Question about Delta & Single Handle Shower Faucet
How do I remove the cold water handle?
How do I remove the cold water handle on a Delta shower facet?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 35 Answers
You will need a set of std allan wrenchs.There should be a small set screw behind the portion of the handle that you grab onto .Its not nessisary to remove it,only loosen it.Then gentlypull and wiggle the handle ,it should come right off.
Posted on Dec 12, 2009
How do I replace a Delta shower faucet with a new one?
should not be necessary to get behind the shower stall as there should be a hole big enough to remove /replace the facet insert
call a plumber in as it may be corroded in place and may require specialist tools for the job
get a quote first
Jun 30, 2016 | Delta & Single Handle Shower Faucet
Can't get both hot water running at the same time. Delta Shower faucet
  • The spool and sleeve, the part of the Scald-Guard pressure balance valve that blends the hot and cold water, is not working properly. This can is caused by mineral deposits that build up over time resulting from hard water. To fix this, follow the steps below based on your model.
  1. Shut off water supply.
  2. There are two types of valves. Choose one or the other below depending on your series.
  • 1300-1400 Series: Remove handle.
  • 1700-1800 Series: Remove temperature knob, cover and handle.
  1. Twist and pull sleeve to remove it.
  2. Unscrew brass bonnet nut.
  3. Remove cartridge.
  4. Soak cartridge in a 50/50 vinegar and water solution for 24 hours to remove any mineral deposits.
  • **NOTE** Unless both hot and cold water supplies are turned on, the pressure balance valve will allow only a dribble of water to flow through the valve.
  • I have put up a picture to make disassembling it just that much easier for you.
Regards, Tony
May 23, 2011 | Delta & Single Handle Shower Faucet
Have hot water in the bathroom sink spigot, but the shower is the single handle and turned on all the way, water is not hot...too much cold mixing, How do you adjust it?
You need to take the handle off...ususally held on with a small allen screw on the bottom side of the handle. After removing the handle there should be a dial setting.
Feb 18, 2011 | Delta & Single Handle Shower Faucet
I have an older single handle Delta shower valve, and I am only able to get good water pressure on cold water (which is opposite of the normal right hand). Can you suggest a solution?
A rebuild kit for a shower is pretty cheap for delta. the actual ball behind the handle maybe wore and not allowing it to seat properly and restricing water flow hot side.
Also if you take it appart the 2 washers and springs you might as well replace them also.
Replace washers and springs and the ball with shaft that handle fits to.
Shut off water before taking appart.
May 07, 2010 | Delta & Single Handle Shower Faucet
I installed this delta shower set & water
remove handle and adjust the cold and hot clips one is set to open to much if u still have the paperwork in it will show how to adjust it also
May 05, 2010 | Delta Home
Adjust the hot & cold water for delia monitor 1700
Remove handle and check to see if there is a dial to take out to repostion back in to adjust cold and hot water flow. take it out and move it a little put handle on and turn on see if it changes,
I believe I have a delta monitor shower faucet. I am wondering why the hot water pressure is less than the cold water pressure. Also, I am wondering what size hex head I need to remove the lever so I can...
It takes a 1/8" allen wrench to remove handle. To increase hot water flow remove plastic dial that sets temperature. It is right behind handle and slides off stem for easy adjustment.
Remove indicator and replace about 1/8 to 1/4 turn counter clock wise to increase to hotter temperature.
Apr 26, 2010 | Delta & Single Handle Shower Faucet
Delta & Single Handle Shower Faucet  Logo
164 people viewed this question
Top Delta Home Experts
Mike
john h
Tim Whalen
Are you a Delta Home Expert? Answer questions, earn points and help others
