Question about Panasonic Televison & Video
I have a black square in the corner of my TV and I'm wondering(hoping) its a small problem.
    Problem Solver:
  • 13 Answers
Turn on the 4:3Overdrive feature in the User setting menu. This enables most standard screen........
Posted on Dec 11, 2009
HI, MY TV PCL5415R, HAVE SOUND BUT NO PICTURES SHOW ONLY BIG BLACK SQUARE
Set would seem to be either in PIP (picture in picture multiple mode) or the black box might be the TEXT feature which is found in the closed caption menu.
Nov 04, 2012 | Samsung PCL5415R TV
HP LaserJet M4345 - The printer display is mangled, the touch screen does not respond properly to commands. Is there a way to reset it?
Calibrate the control panel
Use the following procedure to calibrate the control panel:
1. Turn the device off.
2. Press and hold the # key and the C key.
3. Turn the device on.
4. When a small white square appears in the upper-left corner of the control-panel display, touch
the square with a stylus.
5. When a small white square appears in the lower-left corner of the control-panel display, touch
6. Allow the device to finish the boot process.
Hope this helps.
Jan 25, 2011 | HP LaserJet M4345 MultiFunction Printer
I turn on the calculator and all I get is a small black square dot in the upper left corner. TO Connect can read the unit, but nothing works on the display.
If the small black square does not blink The Calculator is Locked
it need an hardware reset
let me know if you if you want to fix the Calculator
ecrdn@yahoo.com
Jack
Oct 21, 2010 | Texas Instruments TI-84 Plus Calculator
I have a black square in the top left corner
Check to see if your TV has the "P-I-P or picture in picture" option. It may be activated, and set to a channel that has no reception. Hope this helps.
Apr 09, 2010 | Philips Magnavox 27MS343S 27" TV
Vertical lines/black squares all throughout this 50" TV. Is it worth fixing?
I have 5 vertical black bars coming down halfway on the screen. Also 1 black square that appears on the lower half corner of the screen. What can I do to get them off? Please respond or call me @(510)938-6237 Shon Thanx!!!
Dec 27, 2009 | Mitsubishi PD-5010 50 in. Plasma...
Have a black box in the top left corner of tv how can I get
check and see if your tv has PIP (picture in Picture) which you turn on and off with the remote. If you do you have PIP turned on, but not set to any station.
Nov 30, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
Dlp tv has smattering of white (and just a few black) squares in upper right hand corner. Thick at corner then thining as spreads. Covers1/4 of picture. The rest of the picture is perfect.
You have a bad DMD board. It is easily replaced but not easily aligned. I would suggest having a technician look at the TV. The DMD board is the board with the million little mirros on it. The white squares indicate a few mirrors sticking in the on position reflecting the light from the lamp constantly. The black are just the opposite reflecting no light at all.
Oct 17, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Small black square in top left...won't turn off
You should replace the AAA batteries with new ones, and should by a new set of back up batteries.
Aug 23, 2007 | Texas Instruments TI-83 Plus Calculator
Remote wont work TV goes off by itself
Hello, please take the batteries out from the remote. Best regards, Arpi
Jun 23, 2007 | Sony FD Trinitron WEGA KV-27FS200 27" TV
Black Square Covers 80% of screen on most channels on TV
have your tv checked by a tech.probably your chip the eprom needs to be reset by lifting it up from the board and resolder back.some one could have put in a code for those channel.good luck.
Dec 27, 2006 | Toshiba CF35E50 35" TV
Televison & Video Logo
111 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
