Question about Akai PT4298HD Rear Projection Television
IS AKAI PT4298 TV AN LCD OR DLP? AND HOW MANY YEARS IS IT IN THE MARKET ?
  • Akai Master
  • 8,617 Answers
Its neither. Its a CRT rear projection from around 2002
Posted on Dec 11, 2009
SOURCE:
Akai 55 inch dlp Tv
What is the problem of your
akai 55 inch dlp Tv?
Dec 23, 2011 | Akai LCT2715 27 in. LCD Television
I have an Akai 42"
Its usually the convergence board just replacing the old board with a good one should solve the issue. You can get the convergence board for the PT4298 at the following link just scroll down the page. http://www.tvrepairworld.com/samsung__akai_circuit_boards
Jun 24, 2011 | Akai PT4298HD Rear Projection Television
My akai dlp tv turns itself off then it flashes
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Feb 17, 2010 | Akai LCT3201TD 32 in. LCD Television
Hi I have TV AKAI start projecting a red
rear projection tv can be crt or dlp, if crt, try to adjust red color using the customer convergence feature, you will find it in the customer menu usually under advance feature or video settings, some tvs will just give the convergence caption right on the menu listing. If this does not help then the tv might be in need of some convergence circuit repair, probably one of the power outs is damages and needs to be replaced. If it is a dlp if the red shade extends all over the screen or located in a certain area of the screen then i would have the tech check for light engine trouble, this is a common problem on some dlp systems.if i answered your question satisfactorily please leave your positive feed back. thanks
Aug 26, 2009 | Akai Televison & Video
I have an AKAI 50in DLP rear projection HDTV keeps shutting down
hey there is sounds like your tv is trying to tell you to replace the lamp
the lamp is running out of mercury gas and is starting do give up I recommend you get a new bulb
Jun 19, 2009 | Akai PT50DL24 Television
AKAI Rear Projection 46"TV has a blank picture with sound only
Is it a CRT or a DLP/LCD projector? If not a CRT, a worn-out projection lamp can cause this symptom. When it is a DLP projector, a faulty Colour Wheel sensor can be the additional problem. If it is a CRT projection unit the High Voltage and deflection circuit must be examined...
Please tell me more about your unit...
Thomas
Jan 19, 2009 | Akai LCT2715 27 in. LCD Television
Need link and part number for STK-IC for AKAI PT4298 HD rear project convergence fix
The ICs you need are STK392-040 you will need two of them. You cant get the ICs or Radio Shack as they are specialty items. You can get them at the following link and they will provider free instalation instructions as well as free tech support just in case you need extra help. heres the link.
http://servicemanuals.vstore.ca/
Jun 04, 2008 | Akai PT4298HD Rear Projection Television
Akai PT4298HD Rear Projection Television Logo
77 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
