Question about Cakewalk SONAR Home Studio 7 XL for PC
On sonar home studio 6 xl. If i play something i hear only 3 seconds music and than it stops. What can i do?
  • 755 Answers
This sounds like the software still thinks it isn't registered to you.
Do you have a registration button in the program interface?
If you have already registered the program or registration isn't required, try loading Sonar on another box and see if it's just a compability problem with your hardware.
Posted on Dec 11, 2009
Need serial number to sonar home studio 7
It is something you get when you purchase the software. If you have already purchased the software, contact Cakewalk support for assistance.
May 28, 2012 | Cakewalk SONAR Home Studio 7 XL for PC
NOKIA N73 screen shows headset mode on the top right even when not connected to the headset.....so i am not able to hear anything even when i connect the headset it is not responding & i can't hear...
Hi Saik,
I think problem is caused by unplugging the jack before pausing/Stopping the music.
1) Plug in a headset into the jack
2) Open up a media player (either the MP3 player or any online music)
3) Begin to let the music play.
4) Stop the music from playing after a few seconds
5) Completely exit out of the media application.
6) With the headset still plugged in, wait about 15-30 seconds. (this is so that the media/pandora app task can "fully" stop from running)
7) Unplug the headset.
The phone should now be able to emit sound from the earpiece.
If the above does not work, other methods I have read tell you to plug in a headset & play music. While the music is playing, quickly remove & insert the headset into the jack (not too rough so if doesn't break anything) until you hear the music coming out of the speaker.
Finally, if you still have the issue, try rebooting. Turn off the Phone, Remove the battery completely and reinsert after 30 seconds. Turn on the Phone.
Hopefully that should fix the issue.
Jan 01, 2018 | Nokia N73 Music Edition Smartphone
I plug in my usb for the samson studio gt. and no software comes up. but the box says it comes with it. what do I do?
I believe you're referring to the Cakewalk® Sonar LE music production software which should be in the box. If not any recording software will do. Click the link below and go to the page that says "STUDIO GT QUICK START" and follow the instructions.
http://s3.amazonaws.com/samsontech/related_docs/Studio%20GT_OM_ENG_V1.1.pdf
Jan 13, 2011 | Samson Studio GT Active Studio Monitors...
I cant get any output in sonar 6 ahd yes the rack is active im new to sonar just the mixer xenyx xl 1832 usb
Make sure Sonar is set to use the Xenyx for the clock in the audio options pull down menu. It often defaults to your PC soundboard.
Sep 23, 2010 | Behringer Xenyx 1832fx Mixer 18 Input 32...
When I record and listen to playback, I only hear the left side.
This is normal for recording. Even professionals do the same. What you need is to set your input to mono(either hardware or software), or explore your software look for effects like STEREO to MONO with some delay which I prefer for my recording. I did have a good result. Good Luck
Mar 07, 2010 | M-Audio M AUDIO MOBILE PRE - USB MIC...
try downloading AC3 filter
go here:
http://ac3filter.googlecode.com/files/ac3filter_1_63b.exe
download and install that and then tell me what happens?
Dec 11, 2009 | Cakewalk SONAR Home Studio 6 XL Recording...
Stuttering during audio playback in Sonar
The stuttering is caused by excessive CPU usage, in other words: you have too little CPU power to play the file with the inserted synth smoothly. You could try inserting a different synth or play with the rendering-options of the synth (like disabling aliasing, etc.) or increase the audio buffer size (under audio options ?), but the only longterm solution is upgrading to a much faster computer.
Even when you find some tweak which lets you play the file (just) smoothly, adding another effect or synth is likely to cause it to stutter again, since your computer doesn't meet the official (!) minimal requirements for running Cakewalk Sonar 6, which is at least a Pentium 4 1.3GHz computer (and you have a 1.0GHz computer).
I would recommend upgrading your computer to something which at least meets the "recommend requirements" of Cakewalk Sonar 6, which is a Pentium 4 2.8GHz or newer (like any Intel Core 2 system), when you're serious about composing music.
Aug 12, 2009 | Cakewalk SONAR Power Studio 660 Full...
When ever i record there's a constant crackling/hissing in the recording. is this cuz of my sound card?
First are you using onboard sound or an added soundcard? If using onboard then the problem is most likely caused by outdated drivers or underpowered onboard sound. Try checking the software to see if it has any audio cleanup options as using them may help. Hope this helps.
Jul 08, 2009 | Cakewalk SONAR Home Studio 6 XL Recording...
Me and some buddies record with sonar home studio 6 and i bought a new pc custom built for recording well our computers on tha same day and time started having problems with sonar popping and glitching...
Sounds like what is called a latency problem. You need to go into the settings in Sonar and under audio, adjust the Latency to a higher number...I don't know sonar home studio, or I would tell you the exact area to go in the menu's to adjust latency..Hope this helps!
Mar 06, 2009 | Cakewalk SONAR 4 Producer Edition for PC
No sound
Sounds to me like you don't have a bi directional sound card.
It could verywell be your USB driver.
try uninstalling the driver. driver and reboot and let the PC plug and play a generic loaded USB driver.
Possible your sound card or chipset does not support the driver.
goodluck
44hink
Jun 09, 2008 | Cakewalk Computers & Internet
Cakewalk SONAR Home Studio 7 XL for PC  Logo
105 people viewed this question
Top Cakewalk Computers & Internet Experts
Parshiv Luthra
Anbes
Anbes
Are you a Cakewalk Computer and Internet Expert? Answer questions, earn points and help others
