Question about Garden
Engine will not run at steady speed, govenor continually fluctuates , This engine is a Kawasaki FC420V-ES10 on a John Deere Riding Tractor Model LX176. I tried the mixture adjustment needle valve no help.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 197 Answers
On top of carb you will see a jet that is slotted,remove with screw driver and use a very thin wire to clean out hole in jet.Some had a black metal clamp holding it in place,remove that one by removing phillips screw,black clamp then use small pliers to pull jet out of top side of carb.If this does not work remove carb bowl and jetting in bottom-center of carb and clean jetting holes with a small copper wire.The mixture screw is for low speed air/fuel mix,this engine does not have a high speed fuel screw.Fixed jet.
Posted on Dec 11, 2009
ADJUST THE GOVENOR ON MY LT 155 John Deere lawn tractor
This should be Kawasaki engine; although, it could a Kohler. The IPL on this doesn't specify which engine it has. It would nice if it did where I could look the engine's service manual but the following should be what you need.
You place throttle in full throttle position. You need to watch the linkage at the governor shaft for which it turns as you go to full throttle then you would continue turning the governor shaft in that direction until it stops. From there you tighten the retaining bolt or nut and you should be good to go.
Nov 08, 2014 | John Deere Garden
How do you adjust governor on 20hp Kawasaki ohv wants to run to fast
take it to a dealer it is to sesitive to speed changes with the govenor
Sep 30, 2014 | John Deere Garden
1970 John Deere 4020 Diesel, Engine speeds up by its self, I goose the throttle and then it will idle down. pretty sure it is a govenor problem. How do I fix this?
spring is broken/stretched out on govenor linkage bar that runs from air damper flag to injector pump and i would expect a 1970 to be needing a new spring about 5 years ago
Dec 12, 2013 | John Deere Steel Chain/farm/tractor/john...
FC420V Kawasaki back fires thru carb on cold start,runs and starts fine after difficult startts
It sounds like your valves may need to be adjusted...
if they are too lose or worn they won't seat properly and when the engine fires it blows back through the intake valve.
pull the cover and see if the rockers are loose... it only takes one to give you a headache.
Mar 29, 2013 | John Deere 420,1020,2010,2020,2510,2520...
A,b,g Tractor Carburetor Float Dltx10: i had my john deere riding mower running then shut...
My John Deere only starts with a hammer. I have the Kawasaki engine and it is famous for bad starters, so I carry a hammer and tap on the bolt when I want to start it. So, you either have a bad solenoid in your starter, or the contacts are dirty, battery connections are dirty. Or the battery is dieing. Check it out. Hope this helps.
May 07, 2010 | John Deere A,b,g Tractor Carburetor Float...
BACKFIRES THROUGH CARB,WONT START ,MOTOR IS KAWASAKI FC420V IN A JOHN DEERE LAWN TRACTOR
Most likely water in the fuel. Drain the tank and clean the carb. replace with fresh gas. Mr fix it is a dumby
Apr 06, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
665 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
