var searchHostDomain = 's.fixya.net';
var searchHost;
if (searchHostDomain.indexOf("beta") != -1)
searchHost = searchHostDomain + '/Handlers/Search';
else
searchHost = searchHostDomain + '/HTTPHandlers/SearchAutoComplete';
Ask My Experts
Problem with Whirlpool Duet GHW9150P Front Load Washer
whirlpool washer overflows at detergent dispenser
when I turn my washer on and it starts to fill up with water approx. 20 seconds later water backs up through the detergent dispenser and all over the floor
Posted by j5adamson on Sep 04, 2009
$(".meta").find("img").brokenImage({ replacement: "http://c.fixya.net/fixya20/images/icons/expert-not-found.jpg" })
This problem should be removed because:
It's spam/self promotion
It's in the wrong category
It's irrelevant
It's illegal
It's inappropriate/offensive
Other Reason:
Whirlpool Washer Repair
Whirlpool washer repair specialist Access to Whirlpool parts Fast and friendly response
Solutions (4)
Best Solution
Hello, I worked on a problem like this a few days ago. Your problem is going to be a blockage in the inlet to the drum. To fix this problem find the inlet pipe normally located above the door behid a flap of rubber..push your fingers up there to see if you can feel a blockage..If not your going to have to remove the lid of the machine to access the pipe that leads from the detergent drawer to the tub. Look at the rear top of the machine..You will see three screws....remove them and push back and lift the top panel (lid) now you should be able to access the pipe. Pull the pipe off and clean it out, i suspect you will find a sock blocking the pipe :) If you have any other questions or concerns please feel free to comment again. Good Luck! Mike
Testimonial: "You know what? Your advice was down to a tee. Thank you so much and my wife is happy too. Thanks john"
+ Add a comment
you have a blockage in the fill hose, probably a bleach lid cap cardboard circle or detergent lid cardboard from the cap, or another foreign object, remove the object by removing the top of the machine, remove screws in back at top slide lid back remove the dispnser by pressing down on tab and pull it all the way out, remove single screw next to dispenser, see if you can remove the tube under the dispenser box attached to the tub, if not remove dispenser box and hose attached at bottom find blockage and re assemble, with a stroke of luck you may be able to remove the object by reaching in where the dispenser tray was.
