Question about Canon P23-DH Calculator
Printer malfunction The printer adds one number to each keypad input. Thus, 2 x 3 = 6 prints as 3 x 4 = 12. Or 2 x 333 = 666 prints as 3 x 444 = 1,332. Is there a solution for this problem?
  • 106 Answers
Your`printer is poor,try to clen them with compressed air,and probably you may change some parts in the printer
Posted on Feb 05, 2008
How do I align my Citizen CLP 7202e Lable printer print head to align with the lables? Currently it starts printing low on the lable and thus the last 1-2 lines print over onto the next lable
Adjust vertical offset in printer properties. If that doesn't fix it, adjust it under "advanced". Or... you can set the offset in the printer itself. Hold down the left two buttons at the same time. Cycle through the settings until you get to vertical offset.
Apr 19, 2015 | Citizen CLP-7202e Thermal Printer
2 good tips I learned during setup
1. The print server address is indepent of the router address. You have to set the print server address manually, and then 'add a printer' and assign it matching properties. For the individual who kept getting .102 then .103 (I did too), here's the fix. You need to assign an address that is higher than the max DHCP options. On my Linksys router setup, I found that it started assigning at .100 with a max of 50 users (up to .150). Therefore, I went into the print server and assigned mine .175. Then, I added a printer and under its properties, assigned the matching IP address.
2. When assigning the IP address ( for mine) during 'Add a Printer', the Port field below it automatically fills in with an address of something like IP_192..... I had left this the same and followed the instructions from Trendnet as well. It did not work. Well the final solution that finally allowed me to print after hours of frustration, was to manually change this Port field to 'U1' thus matching the pop-up window that Trendnet instructions walk through (the one with LPR and bit enabling etc.) where it says to input U1. I decided to try U1 as the Port and it worked. And it was beautiful to hear the printer start cranking after hours of frustration. Good luck.
on Dec 06, 2007 | Trendware TRENDnet TE100-P1U Print Server
Samsung SCX-6345 machine is blocked by a fax arrived that captured both the printing and copying. how to reset the machine?
  • Turn on the printer.
  • 2 Press the "Machine Setup" button in the upper left corner of the control panel.
  • 3 Press the "Admin Setting" button on the touchscreen. Touch the password input area if the administrator set a password for the printer. Press the number keypad buttons to enter the password. Press the "OK" button on the touchscreen.
  • 4 Press the "General" tab shown on the screen.
  • 5 Press the "Default Settings" option. Press "Yes" to reset all at once the user settings configured on the printer, such as copy and scan options, fax settings and network and system options
  • If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
    Thanks, Joe
    May 19, 2011 | Samsung SCX-6345N Printer
    Windows 7 cannot find my hawking pn7127 print server. All my xp computers print to it no problem , My port is Even when I input this info, Windows 7 cannot communicate with the...
    1. Click "Add a printer".
    2. Click "Add a network printer".
    3. Click "The printer that I want isn't listed".
    4. Select "Add a printer using TCP/IP". Click "Next".
    5. Type in the print server's IP address. Click "Next".
    6. Select "Custom". Click "Settings".
    7. Change Protocol to "LPR". In LPR Settings, type in "lp1". Click "OK".
    8. Click "Next". Select your printer. If your printer isn't listed, click "Windows Update". If still not listed, install driver from manufacturer's website.
    9. Print a test page!
    Mar 10, 2010 | Hawking 10/100M Internet Print Server...
    My printer hp laserjet p3005dn will not let me print from tray 2 every time i try and print it goes to try 1
    You may not have configured the HP for two trays.
    Open Printers and Faxes - right click on the HP printer and click on Properties - click Device Settings tab - Installable Options, in Number of Input Trays enter "2" then click OK.
    When you print you will be able to select the tray1 or 2 to print.
    Sep 01, 2009 | HP Laser Jet Printer P3005dn
    Cannot set up wireless connection
    First, I just want to say--OMFG-- what a hassle to get wireless printing to work. I don't recommend this printer for
    anyone that's not computer savvy, unless you just want to print through the usb cable.
    My problems started when I first bought the printer and tried to install from the cd. I ran into several 'Fatal Flaw'
    errors which required the software to uninstall, the computer to restart, then try to install software again after
    searching the HP support webpage to determine the cause of failure. I finally gave up and went to the HP download page
    and downloaded this:
    This installed everything without errors but I still couldn't do wireless printing.
