Question about LG WM-2277HW Front Load Washer
My machine keep blinking LE. What does this mean?
When this happens to me it means the filter needs to be cleaned out.
Posted on Dec 17, 2009
  • 1,543 Answers
LE is Load Error. First try unplugging the machine for a few minutes and then retry a cycle (with a slower spin spped for that load). If you still get the LE error:
The Hall sensor (part number 6501KW2001A) has failed. The hall sensor is rather easy to replace, and is covered by a seven year part warranty (in the US). Take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Snap new sensor on and reassemble. Usually takes under a half hour. On a difficulty scale of 1 - 10, it might rate a 4. This should be a Fix-Ya for your machine, and at basically no cost!
In the US, find a service provider using your zip code at http://us.lgservice.com/index_b2c.jsp or call LG at 800-243-0000 800-243-0000
Posted on Dec 11, 2009
Water fills machine will not run . Get LE blinking
LE is usually quite logical stands for lid error... This means the lid or the switch that operates when the lid closes is not working. The machine is set to not wash if the lid is not closed....a safety issue. SO check out the lid switch inside of the control panel, but only if you are qualified to do so OR call a licensed electrical person Good luck
Apr 25, 2011 | LG Washing Machines
What does a blinking LE mean?
The internet is rife with people with LE errors on LG Washers please look at links below, but this is what it "officiially" means: dont forget to vote ta
LE LOCKED MOTOR ERROR
• The connector (3-pin, male, white) in the MOTOR HARNESS is not connected to the connector (3-pin, female, white) of STATOR ASSEMBLY.
• The electric contact between the connectors (3-pin, male, white) in the MOTOR HARNESS and 4-pin, female, white connector in the MAIN PWB ASSEMBLY is bad or unstable.
• The MOTOR HARNESS between the STATOR ASSEMBLY and MAIN PWB ASSEMBLY is cut (open circuited).
• The hall sensor is out of order/defective.
http://www.howtomendit.com/answers.php?id=28214
http://applianceguru.com/forum2/7726.html
Thanks to
http://applianceguru.com/forum2/7726.html#ixzz1CwXM5vaa
Feb 03, 2011 | LG Washing Machines
What does error code LE mean?
Here is a tip that explains what the LE error code means.....
LG Washing Machine LE Error Code or Fault Code
heatman101
Sep 20, 2010 | LG Washing Machines
My 6-month old topload WF 8702CPG keeps stopping in the middle of the cycle with the code LE. Going crazy tyring to figure out what's wrong. Error code not in the manual. What does it mean and how do I...
this means the lid safetey switch is a bit out of adjustment LE means Lid Error. if you press down on th lid it might take the error away while you are pressing. without breaking the lid. This will prove the lid error. A warranty call may be necessary . 6 months old must be under warranty Good Luck
Sep 11, 2010 | Washing Machines
When I start my LG washing machine it gives me an LE blinking light what does this mean?
LE on your machine means that the hall sensor or motor is faulty. the hall sensor is located on the motor. please reply if you need further help.
May 23, 2010 | Washing Machines
Error code is LE. Washer fills up with water and
If water runs in when the machine is OFF but stops when the tap is turned off it means a faulty watervalve.replace water valve. Probably a double valve. Dont mix up the hoses or the wires........Nomess
Apr 18, 2010 | LG WM1812C Front Load Washer
I keep gettine the letters LE come up and my machine wont work whats does LE mean
if this is a LG washing machine code LE is motor fault call engineer
Feb 11, 2010 | Washing Machines
My LG TROMM reads a blinking LE message
motor locked...not and easy fix but if you want to give it a go let me know...onthejob
Jan 25, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG WM-2277HW Front Load Washer Logo
241 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
