SOURCE: sky code for a goodmans gtvl19w17 hdv
Try this : Turn TV on, point remote away from TV, press TV button on your SKY remote...hold down SELECT and the RED key together for about two seconds, until the red light (LED) on the remote blinks twice...key in the remote code for your model of TV on the remote keypad ( for Goodmans, try 065, or 0335 ) then press SELECT button ( the LED should blink twice to show code accepted ) press SKY button to exit. point remote at TV and test.....Job Done . !
SOURCE: Goodmans LD3266D TV - need the code to work volume
Well first you can try - 065, 064, 100, 285, 037, 292, 544, 207, 318, 363, 399, 402, 515
if none of the code works for you then please follow the below link to know how to search your sky remote code -
http://www.sky.com/portal/site/skycom/skyhelpcentre/producthelp?nodeId=73a6e9e0-0ade-4eed-810b-cec670799bcc&articleId=11320303
also check the below link -
http://www.skyuser.co.uk/tools/remotecodes/index.php
Good Luck!!
SOURCE: SKY REMOTE CODE FOR GOODMANS GTVL19W17HD
The remote code is 1130 for this set.........using a v8 remote for HD box..... took 3 attempts to get it to work..... hope this helps....
