Question about RIM BlackBerry Storm 9530 Smartphone
Esc button and end button stops working when you check text messages on blackberry storm
I bought a blackberry storm 9530 on amazone. Its unlocked because i am in netherlands antilles and can make and receive calls and text messages but i cant browse the web or use BBM. I think Verizon has it...
Seems like your phone network is locked which needs to be unlocked. This can be done through Blackberry unlocking codes with IMEI. You can unlock your Blackberry Storm 9530 from them since they provide trusted and affordable codes to all their clients. i hope this would help.
Jul 29, 2011 | RIM BlackBerry Storm 9530 Smartphone
I have an unlocked blackberry storm with tmobile service, and all of a sudden i get absolutely no service. It says SOS in the top right corner. Everything else on the phone works besides the mobile...
I think you entered wrong blackberry storm 9530 unlock code and your phone on hardlock state. You only have one option left to fix that, bring your blackberry phone to nearest local mobile repair shop and asking them to doing cable unlock. You will not need any blackberry unlock code again after that process.
Mar 14, 2011 | RIM BlackBerry Storm 9530 Smartphone
On my blackberry storm, the touch screen i snot working properly, the buttons are not pressing, I spend hours try to send a text or make a phone call. Please help me to solve this problem. Do I have to buy...
Hello.
First, remove the back of the Storm. Then, remove and reinsert the battery. Return the back cover.
My Storm locks up periodically and that solution solves my problem.
Hope it solves yours.
Dec 21, 2010 | RIM BlackBerry Storm 9530 Smartphone
My blackberry plays music after i end a call or
Pull out the battery that is what i do until it does it again.
May 03, 2010 | RIM BlackBerry? Tour 9630 Smartphone
How do I transfer messages off my blackberry? (storm 9530)
Use your bb desktop software to make a backup onto your PC. It will make 2 files, with today's date, one a .cab which contains media files (eg photos you took) and the other, an .ipd contains encapsulated application data.
The contents of email are in in the .ipd file, in bare text html format. Suggest taking a copy of the .ipd file first, then open the copy in your favourite text editor. Notepad is OK; I use EditPad Lite. Then do a text search for "<html" (without the trailing ">") to find the first email message. You can copy the html between <html ...> and </html>, paste into a new text file, edit if you want, and save as SomeFileName.html, then open in your browser to see it.
Between each email is some binary info that would be used by the blackberry. Don't know how to decode this.
Some emails are text only. SMS messages are in there too - can search for the text you know is in one of them, to find them all together, the message itself is bare text.
I like helping people with blackberry, because I learn useful things for my own use. Just found this product, shareware for about US$20 after 30 day demo trial:
http://www.processtext.com/abcblackberry.html
Handles IPD files.
Sep 11, 2009 | RIM BlackBerry Storm 9530 Smartphone
My Send & Escape buttons wont work on my Blackberry Storm
Try taking the battery out for about 30 seconds then turning it back on. If that doesn't work, try running on air programming if that is available to you. Check with your customer service for that.
Jun 11, 2009 | RIM BlackBerry Storm 9530 Smartphone
Outgoing SMS Text Problems
check the blackberry fqa.com you will find your answer easy
Jun 01, 2009 | RIM BlackBerry Storm 9530 Smartphone
Text message options
none. you can send an email to a phone number which by send to adx: xxxxxxxxxx@vtext.com (Xs' are the area code and phone number) the person will have to recieve two messages. there is a limit to the length of each sms(text) message (i think it is 164 characters)
May 07, 2009 | RIM BlackBerry Storm 9530 Smartphone
I cant get into my text messages on my BB Storm?
My name is Maureen Uwechia.
I had the same problem but I was able to find a way round it. I switched off the phone (blackberry storm), removed my sim, put the sim back after some minutes and put on the phone. Simple!! It worked.
Apr 27, 2009 | RIM BlackBerry Storm 9530 Smartphone
Downloading Text Messages on my Blackberry Storm
No, you can't do this. The BlackBerry stores your text messages in a database file that isn't compatible with anything other than itself. The only way to get your texts off of the device (in any kind of read-able format), is to forward them to another phone.
Mar 07, 2009 | RIM BlackBerry Storm 9530 Smartphone
RIM BlackBerry Storm 9530 Smartphone Logo
105 people viewed this question
Top RIM Cell Phones Experts
ismael castillo
George Etukudo
George Etukudo
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
