Question about NetGear Wireless-G USB Adapter (WG111NAWG111US)
We are trying to set up a wireless-g USB adapter to a notebook. We already have another computer hooked up to the netgear. The notebook does not have a CD rom drive so do we need to download it from the main computer and hook it up that way? Thank you for your help.
    Novelist:
  • 108 Answers
If you are using windows and it dosn't have a driver of some sort for the wireless dongle (USB adapter), then you will have to hook up the computer directly with a "Wired" network connection, (Perhaps using the connection from the other computer), to download a driver.
If Windows does have the driver and it's working. Go to your Network Connections folder, and into the Properties of the Wireless Connetion and set it to use, "Windows Zero Configuration Tool" to manage this connection; as opposed to a wireless management tool included with the device.
An option should be around there that allows you to "View Available Wireless Networks". Take that option and look for your Router's SSID, or name. It should be the one with the strongest signal.
Double click it, or select Connect.
You will need the security settings here.
Enter it if you know what it is.
Copy them from the other computer's advanced wireless network settings, or if the other computer is a Wired Network computer, then browse with the Internet browser to it's network connections "Default Gateway" address, Usually 192.168.x.x where the x's are 0 or 1.
Get the Default gateway by opening a Command Window, (Command Prompt / DOS prompt) and typing:
ipconfig /all
This will list the network connecitons IP addresses, and Default Gateways.
Once in the Default Gateway on the Web Browser, log in and look for the Wireless security settings.
Get the Key listed there, and use that on the notebook wireless conneciton.
Hope this helps,
Cheers.
Posted on Dec 11, 2009
I just bought the NetGear wireless adapter today. the process runs smoothly until it asks me to hook the wireless adapter. A box pops up stating "detecting wireless adapter" it stays like that...
It looks like your NetGear WNA3100 is dead out of the box.
The software looks like it operating correctly (runs the installed diag, tries to detect, etc.), but
the software isn't having any luck finding the hardware.
The reason that the adapter is disabled in Device Management, is that the software seems
to have correctly installed the driver, but Windows couldn't detect (plug & play) the device, so
Windows didn't enable the device driver - Windows won't load a driver for a non-existent device.
Other (remote) possibilities:
(a) Wi-Fi adapter plugged into a bad USB port. - try another port.
(b) there's a little corrosion on USB contacts of USB port or WNA3100. Try plugging adapter
in and out of the port a few times (this shines up the contacts a bit).
(c) there's a slight misalignment of contacts within the USB connector or either the laptop, or
the WNA3100.
Your fix may be returning the NetGear WNA3100 to the retailer for an exchange.
Sep 04, 2011 | NetGear WirelessN 300 USB Adapter WNA3100
I have several computers in my house, and just purchased a Netgear N600 High Performance Router. All computers easily pickup the signal and connect to the new router. However, one of my computers using a...
you might try moving your computer closer to your router
make sure your routers and your dell 1450 settings are correct ie:password user name,firewall settings to allow your internet to connect also test the lead/s whether usb or ethernet if applicable
hope this helps
Jan 26, 2011 | NetGear WNDR3400 N600 Wireless Dual Band...
Netgear WG111 USB adaptor does not work
-- check the device manager of your computer
-- for win xp - go to right click on my computer - manage - computer management - device manager - on the right hand side that the netgear adapter is listed under network adapters or other devices
-- check the status that its working properly
-- then upgrade the latest drivers ...
-- follow the link ::
http://kb.netgear.com/app/products/model/a_id/2556
and try to connect ..
Mar 26, 2010 | NetGear : WG111 54 Mbps Wireless USB 2.0...
My Netgear 54 Mbps WG 111 wireless adaptor briefly connects with my Access Point, but then disconnects as soon as the link is established. This happens intermittently every 3-5 seconds. I've already...
In this case follow the steps:-
a)Try another computer or try all the ports on the same computer.
b)If the problem still presist then try to run the computer on a safe mode and check the connectivty.
c)Upgrade the drivers of the adapter from the netgear website.
Following direct links will be useful as the instuctions of upgrading the drivers are enlisted in there:-
For WG111v1 or WG111(Version 2.1):-
http://kb.netgear.com/app/answers/detail/a_id/711
For WG111v2 (Version 3.4.0):-
http://kb.netgear.com/app/answers/detail/a_id/713
For WG111v2 (Version 1.5.0):-
http://kb.netgear.com/app/answers/detail/a_id/2733
Dec 05, 2009 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Netgear wg111 usb adapter
Since you already did a uninstall and re installation of your adapter and still the same problem, you may want to try updating the driver of the adapter, so uninstall and reinstall the adapter using the latest driver from the manufacturers web site....
Nov 30, 2009 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Have wireless usb adapter netgear wg11v2. I think
Go to netgear.com site download the driver (if you don't already have it) for your system and device. Install driver and software before you hook ujp device then plug in when it tells you to.
Sep 15, 2009 | NetGear WG111 802.11g/b Wireless Adapter
Can't set up Netgear WG111v2 wireless adapter
You can download the software you need from Netgear's site. All the download and installation instructions are in one place for you.
May 26, 2009 | NetGear USB 2.0-Stick WiFi 108 Mb WG111T...
My computer freezes when connecting WIFI adapter
Does this happen if you try connecting it into all USB ports? Try another USB port. Do you know if your USB ports are 2.0?
Mar 30, 2009 | NetGear WG111T 108 Mbps 802.11g Wireless...
Wireless USB Adapter not wanting to open.
Hi This problem usually happens when the usb adapter as been plugged in before the software as been installed, try uninstalling the software restart your computer then reinstall your software, once finished close computer down plug adapter into usb port then re-start the computer hopefully this will work and you can configure the wireless settings via Netgear Network.
Aug 07, 2008 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Netgear 108 Mbps wireless usb 2.0 adapter wg111t
i had the same problem. i tryed downloading the sofware from other computer and install it on the wireless computer. finally i just connected it directly to a lan line and update drivers with windows
Apr 08, 2008 | NetGear WG111T 108 Mbps 802.11g Wireless...
Computers & Internet Logo
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
