Question about Freezers
Layer of ice forming on bottom inside of freezer - Samsung fridge freezer
  • 4 more comments
  • Anonymous Apr 04, 2008
    drain tube stops up and ice forms on floor of freezer
  • sedgemoor May 07, 2008
    Water leaking into the bottom of my side by side freezer and freezing this is not the problem identifying where the water is coming from and how to fix it is.
  • otterlake May 29, 2008
    Ice forms at the bottom of the freezer floor and seems to come from a vent near the back wall.
  • Anonymous Jun 04, 2008
    1. ice forming at bottom of freezer compartment
    2. called engineer,now whole fridge not working
    3. sensors changed ,pcb changed,5weeks withouy fridge freezer now
    4. samsung model rl39wbns
    5. layer of ice forming will be from drain pipe blocking up,try putting a thin piece of copper wire round heating element down pipe this will heat up when on defrost cycle and keep drain pipe clear
  • Anonymous Mar 24, 2014
    fine ice droplets forming on back of fridge compartment. what should I do?
  • Anonymous Mar 28, 2014
    Puddles of water form in the bottom of the fridge section of my Defy C250 fridge/freezer combo
    Problem Solver:
  • 11 Answers
Might have the temperature too high .. buy a freezer thermometer and place in freezer
Posted on Jan 25, 2008
Why is ice forming under the bottom drawer of my Samsung American fridge freezer Rsa1shpn and then water eventually leaking out the door? I have defrosted the fridge freezer but still have the problem
There is a drain tube located under the panel of most freezers. If that clogs up, the auto defrost can't work. The freezer defrosts by evaporating all the moisture out of the compartment. So, check that first. Secondly, a leaky door seal can also cause that problem. You can order door seals online or on Amazon.
Oct 17, 2014 | Samsung Freezers
Why do I have ice buildup on freezer floor of my samsung?
Check for a clogged drain line. Snake out and get some vinegar in there. Any water collecting from the defrost cycle is supposed to be led away and outside from the unit
Sep 04, 2017 | Freezers
Ice forming at bottom of Daewoo freezer. How do I fix this
Look on the back of the unit for a plastic hose coming out the bottom to a drain pan usually sat on top of the compressor. Bend a straw and push up inside. If it won;t go, there is a blockage, usually ice in the drain. Fully defrost the freezer and blow through the straw until clear.
Apr 28, 2012 | Daewoo Freezers
Sheet of ice forms in bottom of freezer
Frost free fidges are supposed to stay frost free because the automatically defrost regularly. When they do this they may drain water down to the bottom of your fridge. Look for a tray that catches this water underneath the unit. Make sure yo keep it emptied. If you live in a very warm climate you may be getting a lot of humidity inside. There may be a switch that you can change for lower moisture.
Jul 01, 2009 | Freezers
My Bosch frostfree fridge freezer keeps icing up!
My Bosch Frost Free Fridge Freezer did the same thing - Ice forming in the bottom of the freezer area after a few days.
It was caused by a blocked drain pipe - When the freezer does the de-frosting cycle, the melted ice drips into a tray and tehn runs into a dish on top of teh compressor, through a pipe.
If this pipe gets blocked, the de frosted ice overflows from the tray and overflows into the bottom of the freezer and then re-freezes !
To fix, pull the freezer away form the wall, locate the pipe that runs to the dish on top of the compressor and blow through it - This should clear it. Alternatively, from inside the freezer compartment, pull off the cover at the back, but the clips holding it on will probably break off, as mine did ! You can sort of push the cover back on and re-fit the food draws.
Feb 23, 2009 | Freezers
Sears Coldspot 17 frostless freezer not defrosting
One reason for the fan running is that it is trying to distribute the air in the compartment. Look at the very rear of the freezer on the bottom and see if the little vents, which allow water to disperse, are not filled with frozen ice. If so, turn off the fridge (unplug it) and use a hair dryer to melt that ice until it is all gone. That will probably fill the condensation pan under the unit and you'll need to empty it.
Feb 01, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Drain freezes and glacier forms inside bottom
hi thanks for the question the drain hose leading from the freezer is clogged up remove the ice from the bottom pull fridge from wall find small drain tube clean the tube now it will drain into tray vacuum out while your there thanks the appliance doc
Sep 23, 2008 | Maytag Freezer MQU2057
LG frost free fridge freezer GR-359sq
defrost drain is blocked - probably with ice. take the back panel off inside the freezer and melt the ice off with a hairdryer then follow up with hot water till it flows away freely. this takes some patience. if fault reoccurs then get back to me
Aug 27, 2008 | Freezers
Freezers Logo
1,083 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
