to share data between them. The data cable transfers electrical signals from cell phone to computer and computer to cell phone.
What is PC Suite mobile software?
You can buy the following commercially or on eBay for about $10. It contains everything you'll need.
All the best,
Ben
Sep 15, 2011 | Samsung Cell Phones
Samsung C3050 HOW DO I LOAD PICTURES ONTO SD CARD
You will need a USB/Data cable to connect the phone to your computer, if you don't have one they can be bought from here http://cgi.ebay.co.uk/New-Genuine-Samsung-C3050-USB-Data-Cable-Sync-Lead-/260509082004?pt=UK_MobilePhones_MobilePhoneAccesories_MobilePhoneDataCables_JN&hash=item3ca78d2194
Then go here for the samsung pc studio programme that will assist you in putting pictures on your SD Card
Feb 17, 2011 | Samsung C3050 Cell Phone
When I connect my samsung monte c3200 phone with pc through cable it says USB device not recognised. I set it to seting > pc connection > ask on connection. Blue tooth is off. Already...
Plug your usb cable into your computer available usb port.Check for the hardware specification, like usb 1.0, usb 1.1. or usb 2.0. Try also installing your device and kies applicatin to other computer to identify or to troubleshoot where exactly the problem. Good day
Nov 30, 2010 | Samsung USB Interface Data Cable for...
When i connect my samsung code sch-i220 to my laptop using a USB cord nothing happens. help?
you have to install the software provided by your cellphone carrier(i,e. MetroPcs installation disk) then you must use either the original Samsung data micro USB to USB cable or a USB 2.0 compatible equivalent. The USB 1.1 cables will only charge your phone but not allow you to transfer data so your PC wont see the phone.
Sep 14, 2010 | Cell Phones
How do we add music to the LG xenon, i hooked up the USB cord into the comptuer and stuff, but it wont let me add the music, soo how do we do that ? i dont want to go buy a memory card cause i jsut go the...
[Extra Hardwares Needed] 1. MicroSD card 2. "Micro-B" USB data cable
[Procedure - either PC or Mac] 1. Disconnect USB cable (if you connected already) 2. In Xenon phone Settings -> More -> Connection -> USB Connection -> (select) Mass Storage Note: If you don't do this, you will get an error message "Unable to use liscense. TRy again after formatting memory card." 3. Insert MicroSD card into Xenon phone slot 4. Connect Xenon phone to PC (or Mac) using USB cable 5. If MicroSD is not accessible as a disk drive, then (1) remove the MicroSD from Xenon (2) format the MicroSD from PC (3) retry step# 3 & 4 6. You can drag & drop your folders and/or files (.mp3 or .m4a only) into the MicroSD card 7. Disconnect Xenon phone from PC then go to "AT&T Music" -> "Music Player" Note: All features work except for "Playlists" 8. If you want "Playlists", you need to use Windows Media Player and sync. iTunes doesn't work since it doesn't allow other devices than iPod. This means that you cannot use Mac to create/sync the playlist.
Sep 20, 2009 | LG Xenon GR500 Cell Phone
I am trying to hook up my USB so I can download songs i have saved in my computer.the installment process is not working
My sister has one of these, but instead of using a usb cord to the pc she uses a sd card and transfers her songs onto there. I suggest that you get an mircosd card and transfer the songs onto there and then put your microsd card in the slot for your Dare. Let me know how this goes.
Jun 22, 2009 | LG Dare VX9700 Cell Phone
Samsung Rant  Cell Phone Logo
22 people viewed this question
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
