Question about Toshiba TLP-710, TLP-711, TLP-G5, TLP-G7 Projector Lamp - TLP-L3 Projector Lamp
Need a tdp t90a lamp driver module board where can i get one and price - in australia
I am having the same issue, Were you able to aquire a lamp driver module for your projector?
Posted on Feb 10, 2010
I have a toshiba TDP-S3 projector. When it powers on the LED is green after about 10 minutes, the lamp goes out and the LED flashes orange. What could be causing this? The lamp is new. Thank you.
Sounds like overheating. The dust filters by the lamp module may be clogged. You have to remove the lamp and clean them as noted in the user manual. If you don't have the manual you can search for it on line. They suggest using compressed air and isopropyl alcohol to clean these filters. Of course, the blowers also need to be operating and external input and output vents not blocked or restricted.
Feb 08, 2011 | Toshiba TDP S3 Multimedia Projector
It suddenly stoped playing clearly. i can see some extremelly pale picture.my lamp is around 2000 hrs the projector is a 2004 model toshiba TDP-D2.any ideas?thanks panos
You need a new lamp. You can purchase one at:
http://www.shopvsc.com/Toshiba-Replacement-Projector-Lamps-s/143603.htm?searching=Y&sort=7&cat=143603&show=50&page=1&f-TDP%20D2=143381
Oct 25, 2010 | Toshiba TDP-D2 Projector Lamp
Toshiba TDP-T45 projector, groups of vertical lines across entire screen. Someone said try setup frequency to someone else with same problem but that person said it didn't work, then someone said replace...
the tube referred to is the light tunnel. which in your case is not the problem. unfortunately the only thing you can do is give it a good slap on the top 3 inches behind the lens for an unlikely long term fix, or try reseating the main board to the light engine. if neither work then the main board or the light engine is bad.
Aug 07, 2010 | Toshiba TDP-T45U DLP Projector
How to change toshiba TDP-S35 lens
i got a problem with my projector, the colored break up into pieces, i want to know if how much is the price to repair it.
Mar 19, 2009 | Toshiba TDP-S35 DLP Projector
HOW TO RESET TOSHIBA TDP-S8 LAMP
after installing the new lamp, hold the volume top & bottom key simulteniously, when green light indicate at panel start the projector & go to service there you may found reset lamp ? press yes the lamp will reset.
Feb 01, 2009 | Toshiba TDP-S8 Multimedia Projector
Fan indicator red light help
red light means lamp is shot. try BULBMAN.COM or BestBuy.COM for a new lamp at a good price.
Jan 08, 2008 | Toshiba TDP-S20U Multimedia Projector
Toshiba TDP-S20 lamp problem
The lamp ballast which ignites the lamp has failed it sounds like. The red flashing lamp is the tell tale sign with a good lamp installed. Make sure the lamp door is closed too, there is a door switch that can also trigger the red lamp and no startup. There is a company in San Diego CA that can repair the unit called PROJECTOR DOCTOR
Nov 29, 2007 | Toshiba TDP-S20U Multimedia Projector
Toshiba projector TDP-T30
i have the same one but it needs a new lamp i will buy one of your lamps off of you let me know a price
Nov 12, 2007 | Toshiba TDP-T30U Multimedia Projector
Projector Lamps for the Toshiba TDP-MT8 DLP
Have you contacted Toshiba? They will sell you a new fan. It is possible the power supply has a problem. Bulbs usually have a 90 day warranty. Contact where you bought the bulb. Prices are dropping rapidly for new projectors. Yoiu can buy a new oen for under 500.00.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Aug 07, 2007 | Toshiba TDP-MT8 DLP High Definition Home...
100 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
