Question about Gateway MX8711 Notebook
Wet Display I live on a boat and a few drops of rain water got into the display . . . Now the screen has blotches of gray in it . . . I want to open the display and dry it . . . Is this a viable solution?
  • Tho_mas Jan 20, 2008
    Thank you . . . I tried your warming . . . cooling solution and the LCD is not yet 100% corrected but it is vastly improved . . . From about 50% of normal to about 90% . . . Your suggestion saved a tremendous amount of stress . . .
  • 49 Answers
If you have already experienced opening a laptop lcd just go ahead and open it but probably the water already sipped into your lcd... chances are you can still hope to manually repair it by a weired solution... or just have it replaced by your laptop manufacturer if still it got some warranty.
first turn off your laptop and open your lcd holder then gently turn over your lcd... (make sure you wont crack it or pull some cables at the bottom. take some clear cotton white cloths and sandwich your LCD with 1/2 inch of those cloths... take a hair dryer and blow the cotton until its warm enough.... let it just cool out and test your display....
alternative if you got no hair dryer you can just leave it out in the sun for 15 mins depend on how warm the day is.
note: don't do this inside a air conditioned room or you will worsen your problem cause there will be some moisture left...
rate me if his help you cause i already tried this a couple of times...
Posted on Jan 20, 2008
Suspected moisture in Furuno GPS/Plotter display
You need to determine if it's moisture or damage to the protective coating on the LCD glass. If the screen coating is damaged it will have patches or discoloration that resemble water spots like you see on windows and glasses exposed to hard water. If it's moisture between the glass and LCD you should be able to make out the tiny water droplets that are evenly spread throughout the screen. The only proper fix for a glass with damage to the protective coating is replacement of the bezel assembly. If it's moisture you can try inserting a few silica gel packs inside the unit. Don't try to disassemble the bezel (LCD/Screen) assembly. Just but the gel packs inside the 1650 chassis and give it a day or two. Otherwise, you're looking at factory repaire.
Jun 24, 2010 | GPS
The screen on our gps is messed up! Either it got
You would have to send it to Garmin unless you found a Marine Electronics dealer that had an old display in their shop. They could then replace your display. Good luck!
May 22, 2010 | Garmin Gpsmap 5012 Touch Screen...
My Nokia N70 phone display is not working,it just does not display anything.Today few drops of rain water got into my cellphone.Please help me.
open your phone and spray some perfume or sent on its display ic or on lcd then clean it with dental brush if it doesn't works then take it to mechanic and say him for heat the phone
Oct 29, 2009 | Nokia N70 Cellular Phone
Blue screen on main display
its a hardware problem, its FPC cable is tampered plz get it replaced by Nokia Care or call me at 99999-16148 India
Jun 03, 2009 | Nokia 6085 Cellular Phone
You most likely need a new ribbon cable, which is the cable that connects the two halves of the phone. They are not expensive and can be ordered on eBay, and they come with the tools required to disassemble the phone and replace the cable.
Jun 01, 2009 | Nokia 6085 Cellular Phone
Dropped BB in the rain
it would be best to take the phone now and have a mobile tech look and diagnose the problem to get it back in working don't really want to take chances with a phone that has been in contact with water.
Mar 18, 2009 | AT&T Blackberry Curve 8300 Smartphone
Water Damage?
today i went on my slip n slide with it in my pocket annd it got all wet. but then to make it worse i dove into my pool not even knowing it was in my pocket. but it works completely now=)))
Jun 12, 2008 | Pantech Duo Smartphone
I think it got wet
Yike! As with most electronics, they are necessarily dead when they get wet, but you do have to be very careful with them until they're dry. Here's the best you can do:
  1. Remove the stereo from the boat completely.
  2. Remove the cover(s) from the stereo to expose as much of the inside to air as possible.
  3. Let it sit for a few days inside to dry.
  4. Reassembly it and install it back in the boat.
If you're lucky, the unit will return to normal operation. Unfortunately, my guess is, since you powered the unit up when it was wet, damage may have already been done.
Mar 13, 2008 | Jensen CD400M CD Player
Gateway MX8711 Notebook Logo
69 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
