Question about Canon Pixma MP500 All-In-One InkJet Printer
My Alarm button is lighting up and the box that holds the cartridges does not appear to be sliding across like it use to?
    Problem Solver:
  • 16 Answers
Make sure all of the ink cartridges are seated properly. You may also want to open the printer up and clean the slide bar and make sure nothing is blocking the sliding box from sliding. I would recommend using alcohol wipes on any moving parts.
Posted on Dec 11, 2009
Slide finger across wont open
Hi Anonymous,
if sliding your finger across the "slide to unlock" bar won't unlock your iPhone it's possible that your touch screen is (partially) broken.
Try a reboot first: Hold the Power-Button until the "Power off" slider appears. Hopefully you can slide that. If not hold Power and Home-Button for approx. 10 seconds until the phone is off.
If after starting your phone again you can't "slide to unlock" you should see to get a screen replacement.
Mar 04, 2015 | Apple iPhone 4 Black Smartphone
How to fix error code 5200 on canon printer MP258? what is 5200 mean?
Here's the procedure. This code is normally encountered after refilling an ink cartridge and replacing the cartridge. Turn off printer. Hold down Stop/Reset button with one hand and turn printer on with other hand. After green light comes on for the ON button, press the Stop/Reset button two times and you should see the green light blink off and the orange alarm light blink "on" with the first press and then the green light comes back on for the power button and the orange light goes off with the second press (if you did it correctly). Now, you need to hold down the ON button about five seconds, then let go to shut OFF the printer. When you turn it back on, the printer should be back to the factory original condition. Make sure you set all your printer properties the way you want them again from your printer properties dialog boxes because some of the settings may have been stored in the printer's EEPROM, which you just reset to get rid of the offending alarm code.
Feb 01, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
I have an error 5200 The green light flashes and the orange alarm flashes.does not print. have tried unplugging the printer. then plugging it back in. Does not work.
This will work
1. Turn off your printer
2. Press and hold the STOP/RESET button
3. Press and hold Power ON button
4. While holding the Power ON button, release the STOP/RESET button
5. While holding still the Power ON button, press twice the STOP/RESET button
6. Release the Power ON button
7. Wait until it display an "idle" message. It will take about a minute.
8. When "idle" appear, open the top cover to expose the cartridges.
9. Lift up the cover for cartridge holder and take out both the black and color cartridges
10. Return the cover of cartridge holder and turn off the printer
11. Return the top cover and turn on the printer again
12. After the printer initialize, return the cartridges.
1. Press and Hold the STOP/RESET button and wait until it self restart.
2. Release the STOP/RESET button the the printer is restarting.
3. Wait for a few seconds
Sep 17, 2010 | Canon PIXMA MX320 Color USB InkJet Printer
Alarm lights keep blinking after I changed my printer ink.
E5 means cartridges error - to fix press the "stop\reset" button for 5-7 seconds and then release it.
You can also try this:
1) With the printer power turned off but connected to a power source, while pressing the Resume/Cancel button, press and hold the Power button.
(DO NOT release the buttons. The Power LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and
Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light
alternately, Alarm in orange and Power in green, starting with Alarm LED.)
4) When the Power LED lights in green, press the Resume/Cancel button the specified number of time(s)according to the function listed in the table below. (Each time the Resume/Cancel button is pressed, the Alarm and
Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED.)
4 times----Green (Power)------Waste ink counter resetting
Apr 07, 2010 | Canon PIXMA MP240 All-In-One InkJet...
Unable to install new cartridges. they will not slide to left for an Epson 860. Cartridge "lights" do not flash.,
Try holding the cartridge button for a few seconds for it to slide to the left. If not, it may be another button which you must hold for a few seconds.
Sep 18, 2009 | Office Equipment & Supplies
I have a Canon MP700 Printer. The message "waste tank nearly full" appeared. As I couldn't find any help in the manual I removed the ink cartridges to look for a "waste tank". ...
Dear miggsy,
Waste ink absorber capacity of your printer has rise to about 90-95 %. Tentatively, you can continue printing by pressing STOP/RESET button. When ink absorber capacity reach about 100%, the printer stop working and message 'Waste Ink Tank is Full' appears.
