Insufficient gas flow in furnace...could it be the altitude? we are at 5000 ft.
  • 1,420 Answers
Yep, and as the temperature gets colder it will drop even more.
Posted on Dec 11, 2009
High altitude operation of a ryi2200 generator (5000 ft)
You require a high altitude carb (or carb jet) to operate correctly at this altitude. The jets are smaller to compensate for the thin air.
You need to get in touch with Ryobi to see if they sell them.
Do not adjust anything else on the generator!!!!
Dec 22, 2016 | Electrical Supplies
Tip
?JCB FAULT CODES LIST
P0087 (flashing code 227) shared sump low pressure fault (for pump without pressure supply)
The main fault symptoms
• Engine severe vibration.
• idling unstable
• Output Fall
• exhaust smoke
• It may be too large output
P0088 (flashing code 118) shared the tank pressure is abnormally high (first or second stage)
• idle instability
• Output Fall
• channeling gas engine failure
• exhaust smoke
P0089 (flashing code 151) shared the tank pressure failure (for pump pressure supply is too large)
• idle instability
• Output Fall
• exhaust smoke
P0090 (flashing code 247) SCV drive system open, + B short circuit or shorted to ground
• Depending on the open / short situations, there may be an engine stall and / or launch
Machine channeling gas.
• exhaust smoke
• Output is too large
P0107 (flashing code 71) atmospheric pressure sensor circuit input low (open or shorted to ground)
Due to spare the equivalent altitude 2000 m (6562 ft)
• exhaust smoke at high altitude.
• insufficient output at low altitude
P0108 (flashing code 71) atmospheric pressure sensor circuit input high (+ 5V shorted)
• The high altitude exhaust smoke
• lack of low altitude output
P0112 (flashing code 22) intake air temperature sensor fault (low voltage fault, earth fault, short circuit)
• When cold starting, may exhaust white smoke.
More here http://truckmanual.weebly.com/jcb-fault-codes.html
on Dec 20, 2016 | Cars & Trucks
How do I convert cfm to scfm
For the Equation to follow the following definitions apply
S = scfm (the answer you want)
P = Barometric pressure in Pounds per square inch when you measured the cfm.
14.696 = standard barometric pressure at sea level
So:
S = P/14.73 x cfm
Example: Denver
Barometric Pressure 11.50 psi
cfm = 5400
S = 11.5 / 14.696 x 5400 = 4225.6 scfm
There was a lot of debate in the Natural gas industry years ago about the Standard barometric pressure value. Some Companies used 14.69 psi and others used 14.73 psi.
If you use natural gas to heat your home this is the same equation used by the gas company to correct for altitude on your bill.
The equation is derived from Boyles Law which is accurate at pressures close to atmospheric pressure.
Feb 25, 2015 | Heating & Cooling
Need wire diagram from the hot wires feeding a blue angel oil burner and blower motor
Dean,
What kind of primary control? Beckett?Honeywell? Carlin? Control model #?
Oct 18, 2013 | Peerless WV-DV-04, Oil Fired, Hot Water...
Wiring Diagrams
Check out this site
www.peerlessboilers.com/Products/ResidentialBoilers/
SeriesWBVWV/tabid/118/Default.aspx#dnn_relateddocuments
Safety relief valves
Need to know what pressure steam you are running, and what your water feed pressure is & temperature. If you are using a deaerator with pumps to supply feed pressure, and if there is a stack economizer. @ your altitude, I would de-rate your gas output to 10% less than your rated BTU's. Also need to know the % of oxygen in your flue gas, and if the gas & air intake is staged or modulating.
Apr 17, 2013 | Weil-McLain 88 Series - 11.8 GPH -...
I have an Ef3000iseb runs great here at or about 5000 ft. go up in the mountains it starts loading up and wont run. is there a higher altitude kit?
Yes thats true
there is high altitude re jetting in the carburator your carb has to be re jetted for the normal operation of the generator at high altitudes by the authorised personel but when you will bring it back again at the orignal altitude it will get heated quickly and may not function properly so you will have to bring the carb settings to its orignal position so be careful
Aug 12, 2012 | Yamaha Ef3000iseb Generator Portable 3000...
Installing high altitude kit on Cozy NG furnace
the orifice that comes with the unit has a starter hole only needs to be drilled out, in the instructions is a chart for altitude de-rating.
Oct 04, 2009 | Cozy Enclosed Front Console Heater 20,000...
I have a 1990 Wrangler with the 4.2L six carbureted engine. It is set up for under 4000 ft altitiude but I have moved to 5000 ft plus altitude. What do I need to do to set it up for the higher altitude? It...
Smaller jets in the carb, less oxygen in the air means, you got to have less fuel in the mixture otherwise wham to much nox and no pass the mans law...
Jun 12, 2009 | 1990 Jeep Wrangler
Pressure switch on my intertherm furnace m3rl080a bwt is rated at -1.74 is that the wrong switch rating for my unit or should it be closer to -1.0 ,I live at an altitude over 6000 ft if that makes a...
the altitude makes a huge difference. If when the unit was installed and the gas input pressure at the burner manifold was not set correctly, you could be way "underfired". Which means that you're not getting the full btu content that your unit is capable of. Your pressure switch should be fine if that's what came with the unit.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/cody_17f08cf8e340c06c
Apr 29, 2009 | Intertherm P3RA-048K Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Mack Baxter
Marvin
Marvin
