Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Lost horizontal alignment and convergance all at once
Flyback transformer appears to be broken
  • 647 Answers
  • RCA Master
  • 8,617 Answers
You can get a replacement flyback from www.tvrepairworld.com that comes wiith instructions.
Posted on Dec 12, 2009
SOURCE:
So what's a flyback or convergence option ??. Heck, even a stick-figure Diagram might do the trick. It's nice 2 have folks like ya'll sittin' 'round helpin' each-other out
The flyback is the large transformer that has the thick red wire coming out of it. The solder has a tendency to crack slightly which causes the FL231 Fuse to blow ( just to the right of the flyback) When the FL231 fuse blows the convergence option will disappear from the setup menu and the set will appear 3d with an arced picture. I am attaching a pic that shows the Flyback with a white circle, The FL231 is the yellow circled item next to the flyback11_1_2012_11_47_00_pm.jpg
Nov 01, 2012 | RCA Televison & Video
Picture on Samsung TXL2791F gets smaller after a few minuets
The horizontal output transistor that drives the flyback transformer overheats now. There might be other reasons too for this fault. If the flyback transformer has any internal winding short, this transistor will overheat.
Just replace the horizontal output transistor. Check its heat. If the newly replaced transistor too overheats, replace the flyback transformer.
May 24, 2012 | Samsung TXL2791F 27" TV
I have the RCA 52 in hd 5267 can someone tell me where the flyback transformer is located. I see where dave1645 said how to fix the problem of the 3 dimension colors i just dont know heer that stuff is...
Remove the Back panel, Then look to the far left lower board you will see a large transformer with a thick red wire coming out of the top of it. Thats the Flyback. There are three small brown rectanges just to the right side of the flyback. The center one is FL231. When that fuse blows your convergence will go out of alignment and the option will disappear from the menu.
Dec 04, 2009 | RCA HD52W56 52" Rear Projection HDTV
The convergance menue is gone. I need to adjust the convergance badly but it is no longer in the menu
You need to resolder the flyback transformer and replace fuse FL221 off pin 11 of the flyback transformer. The convergence power supply is not coming on so system control thinks a convergence circuit is not installed.
Oct 16, 2009 | RCA D52W23 52" HDTV CRT TV
There is a hissing noise in back of tv and picture goes on and off zenith d36d51
Hissing noise and picture on and off means faulty flyback transformer, it has a small crack and voltage is leaking out, replace the flyback, if tv still not working replace horizontal output transistor (broken flyback could blow the transistor).
Aug 09, 2009 | Zenith D36D51 36" TV
Flyback transformer and horizontal output transistor change out
There is a little loose sleeve at the transformer. It can be pulled out, but it is best to squeeze the sides through hole on each side of the terminal to remove the sleeve. The wire just comes out with a small pull afetr the sleeve is removed. Good luck.
Dec 20, 2008 | RCA Televison & Video
Mitsubishi ws-55859 projection tv with 2-3 error code
did you change the two pico fuses F9A04 and F9A05 when you replaced the Convergence ICs
Sep 25, 2008 | Televison & Video
Still not working after replacing the capacitors
Hi Jim, The problems I have found on these similiar sets are power supply problems and Horizontal transformer ( Flyback transformer ). The clicking I assume you are hearing may be the flyback transformer ( thats the big black transformer with the big red wire along with a couple of other wire coming off it ). The horizontal transistor is sometime the cause of this also, so if you have a transistor, or diode checker, check the horizontal transistor first. If the transistor is bad, it may be an indicatioon the transformer is also bad ( one will burn the other out sometimes). I hope this helps in some matter. Good Luck
Ed
NC Electronic
Mills, Wyoming
Jan 08, 2008 | Mitsubishi WS-65869 65" Rear Projection...
No power
Check the FBT and the Horizontal Output Transistor also.
Sep 18, 2006 | Panasonic TX-15AT1 15" TV
Lamp issues
No its a tube and not a bulb. If thew line is green then theres an issue with the red and blue as the green is stationary on most sets unless thers a green centering ? Its a componet on the convergence board thats bad or going bad but if you replace any components on the board most likly your gonna need to do a convergence alighnment I would let a pro handle this repair unless your an experineced repair tech Good Luck
May 21, 2006 | JVC AV-56WP30 56" Rear Projection...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
97 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
