Question about SmartDisk ,80GB (USBFP80P) 80 GB Hard Drive
Does this hard drive work with older USB 1.1 ports? Or do I need to find a PCI card with USB 2.0 ports... - SmartDisk 80gb External Hard Drive ( Model # USBFP80P )
    Sergeant:
  • 146 Answers
Most drives are reverse compatable, You have not issue using this on you PC with USB 1.0
Posted on Dec 12, 2009
SOURCE:
NewerTechnology uDriveSmartDisk USB Floppy Drive (model FDUSB-M, Color Kit Edition, formerly VST)
Verbatim continues to offer support on select SmartDisk products:
CrossFire USB & FireWire Desktop Hard DrivesSOHO NAS Desktop Hard DrivesFireLite USB & FireWire Portable Hard DrivesFireLite XPress Portable Hard DrivePhotoBankUSB External Floppy DriveSelect models of CameraMate Card Readers
For online support click here:
http://www.verbatim.com/contact-login.cfm
or call technical support at 646-537-3411, Monday-Friday, 8 a.m. to 9 p.m. Eastern Time.
Verbatim Acquires SmartDisk External Hard
Disk Drive Business
Verbatim Acquires SmartDisk External Hard Disk Drive
TOKYO, (July 5, 2007) - Verbatim® Corporation and its parent company Mitsubishi Kagaku Media (MKM), announced today the purchase of substantially all of the assets of SmartDisk® Corporation\'s external hard drive (HD) and digital imaging business.
The acquisition, which includes physical assets, patents, trademarks, technology, engineering and marketing expertise, was effective on June 30, 2007.
Feb 12, 2013 | SmartDisk USB Floppy Drive Titanium...
When i plug in the usb to my computer it is not recognized and does not show anywher
If you have a SimpleTech SimpleDrive connected to your computer and you're experiencing problems with the external hard drive, there may be several reasons why it's malfunctioning. Troubleshooting your computer can help rule out common problems and the possibility that the hard drive may be defective. If you recently purchased the device and suspect there is something wrong with it, return the defective drive to SimpleTech or the reseller for a replacement. Incompatible USB Port Problems SimpleTech SimpleDrive plug and play options makes it easy for you to connect the device to your computer. But you may encounter problems if your computer's USB (Universal Serial Bus) ports are not compatible with the external hard drive. Make sure your ports are powerful enough to operate the drive. USB 2.0 ports are recommended, but if you're using an older computer with 1.0 ports, the hard drive will function much slower or you may receive an error message that the device is not compatible with your system. b> Missing External Drive Letter If you're unable to find the SimpleTech external hard drive's letter on your desktop after you have installed the drivers for the device, it's possible that the external drive may be assigned to another drive. Sometimes, the hard drive is assigned to a network drive and you may need to manually change the drive's letter in Disk Management. b> SimpleTech SimpleDrive Incorrectly Formatted b> SimpleTech SimpleDrive is normally pre-formatted for Windows NTFS (New Technology File System), but Mac users may need to copy the backup software and reformat the external hard drive for FAT32 or Mac OS to be able to use the external drive. If the external hard drive is not formatted correctly for your system, it may not function or work properly. b> External Hard Drive Inaccessible If you receive an error message that says "Drive Inaccessible," the SimpleTech SimpleDrive may not be able to read the service area of the platter. If the external hard drive emits a loud or abnormal sound, this could mean the device is failing.
Test the drive on another computer to see if it is working properly. Otherwise, the external hard drive's surface area may be damaged or corrupted.
Replacing a Defective Hard Drive You can return a defective hard drive that is under warranty to SimpleTech. The manufacturer will exchange the device if the seal is not broken. But if you break or tear the seal on the case, any warranty claims will not be accepted and the device will be returned back to you. SimpleTech will only accept the device if you contracted a commercial data recovery company to retrieve critical data from the external hard drive and the seal needed to be broken. Before returning the defective drive, you will need to secure a RMA (Return Merchandise Authorization) approval number from SimpleTech and furnish any invoices or documentation regarding the data recovery company's services
or if its a usb external drive you might need a usb 3 card installed on your computer your computer might not have enough usb output power USB 3 card will provide more power when needed to the device to gain maximum throughput and conserve power when the device is connected but is idling http://blog.premiumusb.com/2010/09/usb-2-0-vs-usb-3-0/ these can be purchased on Ebay cheap and easy to install http://www.ebay.com.au/itm/PCI-e-PCI-Express-USB3-0-Card-new-NEC-720200AF1-chipset-/330608109325?pt=LH_DefaultDomain_0&hash=item4cf9c7670d for roughly $9 or $10free postage Hope this helps.
b>
Dec 14, 2012 | SimpleTech 500GB SimpleDrive Pro External...
Won't recognize external hd
Dec 11, 2012 | SimpleTech SimpleDrive Pininfarina 500GB...
On my smartdisk firelite the conection that excepts the usb cable has broken. I need data thats on the hard drive how would I get this info off the firelite?
you can open the case and remove the hard drive and install it in a new external usb case for it.
you can find out what type of case you need after you open it. it could be either a SATA connection or IDE.
If it is a SATA and you got a SATA cable/power you could also just install it directly into your computer and grab the files you need.
Mar 11, 2011 | SmartDisk FireLite - 80GB - 5400rpm - USB...
I want to reuse this drive on a new MAC, how do I clean the old information off the drive?
Do you want to use it as an external USB hard drive?
If so connect it to a USB hard drive adapter case and connect it to the MAC and either delete the folders and filed OR format the hard disk.
Nov 25, 2009 | SmartDisk FireLite 80GB 400Mbps FireWire...
External hard drive problem.
1. The usb cable could be defective
2. The usb port could be malfunctioning
3. The drive could be defective.
Try using another usb port, or try adding a PCI card usb ports
Nov 07, 2009 | Western Digital My Book Essential Edition...
New computer won't recognize my Firelite, works on old computer
You need drivers for USB, if you remember when you bought smartdisk you got the installation disc, that you now need for a new computer.
Oct 31, 2009 | SmartDisk FireLite - 80GB - 5400rpm - USB...
External smartdisk firelite
It seems that you will lose your files. These file already
infected with virus, and corrupted it. There's no other
way but to reformat your smartdisk.
Oct 08, 2009 | SmartDisk FireLite - 80GB - 5400rpm - USB...
USB External Harddisk Detection Problem
some people say that its because of not enough power . try inserting the hard disk in other usb slots ( at the back ). onlu usb slots at the back of my pc detects my hard disk
Aug 06, 2009 | ASUS M2N-MX Motherboard
SmartDisk Crossfire Desktop Drive
Usually this is a problem with the usb port not being able to supply enough power to the drive. Often, units like this will come with two usb plugs on one cable to increase the current supplied to the drive. If the drive has an input for external power (some do, some don't), then using external power would help.
Apr 23, 2008 | SmartDisk Crossfire Desktop (xf160f) 160...
SmartDisk ,80GB (USBFP80P) 80 GB Hard Drive Logo
Top SmartDisk Computers & Internet Experts
Marvin
Marvin
Alun Cox
Are you a SmartDisk Computer and Internet Expert? Answer questions, earn points and help others
