Question about TriPro Power : UPS Pro 650VA (PSTP06) UPS System
I cant find any documentation on the power pro 650 ups, and i just had a power outage, the ups did not kick in. How do i test to see if the battery is still functional?
  • fudgster May 11, 2010
    How long have you had the UPS? Even rechargeable batteries die(3 to 4 years) and can no longer hold a charge.
    Problem Solver:
  • 16 Answers
APC Back-UPS Pro 650VA Documentation
The above link is to the APC official website for your UPS.
Posted on Dec 11, 2009
SOURCE:
Apc 650 back-ups does not boot
try turning on the power connection
Mar 22, 2013 | APC Back-UPS Pro 650 UPS System
Cyberpower 425 va When the device kicked in during
You can change that. It is designed to alart you during a power outtage. That way you will have time to shut down your servers. It will alway alarm during a power outage. But check to make sure your batteries are in good condition
Sep 09, 2011 | CyberPower Intelligent LCD CP825LCD 825 VA...
Need information
The Back-UPS is fairly straight-forward. The 9-pin connector (at the top of the back) is a serial port (RS-232) for the UPS data (when connected to a computer it will shut down the computer safely during a power outage). The next plugs are RJ-11 telephone jacks; the cord from the jack (wall) goes in on the left (some models have RJ-45 for network protection). The battery protected outlets are the three surrounded by black paint. The other three provide surge-protection only. Do not plug items like printers and scanners into the outlets that provide battery protection.
I hope this helps.
(for software, manuals and other information:
http://www.apc.com/products/resource/include/techspec_index.cfm?base_sku=BP650S&tab=models )
Apr 17, 2010 | APC Back-UPS Pro 650 UPS System
Yesterday and today one of our Smart-UPS 1400 powered off and 2 of our servers along with it. What would cause this?
may be power to the UPS went off or was not within permissible limits, hence the ups run on batteries until they were completely discharged, the servers went off because they are supplied by this ups. check the power supply to this ups, somebody could be switching it off accidentally. try to sitch the inpu power to the ups to see whether the batteries are okey
Dec 15, 2009 | NEC APC Smart-UPS 1400 (050-01803-000) UPS...
My universal battery do not have enough back up.
Cpcute,
Yes, initial charge should be for 24 hours before initial use (in general).
The UPS is an Uninterrupted Power Supply and is intended to Power your system in the case of a Main Power Failure long enough for you to Save/Backup your work and shut down your system safely so you don't lose data. Five minutes should be plenty of time to do this? It's not intended for you to continue using your system throughout the Power Outage. The UPS will/should let you know when the Battery needs to be replace, so when it does let you know, replace it at your earliest convenience and it should continue to function as it should.
Good luck.
Mar 20, 2009 | Computers & Internet
Apc ups 650va no power when connctd to ac/bt wd power in on batry
Check the relay Circuit. the relay switch must be faulty
Feb 24, 2009 | APC Back-UPS Pro 650 UPS System
Surge causing power outage
A laser printer when warming up draws far more power than your battery backup is equipped to support. Plug it into the surge protector side if you have one, or bypass the battery backup entirely.
Feb 02, 2009 | Samsung CLP 300 Laser Printer
APC Back UPS Pro 650
since the unit is not rusted ,its clear that it is OK!when battery leaks,it loses power,so is not harmfull to unit.replce the battery and keep rollin!
Aug 21, 2008 | APC Back UPS 650 (APWBK650MC) UPS System
UPS
All UPS uses some sort of battery to power the unit in the event of a power outage. Like car batteries they also have a life span which can be a couple of months to a year or so. If the UPS has been in service for some time, perhaps it simply needs a replacement battery. On the other hand, if the unit is fairly new and carries warranty, it may be to your advantage to consult your dealer and claim for a replacement.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 10, 2008 | Opti -UPS PowerES 650 UPS System
TriPro Power : UPS Pro 650VA (PSTP06) UPS System Logo
235 people viewed this question
Top TriPro Power Computers & Internet Experts
Alun Cox
k24674
Are you a TriPro Power Computer and Internet Expert? Answer questions, earn points and help others
