Question about Eureka Whirlwind 4388 Bagless Upright Cyclonic Vacuum
HOW TO REPLACE BELTS - Eureka Whirlwind 4388 Bagless Upright Cyclonic Vacuum
  • 701 Answers
Here is a link to the belts you need and a manual you can view which has instructions:
Eureka 4388 Belts
Owner's Guide (1,068K download)
Posted on Dec 11, 2009
How to Change belts on dc33
The belts are in the clutch. You will need to disassemble the clutch to replace the belts. It's easier to replace the entire clutch. First remove the brushroll, then remove three screws and the cover over the clutch assembly, remove the belt around the motor shaft to pull the clutch from the nozzle housing. It is wise to replace brushroll if it's worn or frayed. I have a tool available to make putting the brush roll back in easier. I also have belts, clutch, brushrolls and filters available if needed.
May 12, 2018 | Dyson Vacuums
How to replace belt on a bissell 66e1 pro heat lift off pet carpet cleaner
There are two belts on your model. Remove the screws on the end cap assembly on each side to remove the assembly to gain access to the belts. Remove the screws holding the brush roll assembly to remove and replace the belts.
Jan 08, 2017 | Bissell Vacuums
I have a Dyson DC07. The roller wasn't spinning so I cleaned the brush of hair and fibers. That SEEMED to do the trick. But while vacuuming I noticed again that the roller brush was not spinning AGAIN. The...
You may need new belts. Belts lose elasticity from being stretched. The clutch must be removed and disassembled to change the belts. It's easier to replace the clutch. The belts will be tight and It's difficult without a special tool. While you have the brushroll out pull the shaft out of the center and clean hair and debris from it or replace brushroll if worn or frayed.
Dec 22, 2017 | Dyson DC07 Bagless Upright Cyclonic Vacuum
How do I replace the belts on a Dyson DC04 purple
That model has a clutch unit from which the two drive belts are located. It is a technical job to strip that unit down to change the belts, so the easier solution if you have a snapped belt, is to replace the clutch unit (that comes with belts on it). A recycled one represents better value for money, and you can get one here: Dyson DC04 clutch unit.
Nov 07, 2010 | Dyson DC04 HEPA Bagless Upright Cyclonic...
Replace belts
1-866-MY-DYSON
(1-866-693-9766)
Here is the contact #, I searched the entire site and did not see the belts. Maybe you should call and see if they are special order or something.
May 23, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
THE ROLLER WON'T GO AROUND. THE EXTRA ATTACHMENT WORK WELL, BUT THE ROLLER STOPPED GOING AROUND.
HI There,
This is definitely a problem with your belts. This Hoover Windtunnel Self-Propelled models has a poorly designed belt system that frequently goes bad. Most customers will have to replace the belt once every 8-12 months, some even more frequently than that.
There are 2 belts on this machine, and it's recommended that you replace both belts at the same time. If you just replace one of the belts, this will cause the other belt to go bad quicker.
If you don't already have the replacement belts, here are links to these belts through us:
Hoover WindTunnel Self Propelled Belt Set (38528-034 & 38528-035)
Here's a helpful video that we've recorded that shows you step by step on how to replace these belts, as well as how to do the basic maintenance on the roller brush to prolong the life of the belts as long as possible.
How To Replace the belts on a Hoover Windtunnel Self-Propelled:
Please be sure to rate this repair helpful, or leave feedback if this video helped you fix the problem. If you're still having problems, please just use the comment field on the repair page and leave a little more specific information on what happened when you inspected the belts, and I'll be more then happy to do some further more advanced diagnosing for you.
By rating the repairs helpful, and leaving feedback, this ensures that Fixya experts continue to leave free repair solutions rather then just leaving premium answers, or repairs that customers pay to have answered. This is also really appreciated.
Chris Jones
GoVacuum.com
Apr 24, 2010 | Hoover U6437-900 / U6439-900 Windtunnel...
Water does not come out of the bottom like it used to. It comes out of the accessory hose. I don't know how to change belts, etc.
You need to replace the belts. Here is a link to the belts you need, they come with printed step by step instructions.
Bissell 1699 Belts
Feb 10, 2010 | Bissell 1699 ProHeat Clear View Upright...
How do I replace the drive belt in the hoover u6401?
Remove the plate from the vacuum's underside. You will see fourscrews or two clips that attach the plate to the vacuum. Removingthe plate will give you access to where the belts are running. Remove the old belts and replace with new belts. The hoover self-propelled models use two different belts. One is a flat belt Hoover #38528035 and the other is a V belt Hoover #38528034. You can find these belts at www.vacbelts.com on these pages:
http://www.vacbelts.com/hoover-38528035-belt.htm
http://www.vacbelts.com/hoover-38528034-belt.htm
Oct 14, 2009 | Hoover Vacuums
Belt keeps coming off.
The dowel that the belt attaches to should have a slight "V" in it. This prevents the belt from slipping off. Check that, if it isn't there than you may need to replace the dowel. I own a Bissell and every 6-8 months replace the belts anyway as preventative maintenance is my philosophy.
May 10, 2009 | Bissell 37604 Lift-Off Pet Bagless Upright...
Eureka Whirlwind 4388 Bagless Upright Cyclonic Vacuum Logo
607 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
charlesjo336
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
