Question about HP Expresscard TV Tuner For Windows Vista (RM436AA#ABA)
Hp express card digital/analog TV tuner signal
When I turned off my laptop HP Pavilion dv9575la, the TV signal or configuration from HP Express Card Analog/Digital TV Tuner is out, doesn't work. I have elimante the hardware and reinstall again. After this I have run the Media Centar configuration again and ready. How I can mantain the configuration when I turn off my laptop, or when I turn off Media center???
  • 4 more comments
  • Anonymous Mar 17, 2008
    I have the same problem.
  • jjdaza Mar 27, 2008
    I have the same problem. Please helpme, i have a Hp dv6253cl Notebook oc. Thanks
  • rydious Apr 02, 2008
    I have the same problem, have to uninstall, restart and reinstall everytime i want to use the tuner card.
    Any workaround so far?
  • edson7 May 19, 2008
    Tengo el mismo problema, alguien tiene idea, no encuentro soporte en hp
  • aais94 Aug 10, 2008
    HP Pavilion 9575la
    When I purchased the notebook, i saw TV with no problem once, then the next time I want to do the same, never more it function.
    One year later, i have to use the 'Recovery' to clean trash, and it function again, but only once again. and never more-
    Somoeone knows how to fix that problem. Who respond? HP?
    jack Village 673
  • Anonymous Sep 26, 2008
    No signal at all very little support from hp.
I think the problem is with windows Vista. I've been having the same problem also with other things on my laptop also on my disk top. Vista at times won't save the setings. I may just install Windows XP and see what happens.
Posted on May 23, 2008
Tambien tengo el mismo problema. Por favor alguien que hay superado este problema??
Posted on May 19, 2008
  • 3 Answers
I ahve the same issue.
Posted on Jan 22, 2008
How do i connect FM to a SAA7130 T.V card
The SAA7130HL card does NOT support FM radio. I own this same card. You would have to get either model SAA7133HL or SAA7135HL to receive FM radio. I don't know where you could purchase either one of these cards manufactured by Pinnacle.
I purchased the PCTV Systems model 800i HD Digital and Analog TV + FM radio card so I could capture digital TV signals and listen to FM radio, and I have installed both cards in my computer. Amazon has the 800i card for $63.78 for Win XP and Win 7 systems with a regular PCI slot:
Pinnacle PCTV HD PCI Card 23040
Amazon also has an Asus Digital TV/FM card for $18.99 for Win 7 and Win 8 with a spare PCI - Express slot:
Asus PCI Express Television Tuner MY CINEMA EHC3 150 NAQ FM AV RC
I hope this helps you.
Jan 31, 2015 | Philips SAA7130 TV Tuner/FM Radio/Video...
Tip
HP Express Card Digital / Analog not working
First thing I tried to do was to install the drivers that came into the CD didn't work, just using mydvd9 the import/aqcuire option I could have some noise signal, but couldn't find a way to select channels and hanged after a while. This is too trickier, I thought, it should be a way to used quickplay and other applications.
I couldn't get anything from HP site so investigating I found the following.
1) Had to upgrade quickplay to latest version (is pretty cool btw)
2) The card internally is a Hauppage and found that is actually the HVR1500 http://www.hauppauge.com/site/products/data_hvr1500.html.
Drivers + application can be downloaded at http://www.hauppauge.com/site/support/support_hvr1250.html
3) After upgrading quickplay and installing drivers and application from hauppage, Quick play had additionally an hp digital tv tuner entry, but here in canada there is no digital signal transmitted through antenna.
4) I have reinstalled manually the drivers that came in the CD, but from the c:\swsetup\HP Digital tv tuner folder
5) After this I had at quickplay a second source "Hp Analog Tv tuner" which allowed me to caputure the regular air signal and wintv worked as well
I'm sure that I did some redundant steps, but it worked and now can I have everything working (quickplay, wintv, digital, analog signals)
Hope this helps and btw I haev uploaded the manuals for thouse who can't get it, since HP doesn't have them in the website.
Cheers
Alejandro
on Feb 08, 2008 | HP Expresscard TV Tuner For Windows Vista...
Media center won't connect to analog TV signal
If my memory serves me correctly, you need vista pro. home just isn't powerful enough and not made for it.
Jun 01, 2009 | Microsoft Windows Vista Home Premium with...
Connecting and recording camera with s video output on 1221 tx
Your laptop has Tv Tuner card and if it takes TV input via cable , you get a S-Video / DVD cable to regular cable converter and use the laptop as a video recorder - if you are in US , any Radio Shack will be able to help you with the cables
May 17, 2009 | HP Pavilion dv6000z Notebook
HP pc with built-in tv tuner
Have 9, 5 and 13 turned entirely digital as yet, so as to leave you without their signal?
From what you say, the tv tuner in your HP receives analog signals better than or instead of digital signals the stations you can receive may be analog while 9, 5, and 13 may have dispensed with their analog transmitters.
They don't have to until June, since the changeover was delayed from the original February cutoff date by Act of Congress. It is actually easier to receive a digital signal than an equally powered analog equivalent so the fact that your system worked so well with analog signals bodes well for the efficiency of your indoor antenna arrangement, though you may have to replace the possibly analog receiver in your pc with a usb digital thumbdrive like model to continue after the changeover is final.
Here's a tip...if the receiver in your pc resembles a square aluminum tin can, mounted on a PCI card in one of your slots, it is very likely analog and not digital.
Usually these receivers (or actually TUNERS) are heavily sheilded while digital receivers do not require the same amount of sheilding to avoid interference with other components, which is the concept of the big square tin can, that a digital tuner does not require.
Mar 27, 2009 | Computers & Internet
Tv tuner option
If are talking about the Express Card slot into which the ExpressCard TVTuners are installed, it should be located on the Left side of the Notebook.
Please go through page number 18 of 266 in the Manual of the Notebook which is available through the link below which shows you the exact location of the Slot :
http://h10032.www1.hp.com/ctg/Manual/c00530488.pdf
By the way, HP no more sells the ExpressCard TV Tuner Cards in HP Shopping.
Only USB TV Tuner Cards are available from HP.
However, you should be able to find Express Card TV Tuner Cards from other Manufacturers.
Hope this helps...
Mar 06, 2009 | HP Pavilion dv4000 Notebook
Catching one Channel Only
A TV card probably wont be able to tune it in...or decode(decrypt) it for that matter. Is a CableTv set top box plugged in? (the box your cable company supplies you with) -damian
May 01, 2008 | HP Expresscard TV Tuner For Windows Vista...
HP ExpressCard Pavilion Notebook
its definitely something you did.
theres a way to wipe system back to original pn hp screen.. F10.. that might fix..
if it dont. then bios is the issue.
Dec 20, 2007 | HP Expresscard TV Tuner For Windows Vista...
HP Expresscard TV Tuner For Windows Vista (RM436AA#ABA) Logo
843 people viewed this question
Top HP Televison & Video Experts
Computer Links
vbalag
Level 1 Expert
Alun Cox
Are you a HP Televison and Video Expert? Answer questions, earn points and help others
