Question about Motorola Talkabout T5950 (7 Channels) 2-Way Radio
One talkabout works when i talk into it, but when i talk into the other one, the speaker of the first one does not say anything. just some skiping static noise sounds like mic is bad
It's very damaged!
Posted on Feb 17, 2010
What frequency does my motorola talkabout have
If they're all set to the same "Channel" and "Code" you will be able to talk between them.
Apr 15, 2014 | Motorola Talkabout T5300 (14 Channels)...
TalkAbout MR350 not hear Talk About MD200
Check your CODE settings. From your description you likely have the CODE set to a different number on the MR350 than the MD200. I would guess the MD200 is set to zero since you can hear the MR350 when it transmits. Set your codes to match one another, and turn off any special features such as call alert or Qt filtering.
Ordinarily I would post links to the user guides, but FixYa seems to be having a problem with this feature today. If you need the user guides visit giantintl dot com website.
Best regards.
May 22, 2013 | Motorola MR350 Two Way Radio
Sends transmission okay but, even with volume set high it receives faintly.
You have one of three problems:
1) You are using the radio with another model of radio which is set to wideband channel spacing. (The TalkAbout is narrowband.)
2) You have a radio with a problem. (bad speaker, or plugged speaker grill possibly, or an internal issue)
3) The transmitting radio has a problem, or has debris or something covering the mic hole.
The only way to narrow down the problem is to have a third known good radio in the mix. This will let you know which radio is problematic. The TalkAbout models are for the most part non-repairable (other than the TalkAbout Distance models and the T7200 and T7400.)
Nov 07, 2009 | Motorola Talkabout T6220 (14 Channels)...
Hi, i bought a Motorola CP200 radio and realised that it didnt work with my Motorola Talk-abouts! now i know that there is a programming that i need to operate with!!! so my question is....how can i know...
Take it too radio-shack and ask the salesman to try out a frequency meter to get the freq. you can get programming help by contacting motorola direct...1-800-638-5119
Aug 23, 2009 | Motorola CLS 1110 (1 Channel) 2-Way Radio
One radio not recieving
You need to check your interference eliminator code. It sounds like they are not set to the same code. Also, if your radio has a Qt filter, set it to zero.
Here's a link to the manual http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T5300_T5400_User_Manual_E.pdf
Aug 11, 2009 | Motorola Talkabout T5400 (14 Channels)...
1 talkabout not working
Check the programming of the channel, interference eliminator and the Qt filter. These must match on both radios. Here is a link to the user manual to assist you: http://direct.motorola.com/ENS/T5920_T5950%20User%20Manual.pdf
Feb 17, 2009 | Motorola Talkabout T5950 (7 Channels)...
I get static after someone else talks
One of the main causes of static can be a bad battery. If you are using rechargeable batteries you need to replace them every 14-18 months. If you are using alkaline batteries, they have been known not to fully power the radio once your cross the 10 hour mark. Your radio would then be operating in somewhat of a brown out. This would lead to static.
Another cause of static is simply being nearly out of range of the other radio(s).
The burst of white noise at the end of Rx on some radios can be rather annoying. On the basic talkabout radios there is nothing which can be done to solve the problem, other than replacing the radio.
Jul 26, 2008 | Motorola Talkabout T5700 AA (22 Channels)...
The talkabout t5500 and the t5725
Hello bella-9,
The T5500 is a 2 channel radio and the T5725 is a 14 channel radio. However, the radios should be compatible with each other on FRS channels 1-14 as long as both radios are using the same Quiet Talk code. If the Quiet Talk settings are different the radios will not be able to communicate with one another.
Assuming all settings are the same (as you say) and the units are within range of each other (typically less then a mile over clear, level terrain) they should work just fine.
Best Regards,
Ken
"Go Ahead. Use Us."
Jul 16, 2008 | Motorola Talkabout T5720 (7 Channels)...
Motorola Speaker
to dissamble this radio you have to remove the face panel, under this face panel ( the blue one) you will find others screws. first of all try if you have an audio accesorie, with this earbund or head set the audio must be normal or the same quality than the other one, if is not, the radio need quilified service. Good luck Ernesto
May 06, 2007 | Motorola Talkabout T5720 (7 Channels)...
T5000 have a lot of static!
I think if you canĀ“t undestand what the other person is sayin, and you think is working fine, the problem could be at the speaker, check if the speaker is clear of dirty or sand or any thing that has not to be there. If you find any dirty or sand on you speaker, try to clean with a brush and giving some little knocks with a piece of steel Good luck
Nov 13, 2006 | Motorola TalkAbout T5000 2-Way Radio
Motorola Talkabout T5950 (7 Channels) 2-Way Radio Logo
181 people viewed this question
Top Motorola Radio Communications Experts
Steve
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
