The drum turns, but the unit does not heat. How do I get inside to check the heating coils?
    Problem Solver:
  • 18 Answers
You need to take the top of the dryer off. Usually clips hold it on. Then remove the dryer drum. The drum usually sits on rollers and has a pulley on it that the belt from the motor is in. The heating coil sits in back of the drum. It looks like a piece of wire and is attached to the back of the dryer via little insulated blocks. If you can not see the heater broken, do a continuity check if you have access to a meter. It should NOT read open.
Posted on Dec 11, 2009
SOURCE:
There's a slight burning smell coming from the dryer drum.
Some item may have gotten between the drum that rotates and the housing and during the rolling of the drum this item may be heating up from the friction. Check closely to see if you can find anything rubbing on the drum.
Jan 22, 2013 | Maytag PYE2300AY Electric Dryer
Dryer does not heat although power source is on and drum turns
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Sounds like your problem may be with the heating coil. Remove the back of the machine and try to locate the air duct going from the blower to the drum. Normally inside the air duct you will find the heating coil and the thermostats/thermistor. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor by removing the two wires and taping them together with electrical tape. If the coil heats up then replace the thermostat/thermistor.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Please rate me,
Aug 17, 2010 | Kenmore Dryers
Dryer not heating
is faulty. If the heating coil is ok, then: You can check the thermostat/thermistor by removing
the thermostat/thermistor. DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause
a fire, as you have removed the safety of overheat from the machine. I will include these two web
sites for parts and further help:
http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck, Hope this helps
Please do not forget to rate me, Thank you
May 27, 2010 | GE Profile DPSB619ED Electric Dryer
Gas drier Whirlpool LGR5634LQ0 drum turns, no heat. Turn off and restart, heats for a while then no heat for drying. Lint is clear, etc... Gas valve is in on position. Not sure what to do next. Check...
most gas dryers will have a problem with the 2 coils on top of the valve.
when these coils are weak or going bad, it will heat for a short while then no heat at all.
if you let the unit set for an hour or 2, it will heat again for a short peroid.
the coils are easy to replace, but do get both of them.
Mar 13, 2010 | Whirlpool LGR5634L Gas Dryer
I have a less than one year old whirlpool dryer, model number WED6600VWD. The drum works and it does have power. However, it does not generate any heat, like the heating unit isn't working. What might be...
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause a fire, as you have removed the safety of overheat from the machine.
I will include these two websites for parts and further help:
Good Luck,
Hope this helps
Nov 06, 2009 | Whirlpool WED6600V Electric Dryer
The unit will turn but won't heat
Good Luck,
Hope this helps
Nov 01, 2009 | Amana Dryers
Drum turns but no heat
Good Luck,
Hope this helps
Oct 24, 2009 | Whirlpool Dryers
Started dryer as soon as the drum started to turn it started banging. the drum is spinning but there is no hot air going into the drum. the heating element does seem to be putting off heat.
UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
#1 Problem: Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
If you have a front loading machine,
Remove the electrical box that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt, remove the drum and belt and this will expose the drum rollers.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
#2 Problem: Sounds like your problem may be with the heating coil.
Good Luck,
I hope this helps
Oct 22, 2009 | Maytag Dryers
Unit runs, no heat
Sounds like your problem is with the heating coil.
If you plan to try to repair the problem yourself, then the first thing you want to do is unplug the dryer from the electric.
Remove the back of the machine and try to locate the air tube going from the blower to the drum. Normally inside the air tube you will find the heating coil and the thermostats/thermistor.
Once you have located the heating coil, remove the two wires from it and check the coil with a continuity meter across the two terminals of the coil.
Good Luck,
Hope this helps
Oct 06, 2009 | GE Dryers
Dryer power problems
Yes, all dryers have a belt that turns the drum. Chances are the belt and heat problems are 2 separate issues.. The belt turns the drum from a motor mounted inside the unit, your electric dryer has a heater element/coils that heats the drum your clothes are in. The belt could be bad and heat element also but both at exactly the same time is rare. Try unplugging the unit for about 5minutes and see if it resets. My washer does that sometimes and I have to unplug
Aug 07, 2009 | Whirlpool WED6400S Electric Dryer
Computers & Internet Logo
14 people viewed this question
Alun Cox
k24674
