A Fender 15G starter amp. The Volume is on full, however turning the knob down wont turn down the volume. I took off the knob but it appears to look ok. What else could I do to fix this problem?
  • 140 Answers
The controll is broke and needs to be replaced. Most likley the amp had fallen over. If you cannot do this you can contack Pro Line Music 215-736-8055
Posted on Dec 11, 2009
Can't turn one unit off when I turn the volume allthe way down I get no click and the unit stays on
Unfortunately, your volume potentiometer (the part behind your volume knob, which connects to the component board, has gone bad. This can happen from turning the knob too far past full volume or even sometimes when turning it off. The part to repair this has never been offered as a replacement part. Your only solution is to remove the battery to turn the unit off.
Best regards.
Dec 07, 2012 | Motorola Talkabout FR60 (14 Channels)...
Play mac through Fender Frontman amp
Simple: connect the headphones out (3.5mm jack) to the input jack of your fender (6.3 jack). By doing this you will loose one channel so you better generate a mono signal inside your computer before. Electrically this is no problem, nothing will be damaged. Turn the gain and volume knobs down and apply a signal from your Mac. Gently increase gain and volume. Et voila wonderful mono sound through a guitar amp
May 24, 2012 | Fender Frontman 65R 65W 1x12 Guitar Combo...
I recently had my fender acoustasonic telecaster checked out because the volume kept shorting out. It seems the volume pot was dirty or had a short. Took it to my local fender guitar and fender electronic...
If the problem is actually the volume knob, then the guitar shop did not fix it and you should bring it back. There is a test you can do to see if the problem is your volume knob. With the guitar unplugged, you can turn the knob up to the max and down to the min a lot of time (like 50-100 times or more) plug it back in and see if the problem is a little bit better, if it is I would bring it back to the repair shop and demand they fix it properly.
The problem could be the cable you are using. Sometimes it can seem like it's a volume knob problem when really it's a cable issue. Jiggle the cable and connector while the guitar is plugged in to see if the sound cuts out at all or you get crackling.
May 04, 2011 | Fender Acoustasonic Telecaster 3TSB
Get a lot of static when try and turn volume down low.....in fact, sometimes it is hard to get sound when you turn the volume down....it is either full blast or silent.....lots of static like noise when...
This is an easy fix with a can of volume knob cleaner i think its called. You should be able to get it at radio shack. You just spray it into the volume knob and let it dry. The instructions are on the can.
Dec 03, 2009 | Tivoli Kloss Model One AM/FM Radio
How do you change the time on a sony cdx-gt510 stereo
Push & hold down the volume knob until "clock adj" appears on the face (a couple of seconds). Then turn the volume knob, left or right, to adjust the time up or down
Nov 28, 2009 | Sony CDX-GT510 CD Player
Fender Deluxe. The volume knob has no effect whatsoever. Volume only changes with the drive knob.
Your amp has two channels - "normal" and "drive." When you are on the normal channel, the "volume" knob controls your gain. In the "drive" channel, the drive knob controls your gain. In both channels, the "master" knob limits how loud the amp will get.
Most likely, you are on the drive channel, so the volume knob will have no effect. Try pushing the "channel select" switch. You should notice the channel indicator lamp (next to the drive knob) turn off. When it is off, you are in the normal mode. Yellow = drive, and red = "more drive."
Experiment with different settings to get a variety of tones.
To get the most out of this amp, try reading the manual, available online here:
http://www.fender.com/support/manuals/pdfs/manuals_elec/guitarpdf/Hot_Rod_Deluxe.pdf
Have fun - it's a great amp.
Oct 28, 2009 | Fender Hot Rod Deluxe Guitar Combo...
We have a Denon AVR 1905/785 We cannot turn the volume down.... it is at -70 and full blast... the volume turns up and gets even louder.... but can't turn the surround sound down... help
if the volume control as been forced the conection in the switch as jammed +vol .this is usually a small preset under the knob the right hand one.pull the knob off pulling straight as not to bend spindle some time's the two presets are visable.a cotton bud dipped in spirits could solve your problem but some times you need to pull the top of the preset .it might need removing and replacing . this could be a more complicated problem caused by a variety of things here are a few,dry joints,cracked pannel .hope some of this helped . if in dire straits skype me farr64
Apr 27, 2009 | Denon AVR-1905 Receiver
When i turn on my amp it makes a loud beeeeeeeeeeeeeeeep.
Turn the volume down.
Check your gain.
That should solve it.
Feb 05, 2009 | Fender Frontman 65R 65W 1x12 Guitar Combo...
VOLUME CONTROL PROBLEM.
If the volume control can be turned continuously in either direction (no stopping), then the control is what is called an encoder and the behavior you are describing is an internal logic failure. If the control has an upper and lower limit (only turns so far), then it is a standard volume control and is physically broken and needs to be replaced. In either case, the unit should be under warranty. Return it to Best Buy for repair. Given that it just came out of the box, talk to a manager and request an exchange.
Dan
Mar 16, 2008 | JVC HX-D77 Shelf System
Volume starts out at full
If you read the owners manual careful it tells you something about setting the volume at start up buy setting the volume to desired level then push in and hold a few seonds the volume knob and that volume should be reached every time you start your vehicle.
Oct 12, 2007 | Dual XDVD8181 Car Video Player
62 people viewed this question
 Grubhead
Grubhead