    I tried to connect using the wizard but it said it couldn't find the printer. The error report file said the
    passphrase on my printer did not match my router. So I thought I had forgotten my router password. I reconfigured the
    router password and I received the same error message.
    My next step was to press the wrench key on the printer control panel and press the arrow keys beside the OK button
    until I found "wireless menu".I clicked OK and proceeded to enter the data manually on the printer. Voila, success! or
    so I thought. It told me that connecting to the router was successful but I still couldn't print.
    My printer showed up in the Printers and Fax section of contol panel, the drivers installed properly, the printer said
    it was connected to the router, and I could print using a usb cable. Just no wireless.
    If it wasn't for the fact that it was 1:00 am I would have taken it back for a refund.
    I decided to try one last thing. I opened Printers and Faxes in control panel then "Add a Printer" in the top left
    "Local printer attached to this computer"
    DID NOT check "Automatically detect and install Plug and Play printer"
    "Use the following port" I used "DOT4_002(Officejet J4680 Printer)"
    Manufacturer-- "HP" Printers--"HP Officejet J4680 Series
    Kept existing drivers
    Printer Name "HP Officejet J4680 Series (Copy 2)"
    printed a test page and -----
    it still didn't work.
    The only option I had left was to add a printer and CREATE A NEW PORT, which FINALLY solved the problem. Here is how
    to do that.
    For Windows XP
    Control Panel
    Printer and Faxes
    Add a Printer (should be in the top left corner)
    Check "Local printer attached to this computer"
    DO NOT check "Automatically detect and install Plug and Play printer"
    Choose "Create a new a port"
    if it asks you to input a name, enter whatever you want in the "name" box. It should be something so you will
    recognize it as your printer.
    Choose "Standard TCP/IP Port"
    A new wizard should pop up.
    For this step you will need to go the control panel on your printer to find your printers IP address.
    Press the wrench button, scroll the arrow keys until you see "Print Report", press OK, then scroll to find "Network
    Print this page. Under GENERAL INFORMATION find the URL number.
    Go back to the Add Printer Wizard
    In the top row, enter the URL like this: using your numbers
    Choose the "Custom" button
    and you should be finished.
    If it still doesn't work you may need to manually configure your DHCP router to input a static M.A.C address for the
    printer, which you can find on the sheet you printed off. It should look something like this
    Hardware Address (MAC) 00345a0d04v
    Consult your router help files to find how to do that or search the web.
    It took me two days to figure this out so I hope this will help.
    Aug 16, 2009 | HP J4680 Office Jet All-In-One Printer
    Cannot get wireless or bluetooth to work with laptop. The software was loaded on. It will print only if connected by usb.
    First, make sure that your Printer is setup with the correct wireless information from your wireless router. Once this information has been entered, you should be able to connect to the wireless printer.
    Click add Printer, from Control Panel, Printers & Faxes.
    Click Add Printer, and than add Local Printer, Create Local Port, TCP/IP.
    Print out the network configuration page from the printer, should be under menu.
    Next input the IP information into the IP Address field, the Port will automatically be filled in.
    Sincerely, Ryan Deschaine Systems Engineer Boxen Solutions LLC
    Email address:
    Office number: 262.432.3120
    Mobile number: 262.364.6196
    Fax: 414.918.8432
    AOL: BoxenRyan
    Twitter: BoxenRyan
    W172 N9175 Shady Lane
    Suite 418
    Menomonee Falls, WI 53051
    Jun 30, 2009 | HP Photosmart C5580 All-In-One InkJet...
    Wrong cartridges error
    Printer cartridge is damage replace it
    May 29, 2009 | HP Photosmart C5180 All-In-One InkJet...
    Netgear ps121 won't print
    Possible reason why you cannot print with the print server is because the computer is not getting a valid IP from the router or a firewall is installed in the computer. You have to disable all firewalls installed in the computer.
    For the print server setup, please follow the steps below:
    Note: Before setting up the print server, make sure that you can print when printer is connected directly to the computer.
