Question about Nokia 5800 XpressMusic Smartphone
My screen on my phone wont go on!!!! help please
I press it to turn on and it vibrates and the 3 buttons come on but the screen some times goes grey then turns back off but thats all it does i dont no why i onlty brought it a week ago i might of droped it once but thats all. how much would it be to get it repaired ? at christmas time like.
How do I turn off battery on Xperia T that is built in
I'm 100% sure on the Xperia T(I have a ZL) but with most off the Xperia's there is some sort of removable back panel or a hinged flap that opens up under the panel/flap there is a orange button that you will need a pen to press and hold. hold this button down while holding down the power button it should vibrate once, keep holding the buttons then it should vibrate 3 times, now let go of the buttons and your phone should stay off.
Aug 17, 2014 | Sony Xperia U ST25I Android OS v2.3...
How to fix my nokia 5230, it switches on and displays 'Nokia' but thats it, it wont go any further than that screen.
Try to manual format your phone. Here's how;
1. Turn off your phone first.
2. Hold and press Green + Red + Camera button and Power button. Wait until phone vibrates.
3. Release Power button and wait until the selection for your location appears.
Please post your feedback after doing this.
Jul 12, 2011 | Nokia 5230 Cell Phone
My nokia 3110c shows only nokia logo and after that only white screen . please help me what is the problem
follow these steps:
1) remove the back case 2) press the power on button 3) remove the battery (button still pressed) 4) insert the battery (button still pressed)
repeat 2-3 times, this will solve the issue...
if it helps plz vote it
Jan 16, 2011 | Nokia 3110 Cellular Phone
I have Nokia 3110c. When I switch it on, NOKIA logo comes, screen flashes 3 times with white blank screen and goes off. It never comes again. It happens every time I press power on button. There is no...
Possible that the software of the phone is corrupt or a possible hardware is defective.
You can remove the battery and memory card, have the card scanned for virus. replace battery after 15 minutes so that the phone is reset.
if the phone wont boot back the services of the Nokia support must be sought for reinstalling the software.
Oct 23, 2010 | Nokia 3110 Cellular Phone
Samsung a737 is the model
Here is a quick run down on that and a link to the PDF manual that will tell you everything you need to know.
This is for a Verizon Samsung u700 mobile phone.
1.From the main screen, press OK MENU, use the right navigation key to highlight SETTINGS & TOOLS and press OK.
2. PRESS (BUTTON 4ghi) SOUNDS SETTINGS.
3.Press (button 1@) CALL SOUNDS. or Press (butoon 1@) CALL RINGTONE to get new ringtones from "GET IT NOW" (GET NEW APPLICATIONS) or choose from the pre loaded ringtones.
4.Press (button 2abc) CALL VIBRATE to turn Call Vibrate On or Off.
5. Press OK to save settings
Aug 10, 2008 | Samsung SGH-E630 Cellular Phone
NEC Dterm 80 calls won't go to voice mail
for us i just found this out.
1.Fwd B/NA
2.1 - 1:set-0:cancel
4.200
5.speaker
after 4 rings it goes to voicemail
this works for us.
i hope it works for others too.
turn this feature off
1.hit fwd b/na
2.0:cancel
3.exit
4.exit
should see the normal display then.
Jul 17, 2008 | NEC Dterm DTP 16D-1 Corded Phone
Freezing
try taking the back cover off then cleaning them out (buttons) they may be stuck try it and write back :)
Apr 12, 2008 | Nokia 5300 Grey Cellular Phone
Iphone Freeze
My iphone froze up today, it just gave me a half lit screen and I couldn't even turn it off, nothing would work.  I held the home button and power off button at the same time for several seconds and this seemed to make it worse.  I did the same thing again, and it restarted the phone.  Nothing lost except for 3/4 of the battery life for some strange reason.  All is good, my phone is back!
Dec 11, 2007 | Apple iPhone Smartphone
Camera wont stay on, please help
Possible that the Lens Mechanism is out of sync. If its still within warranty just bring it in and have it serviced. If not I may be able to help you out but it requires dismantling the camera,..
If any one knows a quicker and easier way maybe they can post it here But as far as experience goes thats what happened with mine,
Hope this helps
Oct 12, 2007 | Casio Exilim Card EX-S600 Digital Camera
Nokia 5800 XpressMusic Smartphone Logo
Top Nokia Cell Phones Experts
270rexton
270rexton
