Question about Acer Aspire 1801WSCi Notebook
My Acer aspire laptop has 25 vertical diffrent coloured lines on the screen. They have slowly been getting worse over time. Have you any ideas what the problem can be? Dave.
  • 748 Answers
Your LCD panel is losing it - either the connections between the electronics and the glass panel are getting damaged, or the control electronics is dying for some reason. You can check if it's a connection problem by gently pressing the plastic frame above or below the display and seeing if it changes for better.
Either way, your LCD will need replacing. If the machine is still under warranty, contact the Acer service a.s.a.p. to get a warranty repair, otherwise it will cost you quite a bit...
Posted on Dec 11, 2009
Why does my monitor have colored vertical lines?
Hi Shannon,
I don't have good news for you. Coloured vertical lines is a symptom of terminal failure of LCD screens. Most common in laptops, monitors, and TVs. Problem only gets worse with time with more lines appearing, then expanding to cover a whole side of the screen. 30 - 50% normally.
Jul 19, 2012 | Dell Inspiron 2200 Notebook
Vertical lines on the Acer Aspire 5745G screen
yellow colour vertical line is comeing on screen since 30 days
Jan 03, 2012 | Computers & Internet
I have acer 7720 aspir it has a gforce 8400gs 256MB graphic card , the screen had vertical coloured lines and white static , now on start up colours go when log on vista , with the computer restarting . on...
I dont know this code but many problems is with this driver. Check drivers from Acer support and from chipset support. if it dont help you let me cnow.
Mar 17, 2011 | Acer Aspire 7720 Notebook PC
On turning on ACER Aspire 5920G laptop the laptop goes through the process of booting up, ie all relevant LEDs on power come on. The screen does not load up with usual ACER whitescreen and comes up with...
Hi. Yes, it could be a failing LCD screen but I would suggest to check the ribbon that connects the LCD screen to mainboard and make sure that it is not damage and properly connected.
Aug 20, 2010 | Acer Aspire 5920-6727 Notebook
Acer Aspire One - vertical lines on screen what is the problem?
as the system works fine with an external screen so the screen has definitely gone bad.only thing you can check is that to enter the setup(bios) screen and check if you can see the same problem.if it still is the same then you need to get the display replaced.you can access the setup the screen by tapping the option which will be displayed on the screen when you turn on the pc and see the acer screen.you need to tap the option which says "setup" on the screen.
Jan 23, 2010 | Acer Aspire One PC Notebook
I use a acer aspire 5810TZ and have a vertical line runnng through my screen how do i fix this problem
Well, if this is the same problem I'm having with my 5810T, then the settings have nothing to do with the vertical lines. There are vertical lines on my acer because the framing of the screen isn't thick enough. Thus, the lines are caused by the lack of sturdiness. Changing settings does nothing. However, pushing on the frame on the bottom of the screen adds more vertical lines. Releasing gets rid of some of them. Tapping also helps, but the problem only gets worse with time.
Nov 09, 2009 | Compaq Presario M2000 Notebook
Acer Aspire 5100 crashes when not plugged into charger.
yeppers..power supply is on multi colored unhappy mode..you'll need a new one..
Mar 21, 2008 | Acer Aspire 5100 Notebook
ACER 3023 SCREEN PIXELATING
Try uninstalling and reinstalling the video drivers. If this doesn't work, it's likely that the LCD control board or cable is damaged.
Feb 13, 2008 | Acer Aspire 3000 Notebook
Acer Aspire 1801WSCi Notebook Logo
69 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
