My Roland kr-5 digital piano has the touch screen but over the last yr has gradually faded so I cannot see what is on the screen unless I bend right down on an angle and even then it is very hard to make out. Do I need the just replace the screen. Is that possible?
  • 4 Answers
Probably wont need a new screen, its probably got led backlights in this is the case these may of been dying, take out the screen and if you can see leds switch it on and see if the leds light up, if now just replace them.
If it uses a bulb in the screen then you can try to get a replacement bulb or just get the whole screen.
There is a slight chance that it could be the backlight circuit in which case changing the backlight/screen wont help.
If you have a multimeter test that the backlight for voltage, to make sure it not the backlight power supply
Posted on Dec 11, 2009
SOURCE:
My Roland KR-03 Piano has bad static sound on the left speaker. It is also in the headphones.
seems to me this will need more than most people can do. tracking down the problem will require a lot of testing of transistors and such... but just maybe it's nothing more than a loose ground wire on the circuit that powers that side. Good luck.
Jan 08, 2018 | Roland Music
I have a Roland KR 4500 Digital Piano and I brought it to the local authorized Roland Service Center here in the Detroit area. Apparently the capacitors on the motherboard leaked and the board is tot
You can sometimes clean up the board with a cotton swab and some alcohol. Trace the lines for continuity with a multimeter making sure there are no breaks. Get the information on the capacitors and buy them at an electronic parts store. Replace them or have a professional do it. If all fails, sell it for parts.
Jan 14, 2012 | Yamaha Music
Keys on yamaha digital piano are sounding more than one note at a time how can i fix this?
The keypads can develop dirt , failure of pads which can result in such malfunctioning. If you are able to open the piano then carefully remove the keypads , clean the surface and reset.
this must solve the issue unless the pads/springs/mechanism are having fault.
Jul 05, 2011 | Roland Hp337 Digital Piano
Hi where can i get a service manual for an fp-8 roland digital piano?
Here's a link to the Owner's Manual
for a service manual, you're probably going to have to contact Roland directly, since they don't even list the fp-8 on their website. Service manuals for their other products only run about five bucks for a hard copy, i believe. I'm sure you can get to the right place through here: http://www.rolandus.com/corporate/contact_us/
Mar 19, 2011 | Roland Digital Piano FP4 Black With Stand...
I have a Roland FP 1 digital piano, serial #AL21141N. It has gradually quit putting out sound through the speakers. At the onset of the problem, I could fit it by jiggling the 1/4" speaker plugs,...
I first would suspect the switches on the eadphone jack. Normally these cut off the speakers when headphones are plugged in. These jacks and the switches are really weak, poorly made, and easily broken, especially if headphone cord gets yanked.
Jan 14, 2011 | Roland Digital Piano FP4 Black With Stand...
My Roland KR 650 digital piano, amplifier has a load hum and will not play.
smd elkos on the mainboard is defective 10uF16V and 3,3uF types
Aug 23, 2010 | Audio Players & Recorders
I have a Roland HP 101 digital piano however certain dont sound
White spirit is NOT what you should use. Mineral spirit leaves a residue film.
Use 99% isoprophyl alcohol.
ALSO inspect the contactboard for cracks by candeling with bright light behind it.
Oct 31, 2009 | Yamaha NP 30 76 Key Lightweight Digital...
Roland KR-5500 digital piano When it warms up it begins to crackle and it smells like an electrical problem. I need a manual on the steps to properly remove the outer case to get inside to the electronics....
Unless you are skilled at electronics troubleshooting, you would probably be better off taking it in to be repaired. It might be the power transformer or a filter capacitor or a number of other things. The problem may not even be visible. You will definitely need a schematic and some test equipment. Try this site:http://www.vintageplanet.nl/ or this site:http://www.rangeraudio.com/stock16.htm
Oct 15, 2009 | Music
I have a Roland HP 2e digital piano - Foot pedal problem
The ROLAND pianos USUALLY require that you use a normally closed sustain pedal.
MANY pedals are the opposite and close when pressed. SOMETIMES you can open the pedal and reverse the way the switch works.
Oct 05, 2009 | Roland Music
Need a manual
To download manuals Roland requires you to register. Go to:
http://backstage.rolandus.com/login.php
Create a new profile, then login to download the manual you need.
Thanks for using Fixya.
Apr 16, 2009 | Computers & Internet
Computers & Internet Logo
147 people viewed this question
Alun Cox
k24674
