Question about Gateway FPD2485W Television
Gateway FPD2485W monitor does not power up what can it be and does it cost alot to fix lmk mike
  • 1 more comment
  • Anonymous Feb 02, 2008
    same thing no power up not even a standby light but power supply has 5v and 27v for inverter on output side, should there be any other voltage coming from psu to main board i only read 5v.
  • EricL Jul 31, 2008
    I have the same problem but lack any electronic training. I took apart the monitor and have both the USB board and mother board in hand. How could I bench test the 1117 3.2v regulators on the mother board to determine which one, if any, is fried?
  • news12 May 11, 2010
    Does any one know where
    i can get a service manual and schematics for FPD 2485W?
HAVE GATEWAY REPLACE IT . . . . . . Under warranty ..... questions provide email
Posted on Apr 11, 2008
I had same problem main board had a bad 3.2 volt regulator
number on regulator was 1117 3.2 there were 2 of them and 1 on the usb hub board so i un soldered the one from the usb and replace the one on the mother board. must be very carefull with ribbon going to front bezel controls easily torn
Posted on Mar 12, 2008
How can I find Owner's manual for Gateway FPD2485W
Download it from there :
http://panam.gateway.com/s/Manuals/Monitors/8512114.pdf
Aug 30, 2014 | Computers & Internet
FIND SOFTWARE FOR GATEWAY FPD2485W TFT LCD Monitor
That model should be plug and play with windows, no disk should be needed. Just plug the monitor in and turn on the PC, it should show "New hardware detected" and load right up.
May 07, 2012 | Gateway Computers & Internet
Fpd2485w monitor takes several attempts to turn on.
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Sep 10, 2017 | Gateway FPD2485W Television
My Gateway FPD2485W Television will not turn on. Please help!
Check the power supply main AC fuse, caps. It can also be that it is in shutdown mode if it senses shorted circuits such as the backlights inverter board.
Parts:
http://www.shopjimmy.com/catalogsearch/result/?q=Gateway+FPD2485W+
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Please leave rating if it helps.
Jan 17, 2011 | Gateway FPD2485W Television
I have a gateway FPD2485W tft lcd monitor and i start my monitor and after it shows gateway it then goes black. How can this be fixed
bonannorl, Maybe it can be fixed. You did not give any history of unit. Only "now" stuff. Is unit covered by Gateway warranty? How old is unit? Date of manufacture? Did unit work fine connected to your pc and this black or black n blank screen thing suddenly happen? Is screen also BLANK? Have you swapped-in old monitor to prove PC is OK? Your CCFL back-lit lcd monitor no different than any other brand in it's basic design and operation. Get into my fixya profile and read some of my testimonials and solutions to black or black n blank screen problems to help in your decision to DIY fix or contract out needed repair work. Most likely 2485w has problem with it's internal "switch-mode-power-supply"/"ccfl inverter supply"!! Let me know more info about unit.
12fixlouie on fixya.
Mar 09, 2010 | Gateway Computers & Internet
I have gateway FPD2485w have take to repair they telling me that main circuit board is bad very cost prohibit to fix. if the monitor turn off it will not come back on wait for some times it will...
what they told you is correct, the power board is failing. but the board can be repaired most often verry easily it is a common problem with gateway. i have repaired several of the 21" gateway monitors. I would be glad to do the repair for you.for a small fee.
Dec 05, 2009 | Gateway FPD2275W LCD Monitor
Hi, how do I connect this monitor (Gateway FPD2485W) to my RG6 wire? I wanna watch TV on it. Thanks!
Use an RG6 adaptor to and install it to your RG6 wire. Then, plug it at the back of your monitor.
Sep 21, 2009 | Gateway FPD2485W Television
Gateway FPD2485W how do I replace the LCD
For most models, replacing an LCD panel is very close to the cost of a complete new monitor.
Jerry G.
Apr 15, 2008 | Gateway FPD2485W Television
Gateway fpd2485w lcd shows video then cuts off
I'm pretty sure the inverter board is bad. you have to replace it if you can or you can let someone else do it. you should find some on ebay for about $80 (not too bad compared to the cost of the monitor: over $200). but its up to you. But first, you should find out if you are still under warranty. good luck. please rate!!
Mar 22, 2008 | Gateway FPD2485W Television
Gateway FPD2485W Television Logo
1,403 people viewed this question
Top Gateway Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Are you a Gateway Televison and Video Expert? Answer questions, earn points and help others
