Question about Crosley 1950 Pay Phone
Do not have the key
Got mine at PB awhile ago and do not have the key to open the bottom. is there parts for this phone
  • Crosley Master
  • 2,460 Answers
The company has a website and a question tab http://www.retroshowroom.com/IVG2/N/ProductID-64503.htm
Posted on Mar 29, 2010
1990 ford f-150,,300 six. the bottom bolt on the alternator snapped off during removal,now i cant get it off and cant get to the bracket bolts either,,,any ideas?
Spray the bolt with PB Blaster a few times and let it sit for awhile. Use a screw extractor on the broken shaft.
Nov 16, 2014 | 1990 Ford F150
Top latch won't latch to the bottom when closing
Try using the truck lid key to reset the top latch...use the key to release/open the trunk...also try using the inside trunk release to reset the top latch...also spray some PB Blaster on both the latch, and the catch...hope this helps.
Jun 06, 2014 | 1995 Cadillac Fleetwood
Key wont turn
Try spraying some PB Blastor directly on the key before inserting...also spray with the fine tube a little PB Blastor into the ignition switch...this is safe for electrical parts...wiggle and retry...Your local locksmith can replace the key switch for you...the air bag usually prohibits self repair...:( You can buy the PB Blastor at Walmart and auto stores...
Jun 04, 2014 | 2000 Oldsmobile Bravada
E522B - About 6 mths ago, a the clip on the bottom hinge of the freezer door broke into two , depositing the one end on the kitchen floor . Fridge seemed to operate OK regardless. Today, the same clip on...
I know this thread is super-dead. Mine broke off a while ago and it means the door doesn't stop until it is 180 degrees open. The bit that broke off is the door-stop part of the lower hinge.
I just put this here in case it helps someone else stumbling upon this thread as I did.
As far as I can tell, the part is available somewhere. I am off to find out where, next...
Aug 14, 2012 | Fisher and Paykel Active Smart E522B...
Pitch automatically bends when i play even without me touching the pb wheel
The resting (centering) of the PB wheel has a problem. It is LIKELY mechanical in nature. You will have to open the unit to investigate or take in for servicing. If you open it yourself, have two people to help hold the two parts of the shell to avoid damaging the ribbon cables when opening.
Mar 12, 2011 | M-Audio ProKeys Sono 61-Key Portable...
My father purchased fish tycoon awhile ago and gve me the code, since then we have gotten new computers and have lost the unlock key. How can i recover the unclock key?
Contact the Software Manufacturer & provide with information in which they will be able to trace back and find your original registration details :-).
Nov 07, 2010 | Nokia 5230 Cell Phone
I have a 1999 VW Beetle, and the interior lights come on when the passenger door is opened, but not when the drivers door is opened. Where's the switch?
ah, This is a very common VW issue. Hopefully yours is just gunked up like mine was. i just fixed mine today. here's how...
1. open drivers door, put key in ignition and turn to "run" position (this so you can hear the dinger)
2. trip the latch in the door so it clicks TWICE locked, you'll see.
3. now at the bottom of the latch there is a void you've exposed. Get a Can of contact cleaner, or brakecleaner and HOSE under the latch piece. I mean firehose the hell out of it for a bit, then open and close the door a dozen times or so to work the latch.
4. Repeat as necessary. Plan to use up at least half a can. I had it running out of the door drains. Hopefully this frees up the gunk that probably has built up.
5. Regardless if this does work or not, finish up with something like a few good shots of PB Blaster, WD 40, or some light lubricant. Maybe it will work free over the next day or so.
If this unfortunatly doesn't do the trick the switch might be physically broken. Either spend $170 on a new one or google '$3 vw door fix' if you feel like MacGyver.
Dec 28, 2009 | 1999 Volkswagen Beetle
TRUNK WILL NOT OPEN WTH KEY OR INSIDE SWITCH
if it does not open with inside switch it may have a blown fuse stop by any Walmart or auto part store and get your hands on a can of PB-blast and spray some in the key hold and use the key and once you get it open then you can see if your pull down motor is bad wish you the best of luck Michigan Man.
Dec 09, 2009 | 1995 Cadillac DeVille
LG ENV2 shutting off
I just got mine a few weeks ago and it does the same exact thing (I didn't drop it, there is no water damage, I didn't understand the cause of it). I took it back to the Verizon store and I was told that the random shutting off like that is caused by having the phone outside being exposed to heat. He reset my phone back to factory settings and that did the trick for awhile (its hard for me to go to the pool and not have my phone exposed to the heat). There is no charge for them to reset the phone. Mine has started the random shutting off again back up
Jun 03, 2009 | LG enV VX9900 Cellular Phone
Crosley 1950 Pay Phone Logo
64 people viewed this question
Top Crosley Lands Phones Experts
Lisa Demont
Lisa Demont
Level 1 Expert
Are you a Crosley Lands Phone Expert? Answer questions, earn points and help others
