Question about Electronics - Others
Is the fan on the inverter 600 W supposed to run continually?
  • 478 Answers
Depending on which one you buy but yes it has to keep the transistors from burning up so in order to do this they attach heatsinks on the transistors and the fan blows off the heat off the heatsinks
Posted on Dec 11, 2009
Samsung refrigerator model SRS 619 DHSS fridge fan runs continuously when door is closed, open door & fan stops. on fridge side
Fan is supposed to stop when door is opened. Continuous running could bevsensor issue if all else is working properly
Aug 31, 2018 | Samsung Refrigerators
2005 Honda CBR 600 RR cooling fan stays on
Hi, Evan and the usual suspects are:
1. Blown fan fuse.
2. Faulty thermostat.
3. Faulty thermal switch.
4. Faulty fan relay.
5. Faulty wiring or connection from the thermostat to the fan.
6. Faulty or damaged fan.
7. The cooling system needs bleeding.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Fan is ALWAYS on temp sensor is OK CBR Forum Enthusiast forums for Honda...
cooling fan will not turn off once it comes on Honda CBR1000 Forum 1000RR...
2005 2006 Honda CBR600RR Service Manual Moto Data Project https://www.partsfish.com/page/oem-parts-for-honda
http://owners.honda.com/assets/ownerlink/model/own_man/powersports/2007/2007_cbr600_rr.pdf
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jun 03, 2018 | 2005 Honda CBR 600 RR
ERROR E03 WHATS IS MEAN ON MY CONVERTER 600 WATTS ELIMINATOR
Hi, here is the error codes that I could find for you, it seems you are overloading the inverter. That means you cannot connect a kettle or other heavy load to the output. See all error codes below, hoep this helps.
Problem: The AC load will not operate, error code shows on digital
display and alarm is sounding.
Error Possible Cause Solution
E01 Low voltage shutdown because battery is discharged.
Recharge battery. Shorten cables or use heavier cables.
E02 Over-voltage shutdown because of high input voltage.
Verify the charging system is properly regulated and the battery
is 12 V nominal.
E03 The AC product(s) connected are rated at more than the
inverter's continuous power rating; overload shutdown has
occurred. Use a product with a power rating within the inverter's continuous power rating (see Table 3).
E04 The inverter has overheated due to poor ventilation.
Overheating shutdown has occurred.Turn inverter off and allow to cool for 15 minutes. Clear blocked fan or remove objects covering unit. Move the inverter to a cooler place. Reduce load if continuous
operation is required.
E05 The AC products connected have a surge power that exceeds
the Digital Inverter's surge capability or the AC products connected are short-circuited and shutdown has occurred.The products exceed the inverter's surge capability. Use a product with a starting surge power within the Digital Inverter's capability.
Nov 14, 2014 | Cameras
Fan relay switch
The fan relay could be defective, especially if the fan continues to run after shutdown and drains the battery.
Nov 14, 2013 | 2007 Chrysler PT Cruiser Touring Hatchback
I recently purchased a schumacher 410w inverter, while it came on right away and powered my electrical device the cooling fan never came on. Is the fan supposed to run all the time, once its connected.
I recently purchased a Schumaker 410/820 watt inverter. I immediately hooked it up to a brand new deep cell batery I had purchased just prior to receiving this inverter.
I plugged in several devices to make sure the inverter worked and to get some idea of what devices I can expect this unit to handle.
I noticed that the fan only ran when I plugged in a device that drew a certain amount of power from the unit. I also plugged in a CPAP unit to make sure the inverter would operate the unit properly, and noticed that the CPAP only drew 38 to 40 watts of power and the cooling fan on the converter never came on. When I plugged in an oscillating fan it drew around 128 watts from the converter and the cooling fan immediately came on when I turned the fan on. Based on that, I would assume that the cooling fan in the converter only runs when there is enough power being drawn through the inverter to cause the inverter to heat up enough to cause possible damage to or failure of the inverter. I haven't taken the time to find out the power draw at which the cooling fan will run. Hope this helps.
Jul 10, 2011 | Schumacher 410 Watt Power Inverter...
The fan at the back of my inverter is running continuously, can you please let me know what might be the problem and how to fix it
If you have it pushed against someting or have too many things around it, it may not be getting enough air to keep cool. That will cause fan to keep running to keep inverter cool.
May 10, 2011 | APC DC to AC power inverter - 150 Watt
Is my Behringer Powered Mixer PMP2000 cooling fan suppose to run continuosly. It has a distracting hum in our small church. I don't remember it always running (fan) when we first started using it? Help :-[
Sorry, the fan is thermally controlled and USUALLY will run at low speed when unit is lightly loaded. In hot weather or driven hard it will run faster and louder.
Whatever you do, do NOT block airflow... these are a dual 400 Watt continuous amp (600 a side peak) and they need to breathe !!!
If you can duct cool air to it, that will help. You could also try sound absorbing baffles while maintaining adequate clearance for airflow.
Aug 20, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
Fans in refer/freezer run continuously
it suppose to run so long the compressor is running it goes into defrost every 8 or 10 hours or it shuts off if it reaches temp but if you can hear the compressor running and the evap fan aint running somethings definitly wrong
Nov 03, 2009 | Kenmore Refrigerators
Motorcycle running a little hot
The fan comes on around 212, when you put a full exhaust, the bike needs more fuel it needs a remap. They say that the stock computer can be flashed but you need a power commander and a BMC race air filter
Mar 30, 2009 | 2008 Suzuki GSX-R 600
Electronics - Others Logo
207 people viewed this question
Top Electronics - Others Experts
Marvin
Marvin
Tom Chichester
Are you an Electronics - Other Expert? Answer questions, earn points and help others
