I have the Royal SC120 model. The shredder does
I have the Royal SC120 model. The shredder does not pull in any paper but makes noise?
  • 610 Answers
1 or 2 gears are broken. royal doesn't make many replacement parts for their machines, might try calling royal at 1-800-222-2310. I would recommend replacing unit with a Fellows brand shredder. royal also makes Ativa brand- don't buy it either.
Posted on Dec 11, 2009
I have royal px110mx and it won't shredd my papers. When turned on and put a paper, it will be making noise and not shredd the paper. Can someone bail me out.
Your Royal shredder probably hasn't been cleaned since the day it was first used. Take a look at the shredding mechanism and you will find bits and pieces of everything. A thorough cleaning should get your shredder working again. Be prepared to spend considerable time on maintenance.
Jul 20, 2016 | Royal Office Equipment & Supplies
Where can i buy a replacement basket for my Royal SC120 12 sheet crosscut shredder
you may get one from the manufacturer spares on line
other wise take the top opening measurements of the container and you may get one from you local hardware shop in the plastic container section that will do as a replacement
Sep 01, 2015 | Royal 12 Sheet Cross Cut Shredder SC120
Makes grinding noise and does not pull the paper in or shred. I have pulled out all bits of paper stuck between the teeth. I'm afraid this thing is toast
This type of shredder can get clogged so badly, the material has to be removed with a utility knife. This is especially true if someone has tried to shred coated stock or, worse yet, credit cards. The noise you are hearing is the mechanism bouncing over clumps of residue jammed in-between the grinding "teeth".
Apr 18, 2015 | Royal 1200MX 12 Sheet Strip Cut Paper...
Royal sc120 shredder wont run.. Paper jammed in head and cannot remove it--no reverse or forward will work.
This is the most common problem..."too much paper".
If it won't go in either direction the only option is to open the cutting head of the machine(after unplugging) and to manually try to turn the gears to un-clog the paper.
Once you have cleared the paper from the cutting blades see if it still turns...see if any plastic gears have been damaged. Plug it back in and see if it runs...if it dosn't you may have blown the PCB in which case you should contact Royal at 1-800-524-0799 regarding replacement parts.
Jun 14, 2011 | Office Equipment & Supplies
My royal sc120 shredder will light up but there is no sound will not run. I have cleaned out clogged bits of paper. What could be wrong?
Shredders have a reputation for being very unreliable...they often just quit like that...
You can try also to blow it out with a can of compressed air, but it probably won't help... not much else that you can do...
heatman101
May 27, 2011 | Royal Sc120 Shredder
My shredder won't start. I emptied it and then when I put it back together it didn't work. Any ideas?
Sounds most likely that you dont have the waste bin back in properly...do a double check there.
Feb 15, 2011 | Royal Sc120 Shredder
I have a Royal RL170MX shredder. It has started
Try putting some oil on a sheet of paper and then shredding the paper with oil on it.
If that dosn't fix it....take cover off....(with the unit unplugged.) and check plastic gears in drive train.
May 20, 2010 | Royal RL170MX Shredder
Televison & Video Logo
413 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
