Question about Whirlpool Washing Machines
I have a model number LA5599XPW4, Whirlpool Design 2000 washer which has never failed until now. The symptom is that during agitation, the agitator (a single-piece design) moves in one direction only, rather than back and forth. This causes grinding noises and clothes trappage at the agitator base. All the other cycles work fine. During spin, the agitator spins freely as it should, and there is no oil or clutch dust coming out the bottom of the machine.
The machine spin out of control
Posted on Nov 27, 2010
Our whirlpool wtw5100vqo agitator doesn't work I already replaced the agitator dogs
No agitation or spin? try these:
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Transmission or clutch assembly not engaging due to going out or slipping.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Apr 03, 2015 | Whirlpool Washing Machines
My whirlpool duet stacking washer wont spin or drain. i tried to do it manually as described in my owners manual with no luck
Oct 12, 2014 | Whirlpool duet Washing Machines
Whirlpool washer fills sometimes and won't agitate or spin or drain what should i do
Jul 24, 2014 | Whirlpool Washing Machines
Agitator disengages intermittently during washing. During the wash cycle it makes a noise like it's unbalanced. Opening lid to watch washing shows the agitator being engaged in fits and starts. ...
On a Whirlpool manufactured washer, the problem may be very simple, inexpensive and easy to repair.
Whirlpool uses a split agitator design. The upper portion is called the auger, while the bottom is called the agitator. Between these components is a agitator cam assembly. This problem is commonly caused by either worn agitator dogs, a worn agitator cam assembly, or a loose agitator bolt. The following link explains what the dogs are and how to replace them:
http://www.fixya.com/support/r3608577-replacing_agitator_dogs
The part number is included in the link provided. You can purchase replacements at pcappliancerepair.com for about $5. For a little more you can purchase the entire cam replacement kit, which includes the cam, the thrust bearing, and the dogs for about $11 or $12.
NOTE: You can refer to the excellent exploded view parts diagrams the web site has to offer for assistance. Whirlpool also recommends the application of a little grease on the thrust washer. The part number for their recommended grease is AP3098553.
If you have any questions about this repair, please post back with your complete model number (located on a nameplate along the wash tub opening under the lid) and let me know. I hope this helps you.
NOTE: DO NOT overtighten the agitator bolt. This can cause damage to the plastic, or restrict the agitator movement. Tighten until snug only.
Jan 04, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
The top part of the agitator won't turn but the bottom will. what do i do?can i remove the top part and replace a gear?
Whirlpool has a split agitator design. The upper portion is called the auger, while the bottom is called the agitator. Between these components is a agitator cam assembly. This problem is commonly caused by worn agitator dogs or the agitator cam assembly. The following link explains what the dogs are and how to replace them:
The part number is included in the link provided. You can purchase replacements at pcappliancerepair.com for about $5. For a little more you can purchase the entire cam replacement kit, which includes the cam, the thrust bearing, and the dogs for about $11 or $12. IMPORTANT NOTE: The model number you have this question listed under did not have the split agitator design. It used a single piece agitator with a center post cap installed. If you need further assistance in identifying parts, please post back with your complete model number (located along the wash tub rim under the lid).
If you have any questions about this repair, please let me know. I hope this helps you.
Dec 22, 2009 | Whirlpool LSR5132PQ Top Load Washer
Good afternoon - I have a Whirlpool model LSR7233EQ0 washer. The washer works fine in regards to draining, filling, lower agitator works...however, the top agitator does not engage and almost sounds like...
Whirlpool uses a split agitator design. The upper portion is called the auger, while the bottom is called the agitator. Between these components is a agitator cam assembly. This problem is commonly caused by worn agitator dogs or the agitator cam assembly. The following link explains what the dogs are and how to replace them:
The part number is included in the link provided. You can purchase replacements at pcappliancerepair.com for about $5. For a little more you can purchase the entire cam replacement kit, which includes the cam, the thrust bearing, and the dogs. For the model number you have listed, the part number for the kit is 285811 and sells for about $11.
Dec 16, 2009 | Dishwashers
Problem for Whirlpool LXR9445JT Top Load Washer Whirlpool top-loader LSQ9200LQ0 The top half og the agitator is not turning.
Dec 14, 2009 | Whirlpool LXR9445JT Top Load Washer
Bottom part of agitator does not work, i replaced the clutch dogs two weeks ago for the top part. kenmore series 80
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
There are a number of Series 80 design washers. You'll need the actual model number to better check for the problem.
First, I'd remove the top agitator (as you've already done), then I'd remove the main agitator.
Under it you will see a clip and what Whirlpool calls a "washer". The "washer has two prongs, one fits into the main agitator shaft drive and the other fits in the lower agitator. If one or the other of the prongs is broken, the agitator most likely wont. I'd also look inside the main agitator to see if the ridges are broken off.
I'd then start the washer on it's smallest cycle and see if the main agitator shaft turns back and forth. If it doesn't and the washer goes through it's drain and spin cycles, the problem is likely in the transmission itself with what they call the agitate gear and / or agitate cams.
Please see the Whirlpool / Kenmore PDF document on installation, maintenance and operation of direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6?OpenView&Start=1
This is a Whirlpool document with parts lists for their commercial washers (basically the same as the consumer models)
If the problem is in the transmission, although it looks complicated, it really isn't that bad if you have a moderate level of mechanical ability.
Sep 26, 2009 | Kenmore 22422 Top Load Washer
Drum won't spin, drains ok and agitator works fine
http://www.pcappliancerepair.com/model-display.php This site shows your lid switch. Just enter your model number. The lid switch is the usual suspect for your symptom.
May 09, 2009 | Washing Machines
INGLIS WASHER SUPERB AGITATOR DOES NOT WORK
sorry not real solution as I am not familiar with that design but recommend replacing machine.
Jan 31, 2009 | Whirlpool Inglis IP4400 Washer
Washing Machines Logo
447 people viewed this question
Dan Webster
Dan Webster
Sal De
