Question about Dishwashers
I have a GE side by side Model #GSH25KGPA refridgerator with a water & ice dispenser. I cannot get the ice to dispense. Water works fine. I removed the ice storage drawer and top shelf and note that the drive mechanism will not rotate either clockwise or otherwise. My manual indicates I should be able to rotate it clockwise a 1/4 turn. Can you help?
  • 1,543 Answers
If you can not turn the U shaped drive by hand, you most likely have a frozen auger drive motor. Just thawing it out will not cure the problem, as moisture will re-freeze it again. You will need to replace the motor, part number WR60X10258 for your model.
Posted on Dec 11, 2009
Testimonial: "You said I need a new Motor #WR60X10258 for my icemaker. Good, where ... GE or who? are they difficult to install? Thanks"
  • Carl Schulzetenberg
    Carl Schulzetenberg Dec 21, 2009
    Most any appliance servicer / service center will be able to get it for you, or direct from GE (800-851-6200 I think) or places like C.E. Sundberg http://www.appliance-parts.com/customers...
    have this item in stock at several of their locations and will sell and ship direct to consumers also.
    Working in a narrow freezer side of a S x S is always a bit of a pain, but all you need is a 1/4 inch nutdriver or socket, and possibly a phillips screwdriver to remove the drive motor mounting, unplug it and then work on it on your table. (sometimes the locking electrical plugs take a bit to figure out the release) The big U drive unscrews off the motor shaft. On a scale of 1-10, it's about a 4, due to the pain of working in the narrow space.
Ice Maker working, but water not dispensing
There are two sides to a dual water control valve. One side fills the ice maker and the other side is the dispenser. If one side goes bad you will need to replace the whole dual water control valve. If your model is the GSL22JFXLB your replacement is the=> WR57X10032 Water Inlet Valve
This part is found on the rear of your refrigerator near floor where the water from your home hooks up to your refrigerator, Thanks Sea Breeze
Mar 08, 2013 | GE GSL22JFXLB (22 cu ft) Side by Side...
I have a side by side refridgerator freezer. I have just connected the water to the ice make / water dispenser for the first time and just a short trickle of water flows into the ice cube maker - not
I would guess that you need to purge the air out of the lines and system for it to work correctly. You can hold down the water dispenser for awhile to help, but if you do nothing, it should purge itself over the next few days.
Jan 07, 2012 | GE Refrigerators
My ice maker is working fine. My ice dispenser is working fine, There is no water from the water dispenser. When I push the button, I hear a click but no water.
I had this same issue with my GE refrigerator and figured out it is a common problem with these units. The water line freezes up near the dispenser panel. Fortunately, GE has an inexpensive solution, a water line heater, that fixes the problem with little work. Check out my blog post on my ge refrigerator water dispenser not working for complete details.
Oct 28, 2010 | GE GSH25JFR Side by Side Refrigerator
I have a GE PROFILE side by side refridgerator model # PS123MGPCWW. my water and ice dispenser stop working periodically (for days at a time) and then come back on. it doesn't appear that the water...
Sounds like the water pump is bad .This is located at the back of the refrigerator. It's is a small pump and if you trace your water line you should be able to find it .Just replaced it and you should be fine
May 22, 2017 | Frigidaire Refrigerators
Model#a4425gd2aww;water dispenser stays on witout pushing cradle even when ice selection is on. This is an americana refridgerator made by GE.
Disconnect the wires on the water valve.(or unplug the frig) If the water stops the dispenser control is defective. If the water continues the valve is stuck and needs replacing.
Eric
Oct 11, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water not dispensing ,side by side gsh25sgpa
make sure the water line is not kinked behind the refridgerator.
Jul 04, 2009 | GE GSH25JFR Side by Side Refrigerator
GE refer will not dispense cubed ice
I have the same problem. My GE refridgerator won't dispense ice cubes.
May 01, 2009 | General Electric GSS22JET Side by Side...
GE GSS25SGRE side by side water dispenser...
The same thing happened to me. If you pull the refrigerator out and remove the large silver panel, you will see the water lines on the left. The line going to the ice maker was fine, but the line going to the water dispenser was split. You may have the same issue.
Jan 30, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice/water dispenser control panel
could be the dispenser board or the main board. hard to sort out without a meter. most likely the dispenser board but i have seen a dispenser board go bad and smoke the main board if that is the case you can damage the new component so check out the cost on the parts
May 07, 2008 | GE Monogram ZISS420NRSS 42" Built-In...
GE Arctica (PSS26NGSB) ice and water dispenser
need to call ge at 1800-386-1215 some of these sxs have a door insulation issue that they will either send replacement doors to an authorized service company to exchange at no cost to you or offer a rebate for a newer model. yours might be in this group
have your model and serial number out of the ref located in the refrigerator section, about 4-5 inches from the celing down the right side and call and see
Apr 12, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Dishwashers Logo
224 people viewed this question
Top Dishwashers Experts
Oloyede Monsuru
Marvin
Marvin
