Question about Creative Labs Gigaworks S750 Computer Speakers
I have a Creative Gigaworks S700 (subwoofer) with no power out. LED off. Fuse ok.
  • 1 more comment
  • stephan_brow Mar 01, 2010
    I have checked only the fuse located below the male end of power adapter. Where is the second fuse located at?
    The S700 is equipped with a power cord only. The power cord connects to the male plug adapter located on the rear panel. There is a single fuse located there. That fuse checks out ok.
  • iba0091 May 11, 2010
    There are two fuses which you can check have you checked both?
First fuse as standard is in the plug to the power adapter. The second fuse is located at the back of the box where the power lead goes into. It is covered so look closely you just need something flat to open it. I have the S750 and that is what im basing this on but if the s700 is the same then you will find this helpful. Sorry did not notice this before.
Hope this helps.
Posted on Mar 01, 2010
I have a Creative Gigaworks S700 i have checked both fuses still no power to control box
Stupid question: does the sound still work? it could be the LED just died after continual use (rare, since they last a long time, but not uncommon).
If not... it could be the controlling circuit board died. In which case, unless you have electronics repair experience, it would be probably more worthwhile to just replace the speakers, as pricey a model as it is.
Mar 23, 2012 | Creative Labs Gigaworks S750 Computer...
I need to connect a gigaworks s700 to my computer but i dont know how to.
I wasn't sure if you were looking for the manual (connection instructions). If so, here's the manual:
http://ccftp.creative.com/manualdn/Manuals/TSD/7676/Creative%20GigaWorks%20S750%20Users%20Guide%20English.pdf
It's possible that your computer doesn't have the proper connections to connect these speakers. If that's the case you will need to upgrade your sound card.
I hope this helps and I which you the best of luck!!
Mar 01, 2011 | Creative Labs GigaWorks S700 Computer...
Subwoofer will not play with other speakers
Hello
It looks like you have posted this before. Unfortunately, I don't know what you have tried so I may be repeating some of your earlier troubleshooting.
The subwoofer needs its own power supply to function properly. if it isn't getting enough power, the sub will not work at all.
On the back of the unit, you should see a green LED when the power is turned on. Is this light on all of the time of does it fade / flicker? This would indicate the power supply is going bad and you need to replace it.
http://forums.creative.com/t5/Speaker-Systems/GigaWorks-S750-power-problems-green-LED-faded-and-flickering/td-p/547311;jsessionid=9B7C9D2D939336148A9036D7E7D18A12
Apr 30, 2010 | Creative Labs Gigaworks S750 Computer...
No Power on the S700, but LED indicator use to blink.
Try disconnecting both of the amp board power supply cable (the green one from psu to amp board)
Jul 08, 2009 | Creative Labs Gigaworks S750 Computer...
Left front speaker works the rest dont and the sub makes a hum
Either you have it configured incorrectly this time around, or the settings are defaulted back to original on your DVR........ adjust your DVR sound properties/settings. and check all wires/connections as well.
Apr 20, 2009 | Creative Labs Gigaworks S750 Computer...
Sub has died overnight
Change the fuse - located at the 220V input. Use a knife ti release it. Then the system will work again.
Oct 08, 2008 | Creative Labs Gigaworks S750 Computer...
Audio control pod
I have a similar issue too, but my problem is that the sub has green light, and my control pod has an 'off' light, but it won't turn on :(
Jun 16, 2008 | Creative Labs Gigaworks S750 Computer...
Creative Labs Gigaworks S750 Computer Speakers Logo
1,241 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