    1. Wire the print server to router. Check the lights on it. It should have the ACT light on and the Error light off.
    2. One way to test if the printer would work with the print server is to reset the print server for 3 to 5 seconds while it is powered on and after you release the button, the printer should automatically print the IP address of the print server.
    Note: If the printer did not print, there is a possibility that they are not compatible. However, you may still continue to try to set up the print server.
    3. Install the PS121 software.
    a. Power on your computer, let the operating system boot up completely, and log in as needed.
    b. Insert the Resource CD for the PS121 into your CD-ROM drive. The CD main page shown at the right will load.
    c. Click Install Software.
    d. Click Next and follow the software installation utility prompts to complete the software installation.
    e. When prompted, restart your computer to complete the installation.
    f. When your computer restarts, click Finish to run the Print Server Setup Wizard.
    4. Run the Print Server Setup Wizard to Set Up a Fixed IP Address for the PS121.
    a. The Print Server Setup Wizard screen should be displayed.
    b. Click Next to proceed. The Print Server Wizard will now search your network for the PS121. If the Print Server Setup Wizard cannot find your PS121, check the network connections and status lights on the PS121.
    c. The “Server Name” and the “IP Address” your network assigned to the PS121 are displayed. Click Next to proceed to the device name screen.
    d. You can enter a descriptive Device Name and Domain Name or accept the defaults. Click Next to proceed to the IP Address configuration screen. The Print Server Wizard displays a recommended static IP address setting for the PS121. This is usually fine.
    e. Click Next to proceed.
    f. Click Finish to exit the Print Server Setup Wizard. This completes the configuration of the PS121 for operation on your network.
    g. Click Yes to run the Add Printer Port Wizard. Follow the instructions in the next section for using the this wizard to set up each computer to use the PS121.
    To set up each computer to use the PS121, please follow the instructions below:
    1. Use the NETGEAR Add Printer Wizard to set up each PC to use the PS121.
    a. When the Print Server Setup Wizard finishes, you are prompted to run the Add Printer Port Wizard. Click Yes to proceed. Alternatively, from the Windows Start menu NETGEAR Print Server program group, you can run the NETGEAR Add Printer Wizard.
    b. After a short delay while the software searches the network for your PS121, the Printer Select window opens and displays the PS121 you have set up.
    c. Click Next to proceed to the Port/Printer name screen. Take note of the printer model number listed.
    2. Set up the correct printer driver for the printer port.
    a. Click Next to proceed to the Port/Printer name screen. Take note of the printer model number listed.
    b. Click Next to proceed to the Select Printer screen. If you see the exact printer model number listed as the printer model number from in the previous screen, click it to select it from the list.
    c. If prompted, print a test page to verify operation of the printer and the PS121. Then, close any remaining Add Printer Port Wizard or Windows Add Printer Wizard windows.
    Use the NETGEAR PS121 Mini Print Server Resource CD to run the Add Printer Port Wizard to set up each PC on you network that you want to use with the PS121. Select the port you added
    You may also use the links below as your guide to troubleshoot the print server:
    However, if this does not resolve the issue we will need to get some additional details from you to be able to assist you further. I have summarized my questions below:
    1. Model number of router
    2. Model of printer
    3. Operating system of computer/s
    May 01, 2009 | NetGear PS121 Print Server
    Epson LQ-2180 continuous printing problem
    An Emulation driver will fix everyones problem... Do this:
    1. Click on "Start", then "Control Panel" and then "Printers and Faxes".
    2. In the left hand column choose the option "Add Printer". The "Add Printer Wizard" comes up, click on "Next".
    3. At the "Local or Network Printer" screen choose "Local" and remove the check from "Automatically Detect".
    4. Click on "Next".
    5. At the "Select Port" screen choose the appropriate port (usually LPT1: recommended printer port).
    6. At the install printer software screen choose "Epson" under "Manufacturer" and LQ-1050 for the printer, then click "Next". If you wanted to install the Windows universal driver, choose "generic" under "Manufacturer" and choose "Text Only", then click "Next".
    7. At the printer name screen choose "Next".
    8. When asked if you would like the printer to be default make the appropriate selections and then click "Next".
    9. Finally click on "Finish". You may need your Windows XP installation disk.
    Feb 05, 2008 | Epson LQ-2180 Dot Matrix Printer
    Canon P23-DH Calculator Logo
    old marine
    old marine
