Question about LaCie External USB 2.0 500GB 7200 RPM 500 GB Hard Drive
I have a Lacie 2 Big Quadra. I can see them under
I have a Lacie 2 Big Quadra. I can see them under device manager, but not disk management. I need to format this drive. How do I do it? The operating system is windows xp.
  • 242 Answers
SOURCE: How to format the LaCie 500GB d2 Quadra for Windows XP??
This way it should work...
Connect your drive to the computer...
Go to: Start > Control Panel > Administrative Tools > Computer management.
A new window will appear...
Select Storage > Disk management on the left of the window.
Now you will see the different drives that are connected or part of your system.
One of the drives listed there is your LaCie, i think you'll recognize it by name...
Right-click on it, and select 'format'
In the new window, select the new volume label (as you like it), the file system (use NTFS), and set allocation unit size to default.
Make sure 'Perform a quick format' is not checked...
Then click OK. Your drive will be formatted now... Don't interrupt the process
Posted on Mar 31, 2008
SOURCE: Blinking Power Light
My Disk has been formated.Not recognized by Windows.How can,I reset the USB.
Posted on Apr 06, 2008
  • 18 Answers
SOURCE: Will reinstalling Netowrk Drive (E.B.Disk) delete everything on
Wait.. If you have this hard drive it should be connected using network adapter right? you make it sound like it is connected through USB. Reinstalling the driver on your pc is not a bad idea and it will remove the hard drive files. I suggest go to another pc and search from there. Also, find out the network ip address of that hard drive. If it is plugged in to the network switch then it would be easy for you to access the files even without installing the drivers.
accessing the drives and shared folder:
start-> run and type in \\harddriveIP\sharedfolder
if you don't know the ip use the software lookatlan to search for it.
Posted on Dec 11, 2008
beast_b9
  • 113 Answers
SOURCE: WIndowx XP can't see my LaCie Big Disk 3TB
did you checked disk management? is it formated to basic or dynamic?
Posted on Jul 10, 2009
  • 4 Answers
SOURCE: I'm running Windows XP professional.
1.
log onto d computer as administrator
2.
start->my computer->manag
3.under storage->disk management
4.ef intialize ndcovert disk wizard appers click next ef not skip to step 8
5.on d selct to disk intialize page click next
6.on d select to disk covert page click next
7.on completing dhese two click finish
8.right click u r external drive nd click format
9.in d format dialog box type d name for u r external hard drive nd then click ok
10.click ok again
Posted on Sep 14, 2009
4big Quadra drive not appearing in disk utility or LaCie desktop manager
Could be defective. Try swapping power cord and usb cable with know good ones. You could also plug it into a different (known working) usb port.
Good Luck
Nov 28, 2013 | LaCie 4TB Biggest Quadra U SATA II Hard...
I am trying to set up the LaCie d2 quadra. I follow the steps in the manual but nothing is loading to My Computer.
you will need to go in Disk Management and format the drive first then it will be available in My Computer.
Regards,
Dec 30, 2010 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
I have a 1TB LaCie 2Big Quadra. It has 2 500GB and runs on RAID 1. I replaced both 500 GB LaCie drives with 1.5 TB LaCie drives, but my computer only recognizes the original 500 GB. I formatted both...
I have the same problem too on my 2big form lacie . If I use 2x 1,5 tera disk in "fast mode" or in "big mode" my disk manager only shows 746 gigs available (it should be at least 2,5 terra).
If I use "safe mode" so my system can see 1,3 tera available, wich is normal for a raid mirror configuration.
I hope to find a solution quickly.
Dec 13, 2010 | LaCie Big Disk Extreme 500 GB Hard Drive
Lacie won't register that it's empty
Click Start
Right-mouse click My Computer
Click Manage
Double-click Storage
Double-click Disk Management (Local)
Right-mouse click on the 60GB partition
Choose Delete Partition
Click on the 300GB of "unallocated" space.
Create a partition that "spans" the 300 GB.
Format the new partition.
Jan 16, 2010 | Computers & Internet
Acronis partitioned LaCie d2 Quadra 1TB. Tried to eliminate the partition and ended up with 100% unallocated space. How can I repair this problem? Thanks, Tom
Go to Start > Control Panel >Administrative Tools > Computer Management > Storage > Disk Management
Choose your LaCie drive. Right click on it, and choose mark the partition as active.
This should give you one partition of 1TB in size.
Nov 29, 2009 | Computers & Internet
I have the same issue
Win XP will not be able to recognize whole 3TB storage drive. You need to use some kind of 3rd party utility and then partition it and format as well.. AS a note win xp size is limited up to 80-100 GB.
Sep 22, 2009 | LaCie 3 TB Biggest Quadra External Quad...
I'm running Windows XP professional. Have plugged in my Lacie d2 Quadra (500 GB). Device manager shows that it is working properly, but it is not initialized and it doesn't show up on my windows...
1.
2.
10.click ok again
Sep 14, 2009 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Jul 10, 2009 | LaCie 3 TB Biggest Quadra External Quad...
Disk manager only sees 25% of it
your partition size is incorrect not disk manager
Apr 27, 2009 | Computers & Internet
LaCie External USB 2.0 500GB 7200 RPM 500 GB Hard Drive Logo
161 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Marvin
Marvin
Alun Cox
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
