Question about Coleman Heating & Cooling
I have a 1970's coleman forced air heater and after it is thru heating and shuts off, the blower keeps cycling on and off for a bit afterwards. is this normal? i also noticed that there appears to be some missing wires form the low volt term box. could this be the problem?
  • 1,420 Answers
Your furnace will either have a fan switch that is adjustable or it has a timer. Look for a small box approx 3" x 5" in the upper area of the furnace just below the plenum. If you pop off the cover you should see a round disk with 3 little tabs in a slot on the disk. These taps should be set at 100, 140 and 200. If it is not there you have a timer on the circuit board and there is no adjustment. If it is not bothering you, don't worry about it. Good luck.
Posted on Dec 11, 2009
Coleman evcon model DGAT070BDF
Open hi temp limit switch or fan limit bad
Apr 01, 2014 | Coleman Propane Forced Air Heater...
I have a customer with a evcon direct vent forced hot air furnace. The thermostate calls for heat , the combustion fan comes on then the ignitor lites and the burner comes on for about 2 minutes, jsut...
same thing happened to mine. go on the roof and pull the cap off. mine was rusted thru the inner pipe (exhaust side) letting the exhaust air to get drawn back into the combustion air side. causing it to short cycle or snuff the flame out.
Oct 29, 2011 | Tools & Hardware - Others
Coleman eb15b blower fan will not shut off
Hello, this will be a stuck relay for the blower. Trace wires back from blower motor and it will lead you to the culprit
May 11, 2010 | Coleman Propane Forced Air Heater...
The most common issue with this symptom and unit is a stuck blower relay.
Once the unit is reached temp and the heat elements stop the blower is to shut down when unit cooled. In your case the switchis stuck resulting in continuous fan.
Here is a manual that is real handy for troubleshooting electric funaces.
http://www.nordyne.com/Literature/359a.pdf
Mar 18, 2010 | Coleman Propane Forced Air Heater...
A 1979 Colman RV furnace. Blower shuts off shortly after burner shuts off leaving a hot heat exchanger. After 15 seconds blower comes on again blows for 10 seconds shuts off comes on in 15 seconds blows...
The fan limiting switch is acting up. It should stay running until lower temp is reached. It will cycle until the temp stays below or at the low setting. Limit switches are adjustable.
Jun 09, 2009 | Coleman Propane Forced Air Heater...
Short cycling..continually..minimal heat
Is this furnace standing pilot or electronic? if standing pilot turn power off then take t-stat off wall and connect the wires labeled r and c together and see if that keeps furnace working. If electronic check flame sensor you can check flame sensor buy cleaning with steel wool. if that doesn't work then try t-sat.
Jan 21, 2009 | Coleman Propane Forced Air Heater...
Coleman evcon Dgato7obdc
Small blower motor? Are you talking about the combustion blower if so then check your vents for blockage.. if the vents are blocked won't work... if it has a control board init it will give you a diagnostic code. Flashing light on the board... count the flashes and look up the fault on the chart in your owners manual ot on the furnace door..
Jan 13, 2009 | Coleman Propane Forced Air Heater...
Heating & Cooling Logo
48 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
