Question about Sony Grand WEGA KDF-55XS955 55" Rear Projection HDTV
What is the sequence of buttons to press on the remote control of my Sony Wega to see how many hours are on the lamp?
I purchased an online service manual, downloaded it and fixed my problem.
Posted on Dec 12, 2009
How do I reset the Lamp Timer on a Sony Wega KF-50WE620 TV?
Hello.
if you want to reset lamp timer on sony grand wega 50WE620...press menu on remote control then go to the setting you will find the setup button then press setup you will see the lamp replacement-start----yes and menu...
Thanks for using fixya
Caseytech
Jun 29, 2011 | Sony Grand WEGA KF-50WE620 Television
I have a Sony VPL-CX61 Multimedia Projector. I just changed the lamp and I cannot get the "please replace lamp" message to go off.
When you use a projector it automatically keeps a timer of how long the lamp has been used for. The message that comes up on screen saying "please replace the lamp" comes up not because it's some how sensing that the lamp is getting old, but because the lamp hours gets to a certain number (usually up around 1500 hours). Because of this when you replace the lamp you need to reset the lamp hours counter, or the projector doesn't even know you've changed it. Every projector does it this way, and they all do it a different way, I googled the model you gave us and found this set of instructions on how to do it, so give it a go.
Reset the lamp counter hours of operation for the projector SONY VPL-CX61
Using the remote commander while the unit is powered up, press "ENTER", "ENTER", "LEFT"
and "ENTER" in sequence. A prompt will appear on the screen asking if you wish to enter the factory mode.
Press the "UP" key on the remote and the unit is now in service mode. This sequence will add two new groups
to the customer setup menu. Press the "MENU" button to view.
Whenever the lamp is replaced, the lamp timer should be reset. With the unit in the "factory" mode, press
"RESET", "LEFT", "RIGHT" and "ENTER" on the remote commander. Verify the lamp hours have been reset to
zero in the service menu.
Hope this worked for you,
Mar 23, 2011 | Sony VPL-CX61 LCD Projector
Replaced the projection lamp, it is still saying that it is ending reaching the end of its life, Is there a reset button?
  • 1
    The procedure may vary from Sony model to model. These procedures are for Sony Rear Projections only. For other models, please consult your manufacter's website. All rear projections have the option of reseting the lamp hours. This helps since you will know how many hours your last lamp ran for. Normal lamps should run between 5000 to 8000 hours.
    Try the following procedure:
    Please be cautious when entering service mode. Following the information below and you will have no problems.
  • 2
    Enter service mode by pressing Display, 5, vol +, Power On.
  • 3
    Proceed to the Option-E screen by pressing the 2 or 5 button
    Option-E 0 0
  • 4
    Change data to 1 using the 3 button on the remote
    Option-E 0 1
  • 5
    Press Mute Enter to write data.
  • Oct 29, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
    I just replace a lamp on Sony vpl-cs20 and lamp timer is still high
    You should turn on the VP-CS20 with the button on projector, NOT THE REMOTE or the instructions wont work.
    "RESET", "LEFT", "RIGHT" and "ENTER" on the remote commander. Verify the lamp hours have been reset to zero in the service menu.
    Hope it helps,
    FVazquez
    Sep 22, 2010 | Sony VPL-CS20 Multimedia Projector
    Sony tv
    TURN TV OFF, PRESS 'DISPLAY' ON REMOTE, THEN' VOLUME UP', THEN 'CHANNEL 5', THEN HIT 'POWER BOTTON', ALL IN THAT SEQUENCE, FAIRLY FAST.. THEN JUMP BUTTON( 3) TIMES, THEN CHANNEL 2( 9 )TIMES THAT SHOULD BRING UP LAMP HOURS
    Feb 24, 2010 | Sony KDS-60A2000 60" HDTV
    Reset lamp hours on sony grand wega
    hello
    1. Press "Display" on the remote, followed by the 5 button, then the sound up key, and "Power On." Do this while the TV is in Standby mode.
    2. Step 2 Then press "Jump" 3 times to enter the DE Service menu. The TV screen will display the total lamp time hours.
    3. Step 3 Reset the lamp time by pressing channel 3, then mute, then enter. This will put your lamp counter back to 0.good luck
    shaun
    Nov 05, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
    Reset code after replacing bulb in sony grand vega
    hello Press "Display" on the remote, followed by the 5 button, then the sound up key, and "Power On." Do this while the TV is in Standby mode.Then press "Jump" 3 times to enter the DE Service menu. The TV screen will display the total lamp time hours.Reset the lamp time by pressing channel 3, then mute, then enter. This will put your lamp counter back to 0. hope it helps
    shaun
    Nov 02, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
    TV doesn't come on
    Please change Lamp and procedure is written in user manual of TV.
    You can see price details of Sony original Lamp at Sony Accessories Store by typing model number in search box and click.
    Jan 19, 2009 | Sony Grand WEGA KF50SX300 50" Television
    How do i get rid of replace lamp message & reset lamp timer
    If you are using the RM-PJ2 remote control, following these instructions. You will have 5 seconds to complete the key sequence.
    1. Make sure the Projector is in "Standby" mode. There will be a red light instead of green
    2. Press the Reset button
    3. On the "joystick" type button, toggle the left directional arrow
    4. On the "joystick" type button, toggle the right directional arrow
    5. Press down on the "joystick" button to press Enter.
    6. Your lamp hours should now be reset.
    Recap: Reset, left arrow, right arrow, Enter, all within 5 seconds.
    Mar 26, 2008 | Sony VPL-EX1 Multimedia Projector
    SONY GRAND WEGA KDF55WF655
    tv turned off black screen and red light flashes 6 times over and over again
    Feb 28, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
    Sony Grand WEGA KDF-55XS955 55" Rear Projection HDTV Logo
    160 people viewed this question
    Top Sony Televison & Video Experts
    Jerry Greenberg
    Jerry Greenberg
    Steve Allison
    Steve Allison
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
