Question about Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense...
I only get crushed ice even when the button is on
I only get crushed ice even when the button is on cubed ice
  • 583 Answers
Pull the ice bin out and you'll see a rectangular hole with a plastic piece that has a rectangular hole in it. This piece will correspond to a steel rod that runs along the bottom of the ice bin. This steel rod actuates the crush/cube option in the dispenser. Sometimes icing can cause the plastic piece to get stuck. Try "jiggling" the plastic piece up and down until it frees and operates easily. Then replace your ice bin and try operating the controls on the dispenser again.
Posted on Dec 17, 2009
SOURCE:
Getting shaved ice instead of cubes
Several possibilities, but check first for cubes that are too small (means too little water is coming in during ice maker fill) and those cubes fracture into smaller bits when they are dispensed.
Another possibility is the cube/crushed plate inside the dispenser is stuck. This is a curved plastic piece that lies next to the crusher blades inside the dispenser head of the ice storage bin. For cubes this place must be retracted (swing away from) the crushed fingers to allow the cubes to pass without being broken up.
Oct 30, 2016 | Refrigerators
Mu Kenmore refrigerator's ice maker is dispensing crushed iced even in the cube mode
Take out the ice bucket and check the metal arm and make sure it moves freely. Ice may have gotten stuck.
Jul 20, 2016 | Kenmore Refrigerators
The ice maker of our GE GSH25JSXSS is only producing crushed ice even when it's set to cubed. Is there a way to fix this issue?
Check that the shifter bar on the bottom of the ice bin is moving to shift from cubed ice to crushed. With the ice bin out you should see movement in the back wall of the freezer with the light switch button held in while changing the dispenser controls from cubed to crushed. GSH25JSXASS Parts
Ice Bin Parts
Appliance 911 Sea Breeze
Nov 03, 2015 | GE Refrigerators
Why am I getting crushed ice when I requested cubes
Hello friend, thank you for your post!
I understand that you are receiving crushed ice even when you request cubed ice. It could be an issue within your control panel or solenoid. Since it could be any one of these under lying issues I would recommend having a technician come out to properly diagnose your appliance. Hope this is helpful. -Matt
Sep 12, 2014 | Frigidaire Refrigerators
Dispenses crushed ice instead of cube ice
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid
Aug 31, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Crushed ice mode seems stuck - want cubes but keeps crushing.
jeff, at one time the ice bin was removed and there is a rod on the bottom of the bin remove the bin and you'll see an opening where the arm will fin the square plastic looking assy is probally stuck in the up position pull it down with you finger and reinstall the bin the it should work
Aug 19, 2009 | Kenmore 54662 / 54664 / 54669 Side by Side...
Ice crusher has stopped crushing
Replace the switch behind the front panel on the freezer.
Mar 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice maker is crushing ice when cube ice button is on
We've had a similar problem, possibly the same, with our LG in-door ice maker. Whether cubed ice or crushed ice is selected, it crushes the ice.
We found that there is a little lever on the inside of the door, on the lower right behind the ice bin, which freezes in the down position. This is a literal "freeze up", as a block of ice forms in the little well under this switch and eventually freezes the switch in place. Since the switch needs to go up to provide cubed,.. we only get crushed. On 3 separate occassions we've thawed and chipped out (carefully) this little ice dam and gotten cubed ice capability back for a few weeks. At which point it freezes again. I have no idea why water collects there in the first place.
Feb 20, 2009 | Frigidaire FRS23KF7AB Side by Side...
Frigidaire Gallery Series Side by Side doesn't crush ice
hi there,
could be that the ice maker arm is getting stuck or may have some frost on it. can you supply the complete model # please?
Sep 25, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frididaire Gallery series side by side with ice and water in the door
First pull out the ice bucket and close the door.  Set for cubed ice.  Press the button for ice to come out and listen for a loud clunk noise.  That is the sound of the solenoid.  You can open the door, hold the light switch and press the button and watch for the solenoid moving up and down.  Solenoid is at the back of the freezer in a little square opening where the rod on the ice bucket goes into.  If that solenoid is moving ok then put the bucket back in while the solenoid is in the down position and cubes should work.  If solenoid is not working then it will need to be replaced.  Let me know what you find.
Oct 14, 2007 | Frigidaire FSC23F7D Side by Side...
Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense... Logo
228 people viewed this question
Top Frigidaire Refrigerators Experts
Steve Allison
Steve Allison
Sal De
Thomas F. Schneider
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