To fix this problem, you need to reset waste ink counter. It strongly recommended that you replace waste ink absorber after resetting waste ink counter.
Here are steps resetting waste ink counter of this printer:
  • With the machine power off, while pressing STOP/RESET button, press and hold the ON/OFF button. (Do not release the buttons).
  • While holding ON/OFF button, release the STOP/RESET button. (Do not release the ON/OFF button).
  • While holding the ON/OFF button, press the STOP/RESET 2 times and then release all buttons. (Each time STOP/RESET is pressed, the alarm LED and COPY lights alternately starting with alarm LED).
  • When the COPY button lights in green, press STOP/RESET button 4 times. (Each time STOP/RESET is pressed, the alarm LED and COPY lights alternately starting with alarm LED).
  • Turn off the printer.
Your printer should work normally now.
Regards,
Source:
Canon Inkjet Printer Forum
Dec 05, 2008 | Canon Office Equipment & Supplies
CANON MP210 ERROR E15 - INK NEW PRINTER, NEW INK
Go to this link. In the search window in the center of the screen, type "error e 1 5" and click on the Search button. Select the appropriate error message, then select the answer that says "reseat ink cartridge". You may not have locked the cartridges into place by lifting up until they click.
Oct 24, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
My i pod wheel has frozen. None of the buttons work on my Ipod only the hold button when it is slides across causing the screen to light up. The i pod is 60gb and has not been dropped or exposed to...
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
That should get rid of the freeze.
If your unproperly disconnecting the ipod from your computer before the itunes
sofware disconnects it for you, then that could be your problem with the freeze ups.
Oct 23, 2008 | Computers & Internet
Printer not working
On this printer, the alarm and data lights mean that the toner cartridge is empty. When you replace the toner, be sure to slide the corona wire cleaner across and back. This is the small light blue plastic piece on top of the drum cartridge. You'll see a small arrow in the plastic. Just slide it back and forth once or twice each time you replace the toner cartridge.
May 11, 2008 | Brother HL 1440 Laser Printer
Printer Problem
This was not the sollution for my pinter..
My Magneta is half full and my error led is also blinking 15 times
I found this service manual for the IP4200 but this methode also doen not solve my error led..
Is their someone who has the sollution for this strange error?
1) With the printer power turned off, while pressing
button. (DO NOT release the buttons. The Power LED
selectable.)
resume/Cancel button. (DO NOT release the Power
button.)
the Power and Resume/Cancel buttons. (Each time the
Power
in
time(s)
setting) (THEN HIT THE POWER BUTTON >AFTER THIS< TO SET).
Time(s) LED indication Function Remarks
0 times Green (Power) Power off When the print head is
not installed, the carriage returns and locks in the
home position capped.
1 time Orange (Alarm) Service test print .
2 times Green (Power) EEPROM information print
3 times Orange (Alarm) EEPROM initialization
>>>>>>>>THIS ONE
4 times Green (Power) Waste ink counter resetting<<<<<<<<<<<<
5 times Orange (Alarm) Destination settings After
entering the destination settings mode, press the
to select the destination. For detail, see
"Destination settings procedures" below.
6 times Green (Power) Print head deep cleaning
(Cleaning of both black and color)
7 times Orange (Alarm) Reserved
8 times Green (Power) CD / DVD check pattern
9 times Orange (Alarm) CD / DVD print position
correction (horizontal: X direction)
10 times Green (Power) CD / DVD print position
correction (vertical: Y direction)
11 to 13 times Orange, Green, Orange(Alarm,
Power,Alarm) Return to the menu selection
14 times Green (Power) Left margin correction Not used
in servicing.
15 times Orange (Alarm) Return to the menu selection
Time(s) LED indication Destination CD / DVD print
0 times Green (Power) No change of the destination
1 time Orange (Alarm) Japan Supported
2 times Green (Power) Korea Not supported
3 times Orange (Alarm) US Not supported
4 times Green (Power) Europe Supported
5 times Orange (Alarm) Australia Supported
Oct 30, 2007 | Canon PIXMA iP4300 InkJet Photo Printer
Canon Pixma MP500 All-In-One InkJet Printer Logo
41 people viewed this question
old marine
old marine
