Question about Dayton Gas Furnace Heater
Installed dayton nat gas hanging furnace in garage and have 2 wires dont know where they go one came from the back side of the transformer it was twisted with the other wire
  • 1,420 Answers
Hopefully there is a wiring diagram glued to one of the panels to verify but on the transformer you will have 2, 110 volt wires. One is the power coming in (usually black wire) and the other is a common (white wire) and will be connected to other common leads. On the low voltage side of the transformer one wire will go to the thermostat then from the thermostat to the gas valve. The other side will connect to the gas valve. When the thermostat calls for heat it completes the circuit from transformer to gas valve back to transformer.
Posted on Dec 11, 2009
How do I hook up the exhaust on a Dayton Gas Garage heater?
Well you have to buy reducer to get it down to 2 inches. Are you sure it's 2 inches or 3 .
Maybe this is a high efficiency heater so design to use a 2 inches pvc pipe
Dec 19, 2017 | Dayton Gas Furnace Heater
I have a hanging Dayton in garage pilot lights fine furnace fires up runs 6or7 min. then burner and pilot go out
Does unit fan come on ??? Is flue clear as most units have a safety klixon if exhaust not venting properly.
Nov 24, 2012 | Dayton Gas Furnace Heater
I have a 25,000 BTU hanging furnace, will this heat a 900sq foot garage that has been insulated.
Here in Vermont we design heating systems to perform at -10 to -20 degrees. Depending upon how tight the doors and windows are, it may if your temperatures don't drop below 20 degrees. It may take a while to heat up and I would not expect any temperature over 62 degrees inside the garage. Maybe a 50,000 Btu heater? Remember the output may be 20% less than the rated input of the heater.
Dec 29, 2009 | Dayton Gas Furnace Heater
DAYTON HEATER 60,OOO BTU
Hi, I do not no the age of this unit, but when a furnace is installed, it is set up for Nat. gas., and they most always leave you a small package taped to or near the gas valve that has the spring and L.P. orfice in it, in case it is needed. See if you can find it first. If not, get all of the numbers from the main gas valve (mgv) and from the unit heating plate attached, b.t.u.If you can't find it, at the top of the main valve, you will see a brass colored screw slot.May be aluminum. Turn off gas and power. Remove the threaded screw cap and remove all small parts, a spring, a plastic or maybe aluminum round orfice, about 3 pieces. Keep them in the order you remove them.Replace with the L P Parts if you have them. If not, you will need to take the parts and all numbers you can get from valve and unit to a appliance parts store to purchase.You shouldn't have to adjust the gas pressure as now days they are the same for nat. and L P.About 3.4" of water colume. Thats a different name for pressure. Very easy for you to do. Good Luck, Shastalaker7
Dec 07, 2009 | Dayton Gas Furnace Heater
I have Dayton space heater 3E 229, pilot wont stay on,I have install new gas operating valve and checked transformer ( 30V) . Pilot lights up but wont stay on even if I hold button down for 2-3 min. please...
The thermocouple is likely defective...(Copper wire heated by the pilot) or the pilot itself is too small or dirty....the pilot must be BLUE , not yellow like a candle...and it must envelop the top portion of the thermocouple....you could also have an auxiliary limit or ECO wired in series with the thermocouple circuit that could be open.....also make sure the thermocouple is inserted all the way and is in the pilot flame as mentioned above
Oct 25, 2009 | Dayton Gas Furnace Heater
Furnace flame goes low fan stays on
if the gas pressure is good on inlet and outlet of valve u might wanna chk the burner trays and manifold for flakes, dirt, spider webs ect... once u kno the passages are clear from obstruction you can focus on the mechanical. (sounds like gas valve may be getting weak and not able to open fully)
Mar 21, 2009 | Dayton Gas Furnace Heater
We need install instructions for Dayton 3e290 gas wall furnace
Hi i would say get a gas fitter to do this its not as simple as it looks
Mar 19, 2009 | Dayton Gas Furnace Heater
Lot of the wires came off the on the back of the Heater
We have a Dayton Unit Heater in the garage, gas. the wiring is a mess do you have schematics?
Sep 23, 2008 | Dayton (3E386) Heater
Dayton Gas Furnace Heater Logo
1,251 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Tim Whalen
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
